My LiveUSB from MX Snapshot/MX Live USB Maker is working
but installing this LiveSystem back on a computer stops with error.
Installation failed. Boost.Python-Error in Job "packages".
Unable to locate package live-boot
live-boot-doc
live-config
(using Q4os 4.8 plasma, MX Tools for Q4OS plasma)
Yes, we will investigate it and post back.
@judydudi
We are not able to reproduce the issue so far, snapshot and follow up installation went well in a VM. If possible, provide the "qreport.tar.gz" file of the current live snapshot booted up, as described here https://www.q4os.org/forum/viewtopic.php?id=3502
Then run in terminal of the original system:
$ sudo apt --purge autoremove *live-boot* *live-config* *calamares*
Make a new snapshot, boot it, proceed an installation from this snapshot media and report back please.
@Q4OSteam
i guess you only use legacy bios boot in VM.
Are you using MX snapshot AND MX live usb maker?
Legacy System -> USB -> Legacy System: fine
Legacy System -> USB- > UEFI System: failed
UEFI System - > USB -> UEFI System: failed
Are you able to check with UEFI system too? Thanks in advance!
Not exactly, we didn't use legacy BIOS for the testing VM, see the steps we have taken:
- Q4OS Gemini Plasma installation in Virtualbox - EFI enabled
- MX tools for Q4OS installed
- Subsequently generated snapshot .iso using mx-snapshot tool
- Move the .iso outside the VM
- Reset VM and boot that .iso on the same VM
- Proceed installation using Calamares
- Installation was a success, it setup a bootable, fully functional system.
Yes, we have not used MX usb-maker indeed, as the generated .iso file could be booted directly in Virtualbox. However the issue doesn't look to do anything with MX tools. Calamares couldn't find "live-boot" files in its Apt database. It seems to be some inconsistency in the original system itself, so we would need the "qreport.tar.gz" file for investigation as mentioned before.
Anyway, we will perform the procedure you suggested on a real UEFI hardware and post back asap, however it will take some time.
Ahh, OK. I did my testing today in Virtualbox too, but with a real USB stick connected, written by MX live usb maker.
seems to be the MX live USB maker.... I will try use the snapshot with rufus.... and do other investigation.
@judydudi
We are now able to reproduce the issue, it will arise under certain circumstances no matter how the .iso file is written to an usb stick. We are on the right track to fix it, so you can stop investigations and wait for us to fix it.
@judydudi
The issue has been fixed, you only need to update from Q4OS repositories.
@q4osteam
thank you so much - i can confirm that this issue is fixed.
So next issue
My source (uefi) pc system is encrypted (notebook). USB stick works fine, but installation back on pc with or even without encryption went into a issue. see picture.
i don't know if it's a bug or if my standards are high
My source (uefi) pc system is encrypted (notebook). USB stick works fine, but installation back on pc with or even without encryption went into a issue ...
Yes, we will take a look at it and post back.
We have made a significant upgrade of MX tools for Q4OS. Almost all of the tools has got an update based on the latest MX modifications and patches. Current users only need to update from Q4OS repositories.
@judydudi
The upgrade may, or may not, solve the issue with encrypted hard drives. We are going to investigate it, however some independent check would be appreciated.
Thank you for taking care of the integration of the mx tools.
i did a new test with these upgrades.
My live USB stick created with MX snapshot/mx live usb maker does now have a error message (pic1), but continues after click.
USB boot menue looks different now, but ok (pic2)
My test with a normal install (gemini plasma, basic profil) from uefi source via USB on normal uefi pc install works.
my test from my notebook (plasma4.8, uefi with / and /home partion encrypted), desktop profile ends again with luks error. (pic3)
I'm keeping my fingers crossed that you'll get it right! Thanks.
Pic1.jpg - We can confirm the Grub error message on the live media. It's not critical, anyway, it is going to be fixed.
Pic2.jpg - Ok.
Pic3.jpg - Investigations are underway, we will post here about a possible fix.
We believe, we are on the right path to fix this issue, however it will take some time. We will post back a progress info in some of 10 days. Anyway, thanks for the valuable reporting and testing.
We are working on a fix, it should be ready in a week. If not so, we will post a progress info.
The fix is underway, it will take a few more days to release new MX Tools upgrade.
In the meantime, we would suggest to try a possible workaround. As you run the Snapshot tool, click the "Edit exclusion file" button on the second screen, scroll down the file content and add the line:
etc/default/grub
Save the exclusion file and continue creating the snapshot as usual.
Thank you so far. I really appreciate it.
I will try it out tomorrow.
We have fixed the issue, along with other updates and fixes. You only need to do upgrade from repositories and reboot your system. The reboot is important for changes to take an effect.
A feedback would be appreciated.
@q4osteam
My first test worked right away even with encrypted source partitions. (uefi computer -> USB Stick -> Uefi Computer)
I am so excited. Many thanks for your effort.
In the next few days, I'm going to explore the tools in depth. I will let you know what I find out.
@q4osteam it is great fun to move the system so easily and flexibly with the tools.
The only thing I've stumbled across so far is when I check the box 'encryption' on the live usb maker. Then the stick starts and hangs when I enter a password. To be honest, it doesn't seem to work with mx linux either. So no idea if u want to look at that. Many thanks so far for your effort!
Yes, we will check this hitch as well and post back here, although it may take a while. Anyway, thanks for the feedback, great to see the tool can do a good job for you.
We have tested the encryption option and it seems to be working fine. The issue may be hardware dependent, or some procedure variation on your side. Please provide more details for us to be able to reproduce and investigate. You also need to enter a new password twice on the first live USB boot, then it only asks for that password on each subsequent boot.
By the way, MX tools for Q4OS has been updated as of today, current users only need to do an upgrade from Q4OS repositories.
MX toolbox is a huge plus!
Thank you!
DELL Optiplex 7060 - 8G RAM.
Have the tools been updated in line with the recent changes by the MX team?
Yes, they are, approximately on monthly basis.
