#1 2023-11-26 06:53
HerrAbisZ
Q4OS 5.3 Aquarius no installation of programs from the software center
I have now tried several times to install programs such as firefox, google chrome, updatemanager, mutimedia codes, etc. from the software center. it is not working at the moment
the installation starts, then the screen flashes a few times and I end up on the login screen.
Or I get an error message. hope I can reproduce it
this appears if you have only loaded the Q4OS Pure profile
I currently have the desktop profile loaded. I could only install Google chrome in the console / terminal
BITTE helft einander! Mehr auf meinem Blog http://herrabisz.wordpress.com/ http://www.youtube.com/user/HerrAbisZ2 + 3
#2 2023-11-26 10:58
Re: Q4OS 5.3 Aquarius no installation of programs from the software center
Please provide more info, see https://www.q4os.org/forum/viewtopic.php?id=3502
#3 2023-11-26 11:28
HerrAbisZ
I installed from the USB Stick. exFAT YUMI like ventoy with q4os-aquarius-5.3-x64.r1 - boot in normal mode - hanging at finished the installation. Boot in Grub2 mode - no hanging at finish
I currently have the desktop FULL profil loaded.
dieserpc@dieserpc-aspire5715z:~$ inxi -F --full
System:
  Host: dieserpc-aspire5715z Kernel: 6.1.0-13-amd64 arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.5 Distro: Q4OS 5.3.1-n1
Machine:
  Type: Other-vm? System: Acer product: Aspire 5715Z v: V1.45
    serial: <superuser required>
  Mobo: Acer model: Acadia v: V1.45 serial: <superuser required> BIOS: Acer
    v: 1.45 date: 11/10/2008
Battery:
  ID-1: BAT0 charge: 22.6 Wh (65.1%) condition: 34.7/44.4 Wh (78.2%)
    volts: 10.9 min: 11.1
CPU:
  Info: dual core model: Intel Core2 Duo T9300 bits: 64 type: MCP cache:
    L2: 6 MiB
  Speed (MHz): avg: 2400 min/max: 2400/2401 cores: 1: 2400 2: 2400
Graphics:
  Device-1: Intel Mobile GM965/GL960 Integrated Graphics driver: i915
    v: kernel
  Display: x11 server: X.Org v: 1.21.1.7 driver: X: loaded: modesetting
    unloaded: fbdev,vesa dri: crocus gpu: i915 resolution: 1280x800~60Hz
  API: OpenGL v: 2.1 Mesa 22.3.6 renderer: Mesa Intel 965GM (CL)
Audio:
  Device-1: Intel 82801H HD Audio driver: snd_hda_intel
  API: ALSA v: k6.1.0-13-amd64 status: kernel-api
Network:
  Device-1: Broadcom NetLink BCM5906M Fast Ethernet PCI Express driver: tg3
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: 00:1b:38:c9:23:06
  Device-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter
    driver: ath5k
  IF: wlp6s0 state: down mac: 00:1f:3a:34:12:fc
Drives:
  Local Storage: total: 156.33 GiB used: 15.01 GiB (9.6%)
  ID-1: /dev/sda vendor: Hitachi model: HTS542516K9SA00 size: 149.05 GiB
  ID-2: /dev/sdb type: USB vendor: Intenso model: Rainbow Line
Partition:
  ID-1: / size: 31.19 GiB used: 9.15 GiB (29.3%) fs: ext4 dev: /dev/sda5
Swap:
  Alert: No swap data was found.
Sensors:
  System Temperatures: cpu: 40.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 165 Uptime: 19m Memory: 2.89 GiB used: 1.55 GiB (53.5%)
  Shell: Bash inxi: 3.3.26
Operating System: Debian GNU/Linux 12
KDE Plasma Version: 5.27.5
KDE Frameworks Version: 5.103.0
Qt Version: 5.15.8
Kernel Version: 6.1.0-13-amd64 (64-bit)
Graphics Platform: X11
Processors: 2 × Intel® Core™2 Duo CPU T9300 @ 2.50GHz
Memory: 2.9 GiB of RAM
Graphics Processor: Mesa Intel® 965GM
Manufacturer: Acer
Product Name: Aspire 5715Z
System Version: V1.45
qreport in the appendix
Maybe Alert: No swap data was found.???
