#1 2016-07-03 22:02
cpcnw
Raspberry PI Specific Forum Subsection
Hi All,
Just got Q4OS installed on my Raspi3 and so far its going very well. The only minor tick is that following a reboot the onboard wifi does not auto connect [I have to prompt it] - it's no big deal though.
I was thinking that Q4OS should be one of the distros availbe to Noobs users https://www.raspberrypi.org/blog/introducing-noobs/
I did a forum search here and I think there where 14 hits containing the word 'raspberry'
I think it would be a good idea to have a Raspbery Pi specific subsection for the forum, then try and get some exposure with the Raspberry Pi folks!
I am heading over to the Raspi forums now just to tell people that there is an image available and that its working nicely!
yikes)
#2 2016-07-03 22:57
Re: Raspberry PI Specific Forum Subsection
Interesting ideas, we will take a look.
cpcnw wrote:
I am heading over to the Raspi forums now just to tell people that there is an image available ...
Thanks for that, we would definitely need a publicity.
#3 2016-07-04 09:08
cpcnw
Hi - maybe this should be the "Raspberry Pi Thread" ?
Anyway, without installing Synaptic [and all of the deps]
What are the minimum packages I need to get printing working with cups on the Pi?
Thanks!
ps  I did a 'sudo apt-cache search cups' and got a huge list!!!
#4 2016-07-04 09:11
These common instructions from Q4OS documentation should be correct for RPI as well:
http://www.q4os.org/dqa007.html#printer
