hello,
after a fresh install of Q4os everything works great even the crappy wifi dongle...but no sound on the hdmi monitor. with the ubuntu image for the pi one sound and video were working great but the wifi dongle is not. as I prefer Q4os I am requesting help to solve it.
I have the speaker icon and I have tested all possible configurations from fresh installs, with no success, any help is very much apreciated
Please first try to follow recommendations here https://www.q4os.org/dqa011.html#install.3 and post results here.
Do you use 'Q4OS ARM port' https://www.q4os.org/dqa012.html or 'Raspberry Pi port' https://www.q4os.org/dqa010.html ?
hi
I did the instqllqtion in 2 steps
1st---Iinstallqtion of debian for the orange pi one server version downloaded from https://www.armbian.com/orange-pi-one/
2nd---I used these lines :
$ wget q4os.org/downloads/q4os-setup.sh
$ su
# sh q4os-setup.sh
and voila I got Q4OS fully installed
after typping artsplay /opt/trinity/share/sounds/KDE_Startup.wav
text below appears
root@orangepione:/home/strongarm/Desktop# artsplay /opt/trinity/share/sounds/KDE_Startup.wav
bash: artsplay: command not found
then :
root@orangepione:/home/strongarm/Desktop# artsshell terminate
bash: artsshell: command not found
i do not know if it is related but I click on log out and then turn off the orange pi reboots strange behavior
just in case :
root@orangepione:/home/strongarm/Desktop# uname -r
3.4.113-sun8i
root@orangepione:/home/strongarm/Desktop# cat /etc/issue
Debian GNU/Linux 8 \n \l
root@orangepione:/home/strongarm/Desktop# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.7 (jessie)
Release: 8.7
Codename: jessie
Thanks for your help
You have incorrectly tried to run 'artsplay' as root. Please run commands as a user, if marked by '$', and as root if marked by '#'. So, try to follow steps in https://www.q4os.org/dqa011.html#install.3 once more, and paste output here to analyze.
Ok,
as I forgot the cable at the office I had to wait until today to test...
strongarm@orangepione:~/Desktop$ artsplay /opt/trinity/share/sounds/KDE_Startup.wav
no sound at all, no error message... nothing...
and then :
strongarm@orangepione:~/Desktop$ artsshell terminate
sound server terminated
strongarm@orangepione:~/Desktop$ aplay /opt/trinity/share/sounds/KDE_Startup.wav
Playing WAVE '/opt/trinity/share/sounds/KDE_Startup.wav' : Signed 16 bit Little Endian, Rate 22050 Hz, Mono
It says Playing wave, but there is no sound even with loud volume...
Well, did you check mixer levels thoroughly as described in https://www.q4os.org/dqa011.html#install.3 ?
If so, try to run in terminal:
$ aplay -l
$ aplay -v /opt/trinity/share/sounds/KDE_Startup.wav
$ amixer
and post output here to analyze.
hello,
yes I triple checked mixers levels.
strongarm@orangepione:~/Desktop$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: audiocodec [audiocodec], device 0: SUNXI-CODEC sndcodec-0 []
Subdevices: 0/1
Subdevice #0: subdevice #0
card 1: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 []
Subdevices: 1/1
strongarm@orangepione:~/Desktop$ aplay -v /opt/trinity/share/sounds/KDE_Startup.wav
aplay: main:722: audio open error: Device or resource busy
strongarm@orangepione:~/Desktop$ amixer
Simple mixer control 'Lineout volume control',0
Capabilities: volume volume-joined
Playback channels: Mono
Capture channels: Mono
Limits: 0 - 31
Mono: 24 [77%]
Simple mixer control 'ADC input gain ctrl',0
Limits: 0 - 7
Mono: 3 [43%]
Simple mixer control 'Audio adda drc',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'Audio adda loop',0
Simple mixer control 'Audio linein in',0
Simple mixer control 'Audio lineout',0
Mono: Playback [on]
Simple mixer control 'LINEIN_G boost stage output mixer control',0
Limits: 0 - 7
Mono: 3 [43%]
Simple mixer control 'MIC1 boost AMP gain control',0
Limits: 0 - 7
Mono: 5 [71%]
Simple mixer control 'MIC1_G boost stage output mixer control',0
Limits: 0 - 7
Mono: 3 [43%]
Simple mixer control 'MIC2 boost AMP gain control',0
Limits: 0 - 7
Mono: 4 [57%]
Simple mixer control 'MIC2_G boost stage output mixer control',0
Limits: 0 - 7
Mono: 3 [43%]
Simple mixer control 'audio capture mode',0
Capabilities: enum
Items: 'main mic' 'mic1_2' 'linein'
Item0: 'main mic'
Please try to go to the mixer in systemtray once more. In top right corner, you should be able to switch between two sound cards. Please set mixer levels for both. If the sound will not work, run 'alsamixer' in terminal and try to tune mixer levels for both cards as well.