many thanks
#4 2023-11-26 11:52
It looks like your sources.list is misconfigured some way. Try to run in terminal and post output here:
$ qrepolist
$ sudo apt update
#5 2023-11-26 12:06
HerrAbisZ
dieserpc@dieserpc-aspire5715z:~$ qrepolist
deb http://q4os.org/q4repo q4os-5-0-cn main
deb http://deb.debian.org/debian/ bookworm main contrib non-free non-free-firmware
deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian/ bookworm-updates main contrib non-free non-free-firmware
deb [arch=amd64] https://dl.google.com/linux/chrome/deb/ stable main
deb [signed-by=/usr/share/keyrings/q4a-skype.gpg trusted=yes arch=amd64] https://repo.skype.com/deb stable main
deb [trusted=yes] copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/
dieserpc@dieserpc-aspire5715z:~$ sudo apt update
Ign:1 copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/ InRelease
Ign:2 copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/ Release
Ign:3 copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/ Packages
Ign:4 copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/ Translation-de
Ign:5 copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/ Translation-en
Ign:6 copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/ Translation-de_AT
Holen:3 copy:/tmp/tmp.d8kIZ0TR07-q4appsetup2 tmp-setup-repo/ Packages [374 B]
OK:7 http://security.debian.org bookworm-security InRelease
OK:9 http://deb.debian.org/debian bookworm InRelease
OK:10 http://deb.debian.org/debian bookworm-updates InRelease
OK:11 https://repo.skype.com/deb stable InRelease
OK:8 https://q4os.org/q4repo q4os-5-0-cn InRelease
OK:12 https://dl.google.com/linux/chrome/deb stable InRelease
Es wurden 374 B in 2 s geholt (181 B/s).
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Alle Pakete sind aktuell.
Is it better to install without an internet connection?
I also tried to install Skype here https://www.q4os.org/forum/viewtopic.php?id=3624 - same thing
#6 2023-11-26 12:11
Well, reboot your computer and run some more commands:
$ cd /tmp/
$ wget q4os.org/downloads_app5/setup_q4os-updater_4.1.1-a1_all.esh
$ sudo qsinst /tmp/setup_q4os-updater_4.1.1-a1_all.esh
and post the output.
#7 2023-11-26 12:12
HerrAbisZ
OK
I can't resize the q4OS partition even with gparted
#8 2023-11-26 12:23
HerrAbisZ
another info: I have a dual boot system with win7 and 11 on it too. After the installation the file system of the HDD is broken - I have to repair it again and again with the system startup repair with a win7 DVD, because otherwise the PC does not start.
#9 2023-11-26 12:27
HerrAbisZ
Many Thanks for your helping
dieserpc@dieserpc-aspire5715z:~$ cd /tmp/
dieserpc@dieserpc-aspire5715z:/tmp$ wget q4os.org/downloads_app5/setup_q4os-updater_4.1.1-a1_all.esh
--2023-11-26 12:25:32--  http://q4os.org/downloads_app5/setup_q4 … a1_all.esh
Auflösen des Hostnamens q4os.org (q4os.org)… 2a02:4a8:ac24:108::96:231, 81.95.96.231
Verbindungsaufbau zu q4os.org (q4os.org)|2a02:4a8:ac24:108::96:231|:80 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 301 Moved Permanently
Platz: https://q4os.org/downloads_app5/setup_q … a1_all.esh [folgend]
--2023-11-26 12:25:32--  https://q4os.org/downloads_app5/setup_q … a1_all.esh
Verbindungsaufbau zu q4os.org (q4os.org)|2a02:4a8:ac24:108::96:231|:443 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
Länge: 12340 (12K) [application/octet-stream]
Wird in »setup_q4os-updater_4.1.1-a1_all.esh« gespeichert.
setup_q4os-updater_4.1.1-a1 100%[=========================================>]  12,05K  --.-KB/s    in 0s
2023-11-26 12:25:32 (132 MB/s) - »setup_q4os-updater_4.1.1-a1_all.esh« gespeichert [12340/12340]
dieserpc@dieserpc-aspire5715z:/tmp$ sudo qsinst /tmp/setup_q4os-updater_4.1.1-a1_all.esh
[sudo] Passwort für dieserpc:
[2023/11/26 12:25:58.603] Setup action:  Calculating progress ...
[2023/11/26 12:25:58.612] Setup action:  Testing Internet connection ...
[2023/11/26 12:25:58.779] Setup action:  Testing Internet connection ... OK
[2023/11/26 12:25:58.782] Setup action:  Extracting archive ...
[2023/11/26 12:25:58.810] Setup action:  Extracting archive ... Done
[2023/11/26 12:25:58.813] Setup action:  Checking package system ...
