#1 2016-08-31 06:55
BSpinoza
recent Gnumeric
It would be nice to have an update of Gnumeric. The Q4OS-Version is 1.12.18 (from September 2014) but the recent Version (gnumeric.org) is 1.12.32 (August 2016).
#2 2016-08-31 08:17
Re: recent Gnumeric
Q4OS Orion is based on the stable version of Debian and therefore lacks the latest software updates, I have checked the testing version and that has 1.12.31-1 which is a lot closer to what you want. If you want the latest software versions you could try using Q4OS Scorpion which is the testing version of Q4OS, but be warned the testing version is not recommended for production use and may have a few quirks (it is a testing release after all).
Sometimes newer software becomes available through the backports repository, but I've had a quick look and I don't see it available at the moment.
Hope this helps.
Dai
#3 2016-08-31 19:07
orion
Re: recent Gnumeric
Hello, about q4os scorpion - that is based on the branch testing (not stable)  - is this version also rolling? can be upgraded indefinitely to the  most recently version as other distros? I want to know because I am interested in installing this in another netbook and to prove .  The advantage of "testing is that has software more recent." as I understand (if I am not wrong) . On stability I am not worry because I want to only experiment and to use in  home . I know stable is more recomended for more stability.  But the center point of my question is,  if this (scorpion [testing branch] can be considered rolling and if this version will be produced continously by the Team in the future. (excuse my grammar sintax _ i’am not english person.)
#4 2016-08-31 19:19
Re: recent Gnumeric
orion wrote:
... can be upgraded indefinitely to the  most recently version as other distros?
Yes, it can. Keep in mind it's a testing branch, so you could meet some unexpected issues.
#5 2016-08-31 23:15
orion
Re: recent Gnumeric
Thanks for the information,  but where i can find de 2.1 scorpion installer iso image? in the main page i can see only the stable version.
#6 2016-09-01 02:41
olzeke51
Re: recent Gnumeric
I found this link -- http://www.q4os.org/downloads2.html - where you could d/l
on the news page -- (http://www.q4os.org/blog.html) had to scroll down to where it was mentioned.
HTH - Gary
The journey is . . . the reward.
#7 2016-09-01 12:47
orion
Re: recent Gnumeric
Yes can download the LIVE iso image, q4os 2.0.1 scorpion -  but this is not installable. Only to test in live mode. I am interested in the installation iso image. Anyway thanks.
#8 2016-09-02 08:51
Re: recent Gnumeric
You can install from the live-cd, in fact it's what I use all the time, I never use the installation only iso. smile
#9 2016-09-03 14:59
orion
Re: recent Gnumeric
Yes  actually realized that the installer is in the corner bottom left. I Started it, but see  [in scorpion 2.1] the  system install is Gparted type, a little more complicated than the Orion 1.6.[ more intuitive] . Here I see a point something difficult for initiated in Linux. Orion is a much more easy to work.(installing). Even for who never had experience with linux. I hope that this detail is taken in consideration. One of the things that blocks on linux initiates to adapt this system is input at the time of installation. You may feel intimidated and abandon the attempt  and to return to Windows. Or could be that this q4os more oriented to Linux users with some experience (not beginners). But nothing, if it provides easily understandable documentation would be a solution. Best regards
#10 2016-09-03 16:33
Re: recent Gnumeric
I have been using Linux for quite some time now so I probably see things as being easier than they are to a noob, but I wouldn’t recommend a testing distro to any one new to Linux, I would think an unstable system would be more likely to put them off than anything else.
And documentation for a testing distro would be almost impossible to keep up to date due to the constant changes, it is for "testing" after all. smile
#11 2016-09-03 16:50
Re: recent Gnumeric
@orion
The Scorpion installer uses almost the same partitioning software as Orion. The difference you mention probably sources from different existing disk partitions on the target system.
There is very nice live installation guide available http://dsbnet.tk/pages/install_q4os.php , thanks to Dai_trying.
#12 2016-11-05 08:08
Moko
Re: recent Gnumeric
What is the live-cd?
#13 2016-11-05 10:23
Re: recent Gnumeric
Live media allows users to get a quick Q4OS experience, or test it on a real hardware without installation. If satisfied, an optional installation of Q4OS is available.
http://www.q4os.org/downloads1.html
