Tip 1 - Trinity desktop:
Use built-in TDE wifi manager
Right click on the network manager icon in system tray > edit connections > select wireless connection > click edit connection button > go through all steps of the guide and enter proper values > until you get to the check box that says "Automatically Connect" > then click "Connect and Save".
Tip 2 - Plasma, Trinity and other desktops:
Use desktop environment independent tool "nmtui"
Another way is to use terminal tool "nmtui", what is desktop environment independent. So run in any terminal:
$ nmtui
and setup your wifi
Tip 3 - Trinity desktop:
Install external advanced network manager applet
- Install from repositories:
$ sudo apt install network-manager-applet
- Reboot
- Run:
$ nm-applet
- Find network manager applet in the system tray > right click > configure > configure desired networks
Tip 4 - Request a help on the forum:
If you request a wifi related help, it would be appropriate to provide output of the following terminal command:
$ inxi -SMCGxn
Moreover, you should provide debug info as described here https://www.q4os.org/forum/viewtopic.php?id=3502
Might I suggest that for ANY wifi connection issue it is mandatory for the user to provide the output of inxi -SMCGxn before it is answered.
Without that one has no idea what sort of can of worms one is dealing with.
@bin
We have updated the OP, thanks.
I am new to Q4os so excuse me if I sound uninformed. I am trying to set up aan Archer T2U plus usb adator for Wifi. I cannot find out how to enable it. The install disc does not execute at start up. It may be set for Windows or Mac. I know it can be configured for Mint linx or Ubuntu. Any suggestions? Thanks!
The solution is here:
ASUS PRIME X470-PRO, AMD Ryzen 7 1700X 8 Core, 16 Gb RAM, Asus GT1030 2 Gb DDR-5 Q4OS 5.9 (Aquarius)
Driver support for this device in Debian is a mixed bag, but take a look at this and read it all the way through,
https://docs.alfa.com.tw/Support/Linux/RTL8812AU/
To be honest youd be better off getting another device that has native Linux support as this product clearly states it doesnt support Linux.
Noob's question...
At https://easylinuxtipsproject.blogspot.c … .html#ID10
"Speed up your wireless internet by disabling the WiFi power management"
Can it use in Q4OS TDE?
Use iwconfig and see whether your wifi chipset power management is on/ off or doesnt show anything. You really should post this question in a separate thread for better visibility. It should work but is it really necessary?
i am having similar issues. This is the second time this has happened and a reboot before solved the issue. Wireless is not available...i see all the settings no matter what manager i use, but i cannot enable it....
Here is the output from the commands that have been suggested...
andrew@andrew-rog:~$ inxi -SMCGxn
System:
Host: andrew-rog Kernel: 6.1.0-41-amd64 arch: x86_64 bits: 64 compiler: gcc
v: 12.2.0 Desktop: KDE Plasma v: 5.27.5 Distro: Q4OS 5.8.1-n1 base: Debian
GNU/Linux 12 (bookworm)
Machine:
Type: Laptop System: ASUSTeK product: ROG Strix G531GU_GL531GU v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G531GU v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G531GU.306 date: 09/24/2019
CPU:
Info: 6-core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 1585 high: 1700 min/max: 800/4500 cores: 1: 1700 2: 1700
3: 1344 4: 1700 5: 1700 6: 1700 7: 1700 8: 1031 9: 1700 10: 1348 11: 1700
12: 1700 bogomips: 62399
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nouveau v: kernel arch: Turing bus-ID: 01:00.0 temp: 29.0 C
Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.9 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915
resolution: 1920x1080~120Hz
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Network:
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK RTL8111/8168/8211/8411 driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: 04:d4:c4:7b:27:0a
andrew@andrew-rog:~$ iwconfig
bash: iwconfig: command not found
I am also new to Q4OS.
The system was running great until I installed Proton VPN.
The WIFI is now disabled, but the wired connection (enp0s25) is okay.
I tried the Edit connections, but no change.
I tried nmtui, but no change.
I also lost the setup for firefox and thunderbird, but I have reinstalled okay.
I tried to find the ProtonVPN package with Synaptic to remove it, but ProtonVPN was not found.
The WIFI New connection menu shows 2 Unknown connections (wlp3s0) (enp0s25) and a VPN connection.
The WIFI deactivate menu shows a connection called lo and won't respond to enable WIFI.
The notification settings shown a VPN banner notification, a VPN connection attempt failed
and a wireless network disappeared.
The wireless connection (wlp3s0) is disabled.
