I tried to play a store-purchased dvd movie and it will not work. I'm guessing I need to install something along the lines of a lib file to get this to work.
I tried 6 factory dvd movies...no luck.
I tested the same 6 dvds on XP, running a portable version of VLC...no problems at all.
Thanks in advance for any help.
MC
Q4OS running Xfce
libdvdcss2 is normally the issue. There are a couple of sources.
https://download.videolan.org/debian/stable/ will give you access to that file in various versions. I've attached the 64bit deb which installs through gdebi or dpkg -i without any dependency issues
The other option is to get it from the unofficial Debian Multimedia repo at http://www.deb-multimedia.org/
You'll need to add the repo info as described, and apt-get update will update a number of multimedia based files on your system.
In addition, the most easy way is to install 'Multimedia Codecs' from Q4OS Software Centre. It will pull 'libdvdcss2' as well.
Thanks bin!
I downloaded and installed the .deb package...problem solved!
Q4OS running Xfce
@Q4OS Team ~ Thanks to you, too! (Our post times are exactly the same)
Q4OS running Xfce
I wasn't sure whether this pulls in the dreaded Flash Player - though it is of course the much simpler solution
Just a thought - if it doesn't cause too much pain, would it be possible to pull Flash Player (flashplugin-nonfree) out and make it a single separate installation?
No, 'Multimedia Codecs' doesn't pull flash at all, it adds the 'deb-multimedia' repository and installs following core packages:
libdvdcss2, w64codecs:amd64 | w32codecs:i386, va-driver-all, libav-tools, twolame, libaacs0, libfaad2, libmp4v2-2, libfaac0, libmp3lame0, libdvdnav4, libdvdread4, libbluray1, libcrystalhd3, libopencore-amrwb0, libopencore-amrnb0
The only Firefox installer pulls the flash, and it's deactivated by default, so user has to manually enable it prior to using it. As discussed in another thread, there will be an option in Q4OS Firefox installer in the future to select, whether to include flash, or not.
Excellent - thanks for clearing that up.
Where do I find the file? And how do I install it? Synaptic Package Manager didn't show it.
q4osteam wrote:In addition, the most easy way is to install 'Multimedia Codecs' from Q4OS Software Centre. It will pull 'libdvdcss2' as well.
You do not have to install it from Synaptic Package Manager.
You have to to install 'Multimedia Codecs' from Q4OS Software Centre.
I appreciate the response, however, I am on Q4OS.org and do not see a software center.
Look in the menu on your computer.
The exact path depends on whether you are using TDE or Plasma - but you'll find it in there.
Q4OS welcome screen > Install applications
Thank you, it works now!
