#1 2025-08-03 21:58
Trinity Bugs and Issues
KICKER ISSUES
BLOCK_1
  • this green line, turns orange if i change Active Title Bar color to something random
  • this line in itself is weird, cant find a way to remove it or theme it manually
  • the "shadow" above the line can not be removed/changed
  • the lock and power off buttons' background and the background of username/image above the line is the same as Active Title Bar, hence cannot be themed properly
  • BONUS: Sometimes dropdown of Widget Color (or other trinity apps' dropdowns) have white borders, even when dark theme is on
BLOCK_2
  • The text color of hovered item's Name doesnt fit with dark theme, renders unreadable
  • BONUS: Tooltips are not themable
BLOCK_3
  • On clicking the Apps button, the left panel's width increases and right panel's items become only partially visible
BLOCK_4
theasmitkid wrote:
the reason might be the huge lengths of
RecentAppsStat= (10901 characters)
FirstSeenApps= (5873 characters)
inside file
~/.trinity/share/config/kickerrc
is there a way to reduce/clear it?
BLOCK_5
  • Sometimes when trying to open menu but it doesn't open on the first try so you click the button repeatedly and then when it shows up and you close it OR it just opens and closes repeatedly and closes, keyboard stops working, I can no longer register keypresses.
    To fix it you need to open and close menu one more time, after that i can input keyboard stokes as normal
COMPTON-TDE ISSUES
BLOCK_1: Partially Fixed (it's white now)!
  • KColorEdit renders background inside its window somehow
TDEIO ISSUES
BLOCK_1
  • Trash icon showing empty if item was deleted via gvfs (thunar), but opening tdeio's trash (konqueror) shows there's trash inside
  • tdeio and gvfs(gio) dont share their trash between various partitions
BLOCK_2
  • tdeio (konqueror) cannot access smb while gvfs (Thunar) can, meanwhile both can access ftp
THEMING ISSUES
BLOCK_1
  • While selecting shortcut and in advanced more, the shortcut text is not themed correctly, rendering it unreadable (similar to BLOCK_4, BLOCK_7 and BLOCK_9)
BLOCK_2
  • The hovered dropdown arrow key for trinity programs dont have proper icon for dark theme, making it hard to see
BLOCK_3
  • Icons in kate's sidebar is not rendered properly, maybe missing icons
BLOCK_4: FIXED!
  • no theming for kate's konsole (similar to BLOCK_1, BLOCK_7 and BLOCK_9)
  • right click on kate's console, go to Settings, check Use Konsole's Settings
BLOCK_5
  • Example Text not themed in Control Panel/Country/Region & Language
BLOCK_6
  • Disabled buttons not themed in konqueror
BLOCK_7
  • Code "blocks" icon not themed (the '-' in the yellow box) (similar to BLOCK_1, BLOCK_4 and BLOCK_9)
BLOCK_8
  • Close Buttons in Konqueror's sidebar is not themed when multiple view is enabled
BLOCK_9: FIXED!
  • Konqueror Location bar's background not themed when visiting websites (similar to BLOCK_1, BLOCK_4 and BLOCK_7)
BLOCK_10
  • Q4OS Icon is not themed
BLOCK_11: FIXABLE!
  • Ark's embedded advanced text viewer not themed
  • Will be fixed if using themes which support Kate theming like Timir
KATE ISSUES
BLOCK_1
  • When pressing Keyboard Shortcuts in kate's konsole sometimes executes shortcuts in kate and sometimes in konsole
    for example, Shift+Insert (to paste clipboard content) in konsole, pastes content in kate
    but just after that, pressing Ctrl+Z doesn't undo the paste in kate but it just runs Ctrl+Z in konsole
BLOCK_2
  • When there are multiple files open, suppose a, b and c. The currently open file be a, then if you right click to close file c, file a gets closed and file c opens.. I think this issue wasn't in Q4OS 5. This has led to loss of a lot of progress in my codes (especially when I have some important detail in previous state, reopening file resets undo/redo)
#2 2025-08-03 22:07
Re: Trinity Bugs and Issues
Thanks, we will check them all.
#3 2025-08-03 22:26
added kicker/block-4 to original post
#4 2025-08-05 11:32
Please edit the original post and add kicker issues / block 4. We will move this topic to the bugs section soon. We will also post some replies a bit later. In anyway we are addressing issues reported, thanks.
#5 2025-08-16 11:53
added kicker/block-5
#6 2025-08-17 12:42
added THEMING ISSUES/block-7
added THEMING ISSUES/block-8
added THEMING ISSUES/block-9
#7 2025-08-17 22:03
marked THEMING ISSUES/block-4 as fixed!
(gosh i wish i knew earlier.. loving kate more)
added KATE ISSUES/block-1
#8 2025-09-08 15:49
added additional issue to THEMING ISSUES/block-3
#9 2025-09-08 15:53
@q4osteam would these issues be fixed in the upcoming Q4OS 6 or would be released as patched packages later?
#10 2025-09-08 16:01
First we need to sort and address the particular issues. We will come in touch here some time after Q4OS-6 release and post some replies and surveys. In anyway continue to report that way, it's helpful for us at least to make some view of user's experience.
#11 2025-09-08 16:29
got it! thankyou~! smile
#12 2025-09-13 11:12
added THEMING ISSUES/block-10
#13 2025-09-13 11:17
added THEMING ISSUES/block-11
#14 2025-09-18 04:57
marked THEMING ISSUES/block-11 as fixable
#15 2025-09-26 10:51
marked THEMING ISSUES/block-9 as fixed in R14.1.5
#16 2025-10-13 11:37
BLOCK_1
- this green line, turns orange if i change Active Title Bar color to something random
- this line in itself is weird, cant find a way to remove it or theme it manually
- the "shadow" above the line can not be removed/changed
This is not random, but somewhat complementary highlight color. Although we don't consider this one as an issue, we may think about to add an option to hide the line.
#17 2025-10-13 15:44
An option to hide it would be much appreciated!
#18 2025-10-13 15:45
marked COMPTON-TDE ISSUES/block-1 as partially fixed in R14.1.5
#19 2025-10-15 11:33
BLOCK_2
- The text color of hovered item's Name doesnt fit with dark theme, renders unreadable
- BONUS: Tooltips are not themable
We can confirm both issues. Both are reproducible on plain Debian/Trinity with dark colors configured. So we consider them as upstream Trinity issues.
#20 2025-10-15 16:58
added kate issues/block-2
#21 2025-10-16 11:01
BLOCK_3 - On clicking the Apps button, the left panel's width increases and right panel's items become only partially visible
Yes, that's by design, no bug.
#22 2025-10-17 12:17
BLOCK_4 - Edit 2: menu, hangs a lottt
We are not able to reproduce, please specify more precisely. What menu, what hangs exactly and when.
#23 2025-10-17 12:44
For example when trying to search for something, there's a 2-30 sec delay when it stops responding
#24 2025-10-17 12:54
We are unable to reproduce. Searching works fine here. Are you able to reproduce that when booting from the live media ?
#25 2025-10-17 17:27
Umm.. no, it happens after prolonged usage, during which a lot of programs need to be installed n removed. Eventually the config file entry gets larger and causes lagging on slow/weak machine like mine
