#1 2026-10-22 21:41
peixe80
PMP (MP3 player) not recognized by TDE or Dolphin
I have a PMP or MP3 player (https://www.behance.net/gallery/57823177/Iriver-T70) that's not recognized by TDE or Dolphin. However, it's detected by fdisk:
# fdisk -l
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdb1         128 33089407 33089280 31,6G  b W95 FAT32
How can I fix this?
I've seen an old issue about the same problem, but it hasn't been solved:
https://www.q4os.org/forum/viewtopic.php?id=3420
Thank you!
#2 2026-10-23 08:33
Re: PMP (MP3 player) not recognized by TDE or Dolphin
A few tips by AI what could be relevant. Try them and post back the progress.
1. Check if you can mount it manually
Open a terminal and try to mount the player to a temporary directory. This will help confirm if the system can read the data:
$ sudo mkdir /media/mp3player
$ sudo mount -t vfat /dev/sdb1 /media/mp3player
If this works, you should be able to browse your files inside /media/mp3player using Dolphin.
2. Verify Trinity Media Manager Settings
TDE relies on its own hardware manager to auto-mount drives.
1. Open the Control Center (TDE Control Center).
2. Navigate to Peripherals -> Storage Media.
3. Check the Advanced tab and ensure that automounting is enabled for removable drives.
4. Try adding a specific rule for your device if it's listed under unmounted media.
3. Check for missing MTP/USBMASS helper packages
Some PMPs require specific runtime libraries to talk to modern file managers. Ensure you have the necessary packages installed:
$ sudo apt update
$ sudo apt install jmtpfs mtp-tools kio-audiocd
(After installing, replug the device and see if TDE prompts a pop-up).
4. Create a permanent Udev rule (If TDE still ignores it)
If the desktop environment refuses to auto-detect it, you can force the system to mount it automatically whenever it's plugged in.
First, get the UUID of the device:
$ sudo blkid /dev/sdb1
Then, add a line to your /etc/fstab (replace YOUR-UUID-HERE with the actual output):
text
UUID=YOUR-UUID-HERE /media/mp3player vfat user,rw,umask=000,nofail,x-systemd.automount 0 0
Let us know if the manual mount works or if you encounter any specific error messages in the terminal!
#3 2026-10-23 17:11
peixe80
Yes, that works.
The automounting option was disabled. I've enabled it, then I reboot the system, but nothing's changed.
$ sudo apt update
Those packages wasn't installed. I've installed them, then I reboot the system, but nothing's changed.
text
I've run "sudo blkid /dev/sdb1" and I've added this line at the end of "/etc/fstab":
UUID=EC95-4FBB  /media/user/mp3player     vfat    user,rw,umask=200,nofail,x-systemd.automount    0 0
Then I reboot the system and now the MP3 player is automounted when I plug it. However, I can't find a way to graphically umount it before I unplug it, and the command "sudo umount /dev/sdb1" doesn't work. In Dolphin, no device appears in Storage Media.
Thanks.
#4 2026-10-28 00:04
peixe80
The same problem happens with all MP3 players. Is it possible to activate the TDE plug&play system for these devices?
