#1 Today 11:01
Multi-boot issue after installing Aquarius
Hello,
after installing Aquarius on an MBR-system on sda4 besides Windows (on sda1) and Q4OS-4 "Gemini" (on sda3):
In the boot-menu there are only the entrie for Q4os - os-prober states:
Found Debian GNU/Linux 11 (bullseye) on /dev/sda3
But what's missing/expected here would also be:
/dev/sda1:Windows 7:Windows:chain
Please, how can i get back Windows on my system??
Thank you!
#2 Today 11:14
Re: Multi-boot issue after installing Aquarius
Please run:
$ sudo os-prober
and post the output
#3 Today 11:23
here it is:
[~\> sudo os-prober
[sudo] Passwort für me:
/dev/sda3:Debian GNU/Linux 11 (bullseye):Debian:linux
Weird enough: good (now old-old-old) Gemini still does find Windows:
[:~\> sudo os-prober
/dev/sda4:Debian GNU/Linux 12 (bookworm):Debian:linux
But for the moment (until the issue is claryfied) i won't run update-grub on Gemini...
#4 Today 11:38
Would you check, whether there is another setting:
$ grep -R "GRUB_DISABLE_OS_PROBER" /etc/default/grub /etc/default/grub.d/ 2>/dev/null
#5 Today 12:30
No, only the disabling of the "DISABLE_OS_PROBER":
# grep -R "GRUB_DISABLE_OS_PROBER" /etc/default/grub /etc/default/grub.d/ 2>/dev/null
/etc/default/grub:GRUB_DISABLE_OS_PROBER=false
/etc/default/grub.d is a directory which only contains an "empty" init-select.cfg file.
#6 Today 14:17
Two things decide this, please run on Aquarius:
$ [ -d /sys/firmware/efi ] && echo "UEFI boot" || echo "BIOS boot"
$ sudo os-prober
$ sudo grep -E "os-prober|50mounted-tests|20microsoft" /var/log/syslog | tail -30
$ sudo grub-mount /dev/sda1 /mnt && ls /mnt | head && sudo umount /mnt
Background: os-prober only reports Windows on a system booted in legacy BIOS mode -
its Windows detector exits immediately when /sys/firmware/efi exists, while Linux
systems are still listed. That alone produces exactly your output. If Aquarius
booted in UEFI mode and Gemini in BIOS mode, that is the answer, and a BIOS Windows
cannot be chainloaded from an EFI GRUB anyway - Windows then has to be started from
the firmware boot menu, or Q4OS's bootloader reinstalled in BIOS mode.
Otherwise the second possibility is that GRUB cannot read the NTFS partition:
os-prober mounts partitions only with grub-mount, and skips a partition silently if
that fails. The grub-mount line above shows it. In that case, mounting the Windows
partition before updating the menu works around it:
$ sudo mkdir -p /mnt/win && sudo mount -o ro /dev/sda1 /mnt/win
$ sudo update-grub
$ sudo umount /mnt/win
Your Gemini install is unaffected either way; running update-grub there is safe.
#7 Today 16:15
It's only Lagacy/BIOS here on my pc. The output of the first block:
me@flex:~\> [ -d /sys/firmware/efi ] && echo "UEFI boot" || echo "BIOS boot"
BIOS boot
me@flex:~\> sudo os-prober
me@flex:~\> sudo grep -E "os-prober|50mounted-tests|20microsoft" /var/log/syslog | tail -30
2026-09-15T17:01:30.434456+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
2026-09-15T17:01:30.448226+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
2026-09-15T17:01:30.461908+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
2026-09-15T17:01:30.475361+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
2026-09-15T17:01:30.488883+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
2026-09-15T17:01:30.497188+02:00 flex 20microsoft: debug: /dev/sda8 is a NTFS partition
2026-09-15T17:01:30.681517+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
2026-09-15T17:01:30.690619+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
2026-09-15T17:01:30.696828+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
2026-09-15T17:01:30.702876+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
2026-09-15T17:01:30.708620+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
2026-09-15T17:01:30.717956+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
2026-09-15T17:01:30.759998+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
2026-09-15T17:01:30.763762+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
2026-09-15T17:01:30.780375+02:00 flex os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda9
2026-09-15T17:01:31.069083+02:00 flex 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
2026-09-15T17:01:31.071423+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
2026-09-15T17:01:31.077153+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
2026-09-15T17:01:31.082767+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
2026-09-15T17:01:31.088325+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
2026-09-15T17:01:31.093991+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
2026-09-15T17:01:31.097497+02:00 flex 20microsoft: debug: /dev/sda9 is a NTFS partition
2026-09-15T17:01:31.226322+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
2026-09-15T17:01:31.231098+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
2026-09-15T17:01:31.234279+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
2026-09-15T17:01:31.237560+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
2026-09-15T17:01:31.240582+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
2026-09-15T17:01:31.245326+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
2026-09-15T17:01:31.268202+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
2026-09-15T17:01:31.271715+02:00 flex 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
The second solution then seems to work::
me@flex:~\> sudo mkdir -p /mnt/win && sudo mount -o ro /dev/sda1 /mnt/win
me@flex:~\> sudo update-grub
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-6.1.0-53-amd64
Found initrd image: /boot/initrd.img-6.1.0-53-amd64
Found linux image: /boot/vmlinuz-6.1.0-44-amd64
Found initrd image: /boot/initrd.img-6.1.0-44-amd64
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
/usr/sbin/grub-probe: error: unknown filesystem.
Found Windows 7 on /dev/sda1
done
me@flex:~\> sudo umount /mnt/win
me@flex:~\>
Please let me reboot...
Added later 30 min 16 s:
Many thanks for your support @q4osteam!
But it fails. The entry for Win7 in the boot menu is actually present, but when selecting it:
Settin partition type to 0x83
error: invalid signature
any key to continue
if i edit the entry, i can see the cause: the entry is far too less (as i saw it on a working system), even the partition uuid is missing!
Setparms 'Windows7 (on /dev/sda1)'
        insmod part_msdos
        parttool ${root} hidden-
        chainloader +1
This is disappointing, two steps at least back from Gemini tbh.
Should i try  sudo /media/me/<uuid of beloved Gemini partition>/usr/bin/os-prober ?
Edit: tried it - no success neither, only Gemini is found...