The following packages are in a mess due to serious problems during
installation.  They must be reinstalled for them (and any packages
that depend on them) to function properly:
libgtk2.0-common     common files for the GTK graphical user interface library
The following packages are missing the md5sums control file in the
database, they need to be reinstalled:
[2023/11/26 12:25:59.228] Setup action:  Package system not consistent ...
[2023/11/26 12:25:59.231] Setup action:  Trying to recover APT integrity ...
Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
  libgtk2.0-common
Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
1 nicht vollständig installiert oder entfernt.
Es müssen noch 0 B von 2.700 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
N: »tmpsetup.list« in Verzeichnis »/etc/apt/sources.list.d/« wird ignoriert, da es keine reguläre Datei ist.
OK:1 http://security.debian.org bookworm-security InRelease
OK:2 http://deb.debian.org/debian bookworm InRelease
OK:3 http://deb.debian.org/debian bookworm-updates InRelease
OK:5 https://dl.google.com/linux/chrome/deb stable InRelease
OK:4 https://q4os.org/q4repo q4os-5-0-cn InRelease
  libgtk2.0-common
[2023/11/26 12:26:13.190] Setup action:  Package system still not consistent, canceling installation ...
[2023/11/26 12:26:13.194] Installation failed !
#10 2023-11-26 12:44
Run commands to fix the package system:
$ sudo dpkg -r --force-all libgtk2.0-common
$ sudo apt install -f
and post back
#11 2023-11-26 13:06
HerrAbisZ
dieserpc@dieserpc-aspire5715z:~$ sudo dpkg -r --force-all libgtk2.0-common
dpkg: Warnung: Problem wird übergangen, weil --force angegeben ist:
dpkg: Warnung: Paket ist in einem sehr schlechten inkonsistenten Zustand - Sie sollten
es erneut installieren, bevor Sie es zu entfernen versuchen.
(Lese Datenbank ... 180961 Dateien und Verzeichnisse sind derzeit installiert.)
Entfernen von libgtk2.0-common (2.24.33-2) ...
dieserpc@dieserpc-aspire5715z:~$ sudo apt install -f
#12 2023-11-26 13:11
Looks good now. Now run again those commands https://www.q4os.org/forum/viewtopic.ph … 755#p25755 and post back
#13 2023-11-26 13:21
HerrAbisZ
--2023-11-26 13:19:14--  http://q4os.org/downloads_app5/setup_q4 … a1_all.esh
--2023-11-26 13:19:15--  https://q4os.org/downloads_app5/setup_q … a1_all.esh
Wird in »setup_q4os-updater_4.1.1-a1_all.esh.1« gespeichert.
2023-11-26 13:19:15 (91,7 MB/s) - »setup_q4os-updater_4.1.1-a1_all.esh.1« gespeichert [12340/12340]
[2023/11/26 13:19:31.918] Setup action:  Calculating progress ...
[2023/11/26 13:19:31.926] Setup action:  Testing Internet connection ...
[2023/11/26 13:19:32.130] Setup action:  Testing Internet connection ... OK
[2023/11/26 13:19:32.133] Setup action:  Extracting archive ...
[2023/11/26 13:19:32.148] Setup action:  Extracting archive ... Done
[2023/11/26 13:19:32.151] Setup action:  Checking package system ...
Reading package lists... Done
N: Ignoring 'tmpsetup.list' in directory '/etc/apt/sources.list.d/' as it is not a regular file
[2023/11/26 13:19:32.667] Setup action:  Verified ... OK
[2023/11/26 13:19:32.671] Setup action:  Autofix not needed ... OK
[2023/11/26 13:19:32.674] Setup action:  Waiting to complete current operation ... Done
[2023/11/26 13:19:32.678] Setup action:  Adding security keys ...
[2023/11/26 13:19:32.722] Setup action:  Adding security keys ... OK
[2023/11/26 13:19:32.726] Setup action:  Preparing installation files ...
[2023/11/26 13:19:32.800] Setup action:  Preparing installation files ... OK
[2023/11/26 13:19:32.808] Setup action:  Partial update sw database ...
Ign:1 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ InRelease
Ign:2 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ Release
Ign:3 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ Packages
Ign:4 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ Translation-de_AT.UTF-8
Ign:5 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ Translation-de
Ign:6 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ Translation-en
Ign:7 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ Translation-de_AT
Holen:3 copy:/tmp/tmp.n4ZEAO39Un-q4appsetup2 tmp-setup-repo/ Packages [20 B]
Es wurden 20 B in 0 s geholt (631 B/s).
[2023/11/26 13:19:33.084] Setup action:  Partial update sw database ... Done
[2023/11/26 13:19:33.087] Setup action:  Testing installation ...
