#1 2025-08-05 12:51
bugmenot
draging files to play in vlc passes wrong file name?
draging files to play in vlc passes wrong file name, even the all path in english, but when clicked the file it plays.
any solution?
#2 2025-08-05 13:21
Re: draging files to play in vlc passes wrong file name?
I think vlc loads the name from metadata to display them, try setting
Tools > Preferences > All > Input/Codecs > Advanced > Change title according to current media
$F
for full name with path
check out VLC's wiki for full list
If this doesn't work out and/or vlc is having a memory leak,
Just untick
Tools > Preferences > Show settings > All > Playlist > Automatically preparse items
#3 2025-08-05 21:09
bugmenot
Unfortunately, I ended with installing pcmanfm,
#4 2025-08-05 22:03
Huh.. did that fixed your issue?
