#1 2026-01-24 19:34
Totone
Directory / not access
Hello,
From Dolphin, I no longer have access to
the / directory. All other directories are present
But in recent locations,  / is missing.
I restored the timeshift, but it's still the same.
Do you have any idea how this happened,
How to fix it, or what to do to remedy the situation?
Regards,
#2 2026-01-25 12:19
Re: Directory / not access
Type just a slash in Dolphin's address bar and hit Enter.
You can also open a Terminal and type `$ dolphin "/"`.
Note that you will never see the root of the file system "/" in Dolphin right panel.
Most probably you'll see it in Dolphin's "Devices" section rather than "Recent locations".
#3 2026-01-25 16:14
Totone
Hello,
Thanks for the reply, I was wrong, but it's the "Devices" tab that's no longer displayed on the left in Dolphin.
I do have "Recent Files" and "Recent Locations," and I don't know how to get the "Devices" tab back.
Regards
#4 2026-01-25 18:15
I think you can right-click somewhere in the left panel and select to display everything.
Very user unfriendly...
#5 2026-01-26 16:22
Totone
Excuse me, but why is it "Very user unfriendly"?
Excusez-moi mais en quoi ai-je été "Très peu convivial".
#6 2026-01-26 16:57
I meant that the way one have to find how to display devices is unfriendly (one would expect to have a parameter in the settings, but there is none).
#7 2026-01-26 18:12
Totone
OK   wink
This image makes it clearer
[https://i.postimg.cc/zBB8f2Tt/peripherals.jpg]
#8 2026-01-26 22:27
Have you read the first line in post #4 or does it not work?
#9 2026-01-28 17:54
Totone
Yes, I read it, and right-clicking doesn't work.
I'm considering reinstalling everything.
Thank you for your help.
#10 2026-01-28 21:35
No contextual menu on right-click? Or no option to enable/activate?