Die folgenden zusätzlichen Pakete werden installiert:
  libgail-common libgail18 libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf2.0-0
  libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libunique-1.0-0
Vorgeschlagene Pakete:
  gvfs
Die folgenden NEUEN Pakete werden installiert:
  libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libunique-1.0-0 q4os-updater
0 aktualisiert, 9 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Inst libgtk2.0-common (2.24.33-2 Debian:12.2/stable [all])
Inst libgtk2.0-0 (2.24.33-2 Debian:12.2/stable [amd64])
Inst libgail18 (2.24.33-2 Debian:12.2/stable [amd64])
Inst libgail-common (2.24.33-2 Debian:12.2/stable [amd64])
Inst libgdk-pixbuf-xlib-2.0-0 (2.40.2-2 Debian:12.2/stable [amd64])
Inst libgdk-pixbuf2.0-0 (2.40.2-2 Debian:12.2/stable [amd64])
Inst libgtk2.0-bin (2.24.33-2 Debian:12.2/stable [amd64])
Inst libunique-1.0-0 (1.1.6-6 q4os-5-0 repository:5.0/q4os-5-0-st [amd64])
Inst q4os-updater (4.1.1-a1 q4os-5-0 repository:5.0/q4os-5-0-st [amd64])
Conf libgtk2.0-common (2.24.33-2 Debian:12.2/stable [all])
Conf libgtk2.0-0 (2.24.33-2 Debian:12.2/stable [amd64])
Conf libgail18 (2.24.33-2 Debian:12.2/stable [amd64])
Conf libgail-common (2.24.33-2 Debian:12.2/stable [amd64])
Conf libgdk-pixbuf-xlib-2.0-0 (2.40.2-2 Debian:12.2/stable [amd64])
Conf libgdk-pixbuf2.0-0 (2.40.2-2 Debian:12.2/stable [amd64])
Conf libgtk2.0-bin (2.24.33-2 Debian:12.2/stable [amd64])
Conf libunique-1.0-0 (1.1.6-6 q4os-5-0 repository:5.0/q4os-5-0-st [amd64])
Conf q4os-updater (4.1.1-a1 q4os-5-0 repository:5.0/q4os-5-0-st [amd64])
[2023/11/26 13:19:41.295] Setup action:  Testing installation ... Done
[2023/11/26 13:19:41.305] Setup action:  Downloading packages ...
  gvfs
Es müssen noch 0 B von 5.123 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 28,1 MB Plattenplatz zusätzlich benutzt.
Herunterladen abgeschlossen; Nur-Herunterladen-Modus aktiv
[2023/11/26 13:19:42.238] Setup action:  Downloading packages ... Done
[2023/11/26 13:19:42.241] Setup action:  Copying system packages ...
  gvfs
Vormals nicht ausgewähltes Paket libgtk2.0-common wird gewählt.
Vorbereitung zum Entpacken von .../0-libgtk2.0-common_2.24.33-2_all.deb ...
Entpacken von libgtk2.0-common (2.24.33-2) ...
Vormals nicht ausgewähltes Paket libgtk2.0-0:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../1-libgtk2.0-0_2.24.33-2_amd64.deb ...
Entpacken von libgtk2.0-0:amd64 (2.24.33-2) ...
Vormals nicht ausgewähltes Paket libgail18:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../2-libgail18_2.24.33-2_amd64.deb ...
Entpacken von libgail18:amd64 (2.24.33-2) ...
Vormals nicht ausgewähltes Paket libgail-common:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../3-libgail-common_2.24.33-2_amd64.deb ...
Entpacken von libgail-common:amd64 (2.24.33-2) ...
Vormals nicht ausgewähltes Paket libgdk-pixbuf-xlib-2.0-0:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../4-libgdk-pixbuf-xlib-2.0-0_2.40.2-2_amd64.deb ...
Entpacken von libgdk-pixbuf-xlib-2.0-0:amd64 (2.40.2-2) ...
Vormals nicht ausgewähltes Paket libgdk-pixbuf2.0-0:amd64 wird gewählt.
Vorbereitung zum Entpacken von .../5-libgdk-pixbuf2.0-0_2.40.2-2_amd64.deb ...
Entpacken von libgdk-pixbuf2.0-0:amd64 (2.40.2-2) ...
Vormals nicht ausgewähltes Paket libgtk2.0-bin wird gewählt.
Vorbereitung zum Entpacken von .../6-libgtk2.0-bin_2.24.33-2_amd64.deb ...
Entpacken von libgtk2.0-bin (2.24.33-2) ...
