#1 2026-09-15 11:01
Multi-boot issue after installing Aquarius
Hello,
after installing Aquarius on an MBR-system on sda4 besides Windows (on sda1) and Q4OS-4 "Gemini" (on sda3):
In the boot-menu there are only the entrie for Q4os - os-prober states:
Found Debian GNU/Linux 11 (bullseye) on /dev/sda3
But what's missing/expected here would also be:
/dev/sda1:Windows 7:Windows:chain
Please, how can i get back Windows on my system??
Thank you!
#2 2026-09-15 11:14
Re: Multi-boot issue after installing Aquarius
Please run:
$ sudo os-prober
and post the output
#3 2026-09-15 11:23
here it is:
[~\> sudo os-prober
[sudo] Passwort für me:
/dev/sda3:Debian GNU/Linux 11 (bullseye):Debian:linux
Weird enough: good (now old-old-old) Gemini still does find Windows:
[:~\> sudo os-prober
/dev/sda4:Debian GNU/Linux 12 (bookworm):Debian:linux
But for the moment (until the issue is claryfied) i won't run update-grub on Gemini...
#4 2026-09-15 11:38
Would you check, whether there is another setting:
$ grep -R "GRUB_DISABLE_OS_PROBER" /etc/default/grub /etc/default/grub.d/ 2>/dev/null
#5 2026-09-15 12:30
No, only the disabling of the "DISABLE_OS_PROBER":
# grep -R "GRUB_DISABLE_OS_PROBER" /etc/default/grub /etc/default/grub.d/ 2>/dev/null
/etc/default/grub:GRUB_DISABLE_OS_PROBER=false
/etc/default/grub.d is a directory which only contains an "empty" init-select.cfg file.
#6 2026-09-15 14:17
Two things decide this, please run on Aquarius:
$ [ -d /sys/firmware/efi ] && echo "UEFI boot" || echo "BIOS boot"
$ sudo os-prober
$ sudo grep -E "os-prober|50mounted-tests|20microsoft" /var/log/syslog | tail -30
$ sudo grub-mount /dev/sda1 /mnt && ls /mnt | head && sudo umount /mnt
Background: os-prober only reports Windows on a system booted in legacy BIOS mode -
its Windows detector exits immediately when /sys/firmware/efi exists, while Linux
systems are still listed. That alone produces exactly your output. If Aquarius
booted in UEFI mode and Gemini in BIOS mode, that is the answer, and a BIOS Windows
cannot be chainloaded from an EFI GRUB anyway - Windows then has to be started from
the firmware boot menu, or Q4OS's bootloader reinstalled in BIOS mode.
Otherwise the second possibility is that GRUB cannot read the NTFS partition:
os-prober mounts partitions only with grub-mount, and skips a partition silently if
that fails. The grub-mount line above shows it. In that case, mounting the Windows
partition before updating the menu works around it:
$ sudo mkdir -p /mnt/win && sudo mount -o ro /dev/sda1 /mnt/win
$ sudo update-grub
$ sudo umount /mnt/win
Your Gemini install is unaffected either way; running update-grub there is safe.