Thx
inxi -SMCGxn
Host: q4os-hpelitebook8530p Kernel: 6.1.0-34-amd64 arch: x86_64 bits: 64
compiler: gcc v: 12.2.0 Desktop: Trinity v: R14.1.1 Distro: Q4OS 5.8.1-n1
base: Debian GNU/Linux 12 (bookworm)
Machine:
Type: Laptop System: Hewlett-Packard product: HP EliteBook 8530p v: F.12
Mobo: Hewlett-Packard model: 30E7 v: KBC Version 90.27
serial: <superuser required> BIOS: Hewlett-Packard v: 68PDV Ver. F.12
date: 06/08/2010
CPU:
Info: dual core model: Intel Core2 Duo P8700 bits: 64 type: MCP arch: Penryn
rev: A cache: L1: 128 KiB L2: 3 MiB
Speed (MHz): avg: 800 min/max: 800/2534 boost: enabled cores: 1: 800
2: 800 bogomips: 10108
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3
Graphics:
Device-1: AMD RV635/M86 [Mobility Radeon HD 3650] vendor: Hewlett-Packard
driver: radeon v: kernel arch: TeraScale bus-ID: 01:00.0 temp: 64.0 C
Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: radeon
unloaded: fbdev,modesetting,vesa dri: r600 gpu: radeon
resolution: 1280x800~60Hz
API: OpenGL v: 3.3 Mesa 22.3.6 renderer: AMD RV635 (DRM 2.50.0 /
6.1.0-34-amd64 LLVM 15.0.6) direct-render: Yes
Network:
Device-1: Intel 82567LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 80e0 bus-ID: 00:19.0
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: 78:e7:d1:af:6b:3b
Device-2: Intel Ultimate N WiFi Link 5300 driver: iwlwifi v: kernel
bus-ID: 03:00.0
IF: wlp3s0 state: down mac: 00:21:6a:be:07:68
Welcome to the forum @dano
Please create a new topic in the support section https://www.q4os.org/forum/viewforum.php?id=3
Crosscourt, this system has been working for several montessori exactly as is. The only difference is I now installed it on
another, similar ssd. Apart from that everything is the same.
One more thing could be that the very reson for the reinstallation was that q4os stopped working entirely and I could not get it going.
Reinstalling was the final attempt I came up with. So it is of course possible some hardware gave in.
Peter
Q4os team:
Hope you can see this relaterad to the correct post....
I received a response to my not being able to open wireless wifi.
One suggestion was to run nmtui and then setup your wifi. I did that, so now I have
a box "nmtui ‐- Konsole". There I can see my wireless connection but not activate it ?
There is profile name,
SSID (password ?),
BsSID ??? Some numbers
IPv4-config -automatic
Ipv6 same thing
Connect automatically and for everyone are both ticked.
Not very clear but I installed it in swedish, which was a mistake.
This looks good, but how do I confirm or activate it ?
This is actually the first confirmation of a wireless connection but, again, it wont run.
Not able to copy computer data, but my distro is q4os 6.5.1 - deb 13u1 (Andromeda)
Kennel is 6.12.69 + deb13-amd64
Not very clear I know.....
Peter
Reading #13 I have another comment (yes, I am answering my own post....)
I just remembered my previous q4os installation, a few months ago. That one connected wifi on the spot, with the same usb unit I am trying to use now.
My present installation is somewhat different, more code to start up. (I know, it's called progress...)
Is it possible my wifi unit Is simply outdated, and a newer one Is needed ?
If so, where can I find a previous version ?
A new route, yes, but this system is a bit limited w/o wifi
Check first that
- the SSID (Service Set IDentifier) in your WiFi config matches the SSID of your WiFi router (often written on a label present on the router);
- the BSSID is empty;
- the mode is "Infrastructure";
- the security mode matches the one required by your router (often WPA / WPA2);
- the password is correct
- you are not out of range of your WiFi router.
If it still not works, please describe what "I received a response to my not being able to open wireless wifi" means (your post #13); give the exact error message if there was one.
Also please also specify which desktop (Plasma / Trinity) you are using; they have GUI to configure WiFi but they are different. Don't hesitate to attach screenshots of each tab in your WiFi config to show the exact values and choices that are cofigured.
As I understand your last post, you are using an USB WiFi dongle, correct? Are you sure it hasn't been damaged since the last time you used it and the connectors are clean and in good state? And what are the exact references of you device? Without that info, nobody can give any advice on drivers.
Hchiper,
#13 was just referring to my earlier error description: "not being able to open wireless wifi" .
I have the settings you mentioned, but see no trace of life. Lacking wifi, providing screen shots is difficult, you have to trust me....
I can add my system info, DebianGNU/Linux 13, KDE Plasma Version 6.3.6, Frameworks Version 6.13.0
Still in the dark about this, the only good sign is that it worked ok during installation...
Peter
Hchiper, another comment:
My Hardware info shows, under Network, Device 2: Realtid RTL8188SU 802.11n WLAN Adapter driver:N/A type: USB rev:2.0.........
So it appears to be seen by the system.
From the answers and information you give in your two previous posts, the only advice I can give is to check that the package "firmware-realtek" is installed: see the result of
apt list firmware-realtekQ4OS machine: Samsung R519 - Pentium T4200 2.0 GHz - 4 GB RAM - 500 GB SSD