Card: audiocodec F1: Help │
│ Chip: F2: System information │
│ View: F3:[Playback] F4: Capture F5: All F6: Select sound card │
│ Item: MIC1 boost AMP gain control Esc: Exit │
│ │MM│ │MM│ │MM│ │OO│ │
│ 100 100 100 100 │
│ Lineout ADC inpu Audio ad Audio ad Audio li Audio li LINEIN_G<MIC1 boo> │
│ │all levels to the max, tv screen also to the max and...no sound
EDIT: code blocks edited by q4osteam
MM = mute, it's difficult to see from the post but if the MM is under Master or speaker or headphones (whichever you use) then you will hear no sound. I would unmute everything and see if that works.
And a tip, enclose your output above in code blocks and it will appear more readable put [ code ] at the beginning and [ /code ] at the end. Remove the spaces they are just to allow to display the command in the post.
┌───────────────────────────── AlsaMixer v1.0.28 ──────────────────────────────┐
│ Card: audiocodec F1: Help │
│ View: F3: Playback F4:[Capture] F5: All F6: Select sound card │
│ Item: MIC2_G boost stage output mixer control Esc: Exit │
│ 100 100 100 100 100 100 100 │
│ Lineout vo ADC input LINEIN_G b MIC1 boost MIC1_G boo MIC2 boost<MIC2_G boo>│
└──────────────────────────────────────────────────────────────────────────────┘┌───────────────────────────── AlsaMixer v1.0.28 ──────────────────────────────┐
│ Card: sndhdmi F1: Help │
│ Item: hdmi audio format Function [pcm] Esc: Exit │
│ pcm │
│ <hdmi audio format Function> │
I have the OPi connected to the tv screen by HDMI.
Thanks for the tips..I have put all the volume up at 100% even the one of the tv screen I am using...and still no sound... Thanks for any help
If you remove the spaces from the code tags your output will look like this below, Much easier to read.
┌─────────────────────────────────── AlsaMixer v1.1.3 ───────────────────────────────────┐
│ Card: HDA Intel PCH F1: Help │
│ Chip: Realtek ALC3234 F2: System information │
│ Item: Master [dB gain: -27.75] Esc: Exit │
│ ├──┤ ├──┤ ├──┤ └──┘ ├──┤ └──┘ ┌──┐ ├──┤ Enabled │
│ │OO│ │OO│ │MM│ │OO│ │OO│ │OO│ │
│ 29 100<>100 0<>0 0<>0 100<>100 100<>100 0<>0 │
│ < Master >Headphon Headphon Headphon Speaker PCM S/PDIF Beep Auto-Mut │Last edited by Dai_trying (2017-03-31 22:23)
People from UK make the classiest cars and screen captures ever
@Pieater
Alsa and TDE configuration looks well. Does audio work within plain 'Armbian' https://www.armbian.com/orange-pi-one/ setup ?
@Pieater
Please run another commands in terminal:
$ aplay -v -D plughw:0,0 /opt/trinity/share/sounds/KDE_Startup.wav
$ aplay -v -D plughw:1,0 /opt/trinity/share/sounds/KDE_Startup.wav
and post results here to analyze.
with armbia the sound does not work, how ever with ubuntu the sound of the OPi works...with armbian the wifi dongle works but with ubuntu in spite of the 10+ methods tried to install the drivers, there was no way to make the wifi dongle work.
strongarm@orangepione:~/Desktop$ aplay -v -D plughw:0,0 /opt/trinity/share/sounds/KDE_Startup.wav
Plug PCM: Hardware PCM card 0 'audiocodec' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : S16_LE
subformat : STD
channels : 1
rate : 22050
exact rate : 22050 (22050/1)
msbits : 16
buffer_size : 11024
period_size : 2756
period_time : 124988
tstamp_mode : NONE
period_step : 1
avail_min : 2756
period_event : 0
start_threshold : 11024
stop_threshold : 11024
silence_threshold: 0
silence_size : 0
boundary : 1444937728
appl_ptr : 0
hw_ptr : 0
strongarm@orangepione:~/Desktop$ aplay -v -D plughw:1,0 /opt/trinity/share/sounds/KDE_Startup.wav
Plug PCM: Hardware PCM card 1 'sndhdmi' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
format : S16_LE
subformat : STD
channels : 1
rate : 22050
msbits : 16
buffer_size : 11024
period_size : 2756
tstamp_mode : NONE
period_step : 1
avail_min : 2756
period_event : 0
silence_size : 0
appl_ptr : 0
hw_ptr : 0
BIG SURPRISE!!! NOW there was sound!!!
BIG SURP
Just aftre the succesfully sound played, I went to youtube and there was no sound on youtube
Sorry to keep asking for help...but still no sound...I can just hear one sound that is played by:
after that, no sound at all in any application, is there a command line instruction so the setup that is able to play sound keeps working AFTER the command aplay -v -D plughw:1,0 /opt/trinity/share/sounds/KDE_Startup.wav ?
Thanks a lot for helping me
Please try to create file '~/.asoundrc' with contents:
pcm.!default {
type plug
slave {
pcm "hw:1,0"
ctl.!default {
type hw
card 1
}reboot your OPi and check the audio in terminal:
Hello operations were done, no sound, and no error message...