#7 2026-09-15 16:15
It's only Lagacy/BIOS here on my pc. The output of the first block:
me@flex:~\> [ -d /sys/firmware/efi ] && echo "UEFI boot" || echo "BIOS boot"
BIOS boot
me@flex:~\> sudo os-prober
me@flex:~\> sudo grep -E "os-prober|50mounted-tests|20microsoft" /var/log/syslog | tail -30
2026-09-15T17:01:30.434456+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
2026-09-15T17:01:30.448226+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
2026-09-15T17:01:30.461908+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
2026-09-15T17:01:30.475361+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
2026-09-15T17:01:30.488883+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
2026-09-15T17:01:30.497188+02:00 flex 20microsoft: debug: /dev/sda8 is a NTFS partition
2026-09-15T17:01:30.681517+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
2026-09-15T17:01:30.690619+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
2026-09-15T17:01:30.696828+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
2026-09-15T17:01:30.702876+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
2026-09-15T17:01:30.708620+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
2026-09-15T17:01:30.717956+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
2026-09-15T17:01:30.759998+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
2026-09-15T17:01:30.763762+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
2026-09-15T17:01:30.780375+02:00 flex os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda9
2026-09-15T17:01:31.069083+02:00 flex 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
2026-09-15T17:01:31.071423+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
2026-09-15T17:01:31.077153+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
2026-09-15T17:01:31.082767+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
2026-09-15T17:01:31.088325+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
2026-09-15T17:01:31.093991+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
2026-09-15T17:01:31.097497+02:00 flex 20microsoft: debug: /dev/sda9 is a NTFS partition
2026-09-15T17:01:31.226322+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
2026-09-15T17:01:31.231098+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
2026-09-15T17:01:31.234279+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
2026-09-15T17:01:31.237560+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
2026-09-15T17:01:31.240582+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
2026-09-15T17:01:31.245326+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
2026-09-15T17:01:31.268202+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
2026-09-15T17:01:31.271715+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
The second solution then seems to work::
me@flex:~\> sudo mkdir -p /mnt/win && sudo mount -o ro /dev/sda1 /mnt/win
me@flex:~\> sudo update-grub
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-6.1.0-53-amd64
Found initrd image: /boot/initrd.img-6.1.0-53-amd64
Found linux image: /boot/vmlinuz-6.1.0-44-amd64
Found initrd image: /boot/initrd.img-6.1.0-44-amd64
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
/usr/sbin/grub-probe: error: unknown filesystem.
Found Windows 7 on /dev/sda1
done
me@flex:~\> sudo umount /mnt/win
me@flex:~\>
Please let me reboot...
Added later 30 min 16 s:
Many thanks for your support @q4osteam!
But it fails. The entry for Win7 in the boot menu is actually present, but when selecting it:
Settin partition type to 0x83
error: invalid signature
any key to continue
if i edit the entry, i can see the cause: the entry is far too less (as i saw it on a working system), even the partition uuid is missing!
Setparms 'Windows7 (on /dev/sda1)'
        insmod part_msdos
        parttool ${root} hidden-
        chainloader +1
This is disappointing, two steps at least back from Gemini tbh.
Should i try  sudo /media/me/<uuid of beloved Gemini partition>/usr/bin/os-prober ?
Edit: tried it - no success neither, only Gemini is found...
#8 2026-09-15 18:01
Nothing is wrong with your machine or Windows installation. os-prober detects Windows correctly, but grub-probe cannot identify the filesystem on sda1, so the generated entry lacks the required "set root" line. "chainloader +1" then targets the wrong partition, causing the "invalid signature" error. The same happens with sda3, so the Gemini entry is affected too.
This is a Debian bug, not a Q4OS one, reported in 2022 and apparently unchanged since 2023:
https://bugs.debian.org/1013203
If you want, we can investigate why GRUB cannot read those partitions.
#9 2026-09-15 21:10
Oh man, a big 'Thank you!' once again!!
I already was sure, that it would be a Debian bug - quite apparently - unfortunately Q4 is affected in this case.
And i'm wondering, how such a grave bug can persist in Debian - for years! (So frustrating that so many things go the total wrong direction these days...)
And instead that somebody would care, in contrary, the GRUB_DISABLE_OS_PROBER is activated by default to hide other OS's!
Another annoyance btw i observed: firstly i installed and started Synaptic to add some software to the installation, and it modified the kernel to a new version (.44 -> .53) - in the background - even without any explanation or information.
MANY THANKS again @team for your kind offer: only if you've really got nothing better to do, and if you are interested too wink
Of course i offer to test/verify the solutions you find.
I for my part  will boot back into Gemini now, try to restore the grub from there, and will show Debian 12+ my back for a while...
SO frustrating...
Added later 3 h 34 min 49 s:
Now, this is really sad: back in Gemini i issued the sudo update-grub here again, an the output was quite promising:
Found Debian GNU/Linux 12 on /dev/sda4
done
i even controlled the generated  /boot/grub/grub.cfg: just perfect!
But: after reboot the bootmenu hadn't changed at all ! Aquarius was still the leading entry and the Win7-entry as poor as before.
That means: the bootmenu created with Debian12 had remained.