Vormals nicht ausgewähltes Paket libunique-1.0-0 wird gewählt.
Vorbereitung zum Entpacken von .../7-libunique-1.0-0_1.1.6-6_amd64.deb ...
Entpacken von libunique-1.0-0 (1.1.6-6) ...
Vormals nicht ausgewähltes Paket q4os-updater wird gewählt.
Vorbereitung zum Entpacken von .../8-q4os-updater_4.1.1-a1_amd64.deb ...
Entpacken von q4os-updater (4.1.1-a1) ...
libgdk-pixbuf-xlib-2.0-0:amd64 (2.40.2-2) wird eingerichtet ...
libgdk-pixbuf2.0-0:amd64 (2.40.2-2) wird eingerichtet ...
libgtk2.0-common (2.24.33-2) wird eingerichtet ...
libgtk2.0-0:amd64 (2.24.33-2) wird eingerichtet ...
libunique-1.0-0 (1.1.6-6) wird eingerichtet ...
libgail18:amd64 (2.24.33-2) wird eingerichtet ...
libgtk2.0-bin (2.24.33-2) wird eingerichtet ...
q4os-updater (4.1.1-a1) wird eingerichtet ...
No previous version, so seems to be a new installation ...
replacing [line #1] APT::Periodic::Update-Package-Lists << 1
replacing [line #2] APT::Periodic::Unattended-Upgrade << 0
libgail-common:amd64 (2.24.33-2) wird eingerichtet ...
Trigger für man-db (2.11.2-2) werden verarbeitet ...
Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ...
Trigger für libc-bin (2.36-9+deb12u3) werden verarbeitet ...
[2023/11/26 13:20:03.284] Setup action:  Copying system packages ... Done
[2023/11/26 13:20:03.287] Setup action:  Postinstall operations ...
[2023/11/26 13:20:03.309] Setup action:  Postinstall operations ... Done
[2023/11/26 13:20:03.312] Setup action:  Checking installation ...
[2023/11/26 13:20:03.364] Setup action:  Checking installation ... OK
[2023/11/26 13:20:03.404] Setup action:  Registering application ... OK
[2023/11/26 13:20:03.408] Setup action:  Finishing installation ...
[2023/11/26 13:20:03.411] Installation successfully completed :-)
#14 2023-11-26 13:24
Now try to use Q4OS installers in gui mode.
#15 2023-11-26 13:28
HerrAbisZ
unfortunately no success yet
Sorry - how to do this : in GUI Mode ??
#16 2023-11-26 13:43
Just run some of installers from software center.
#17 2023-11-26 13:45
HerrAbisZ
#18 2023-11-26 14:32
It looks more like a hardware related issue, as we are not able to reproduce it. Installers are working fine here. You could report a hardware related bug at our bug tracker https://sourceforge.net/p/q4os/tickets/
#19 2023-11-26 14:39
HerrAbisZ
OK - Many Thanks for your Time
#20 2023-11-26 14:43
We have got it. What is the output now ?
$ sudo apt update
$ sudo apt dist-upgrade
#21 2023-11-26 14:48
HerrAbisZ
OK:1 http://deb.debian.org/debian bookworm InRelease
Holen:2 http://security.debian.org bookworm-security InRelease [48,0 kB]
Es wurden 48,0 kB in 1 s geholt (36,9 kB/s).
dieserpc@dieserpc-aspire5715z:~$ sudo apt dist-upgrade
Paketaktualisierung (Upgrade) wird berechnet… Fertig
#22 2023-11-26 15:06
Ok, at least the package system has been fixed. We have no idea why installers fail, If you would generate and provide the qreport.tar.gz file once again it may help.
#23 2023-11-26 15:58
HerrAbisZ
Here
I am now doing two new installations and partitioning first with GParted - also the SWAP partition. And then 5.3 x64 tde.r1
#24 2023-11-26 17:46
HerrAbisZ
I have now reinstalled twice. Once I reinstalled the partitions with SWAP - then the file system got corrupted again. After the repair I saw that I had 5 primary partitions under MBR ??. Then I realized why the file system was broken for the time being, because 5 primary partitions were not supposed to work. But then it did.
Then I extended windows and let the KDE partition program set up the partition on the side. No file system was broken (only 4 primary partitions), but the GUI installation still didn't work. New install after win7 then ran a CHKDSK, so the KDE partition program doesn't work properly.
Now I am installing Q4OS 5.3 Trinity. Let's see what comes out of it
#25 2023-11-26 18:31
HerrAbisZ
IT WORK`S !! But streaming with tv.magenta.at is not good! With Aquarium better