However, i was prepared and edited/completed the entry for Win7 (very painful with a german keyboard)... and was finally able to boot once into Windows.
So: Why the he__ the update-grub in Gemini does not take effect? Maybe because it's an older version of grub?
Unfortunately i know few about GRUB and the booting process (MBR, IPL and partition table) - hopefully someone can help me, to get control of my booting-situation here again...
Many thanks in advance!
Added later 3 h 43 min 29 s:
it seems that i do have to re-install grub on Gemini: https://askubuntu.com/questions/1069735 … -no-effect
#10 2026-09-16 10:28
FlexQ4 wrote:
So: Why the he__ the update-grub in Gemini does not take effect? ... it seems that i do have to re-install grub on Gemini ...
Yes, you need to reinstall Grub prior update:
$ sudo grub-install
$ sudo update-grub
#11 2026-09-16 10:55
update-grub does not "update the boot menu" in the firmware/MBR sense, It mainly does the following:
/etc/grub.d/*   --> grub-mkconfig  --> /boot/grub/grub.cfg
However, it does not necessarily reinstall the bootloader in the MBR; grub-install is the tool that actually installs GRUB to the disk. The official documentation, for example, provides: grub-install /dev/sda for a bios installation on the first disk.
So, it’s possible to have:
Gemini :   /boot/grub/grub.cfg (new)
but
MBR : old GRUB  (still in use)
and end up with the situation where update-grub appears to work, but after rebooting, the menu has not changed.
(exactly what Q4OS Team described: "That alone produces exactly your output. If Aquarius booted in UEFI mode and Gemini in BIOS mode, that is the answer, and a BIOS Windows cannot be chainloaded from an EFI GRUB anyway - Windows then has to be started from the firmware boot menu, or Q4OS's bootloader reinstalled in BIOS mode.")
I would start by determining what actually boots the system:
sudo grub-install --version
and then:
findmnt /boot
findmnt /boot/efi
because you need to know whether the machine uses BIOS+MBR or UEFI+GPT
If it is BIOS/MBR -->  reinstall GRUB on the correct disk; if /dev/sda is the boot disk and gemini has the correct /boot:
sudo grub-install /dev/sda
sudo update-grub
*important: /dev/sda and not /dev/sda1, for a bios GRUB install, you install to the disk, not the partition.
But, I think it's the best solution: for  windows 7 on an old machine, you can even completely bypass os-prober:
If   /dev/sda1 = Windows partition
you don't need os-prober to understand its filesystem to chainload the boot sector, just create a manual entry: sudo nano /etc/grub.d/40_custom
with:
menuentry "Windows 7" {
    insmod part_msdos
    insmod ntfs
    set root=(hd0,1)
    chainloader +1
and then run again sudo update-grub
--> it will create an entry independent of (unreliable) result from os-prober.
#12 2026-09-16 13:22
MANY thanks @seb3773 too,
that is exactly what i did and what gave me back access to my OSs: in Gemini/Bullseye issued:
$ sudo grub-install /dev/sda
$ sudo update-grub
Since - beside Win7 and Gemini - there is still a (bootable) Win-XP partition on my system, i have to rely on a MBR/legacy configuration.
So now, two days later, i''ve got a nice working quad-boot MBR situation here as planned wink - BUT:
i am extremely disappointed about the negligent manner, how Debian seems to let phase-out support for older OS's and boot-configurations.
How would have been it, if Gemini wouldn't still reside here? Tinker with 40_custom files in /etc/grub.d/  to get access to Windows back?
Hiding (more pricisely: making inaccessible Win7 in my case, see above: https://bugs.debian.org/1013203 ) is a manner that i knew only from MS so far.
Debian12 did a first 'update-grub' during installation, then a second after an unrequested kernel update (while installing few apps via Synaptic) - but for a convenient boot-menu i have to tweak the /etc/default/grub, 'update-grub' a third time (to regain access to Gemini), then boot back into it - to install/update (an older) grub a fourth time...
Puhh, i'm done for the moment. Seems that Gemini will still remain my daily driver for a wihile!
Edit: forgot to thank you too @q4os-team explicitely! wink
