#1 2025-06-15 16:57
lmelkvik
Desktop Trash Icon Always Shows Empty
The desktop trash icon always shows empty even if there are files contained in the trash. Is there a way to have the icon change to show that there are files in the trash?
#2 2025-06-15 17:00
Re: Desktop Trash Icon Always Shows Empty
Are you using Trinity DE ?
#3 2025-06-16 14:29
lmelkvik
Yes
#4 2025-06-16 17:29
What icon theme have you set ? Control panel > appearance .. > icons
What is your Q4OS version:
$ get-q4os-version
#5 2025-06-16 19:32
lmelkvik
Crystal SVG icons. Q4OS version: 5.8.1-n1.
#6 2025-06-16 20:28
lmelkvik
I deleted Trash folder in /.local/share and that fixed it. Trash icon now changes full/empty.
#7 2025-06-16 20:32
Well, that should work with crystalsvg icons. Please perform a simple test.
- right click on the trash icon > empty trash bin.
- paste a screenshot of trash bin here
- create a testing file using konqueror
- paste a second screenshot
- double click on the trash icon and check the file is really there
Post back the result.
#8 2025-06-17 03:15
lmelkvik
Emptied trash. Took screenshot.
#9 2025-06-17 03:16
lmelkvik
Moved text file to trash. Took screenshot.
Verified text file in trash
#10 2025-06-17 10:08
We are not able to reproduce the issue. How exactly do you "move text file to trash" ? Please specify step by step so we can reproduce the way.
Moreover please take another test.
- Open "My Documents" shortcut on the Desktop
- Right click on the space > create new > text file
- Select the new file
- Press "Delete" key and confirm
- Check the trash status
And another one. Create a new testing user and test trash bin within new user's session.
#11 2025-06-28 14:29
Similar issue, the trash icon shows empty even if i have files inside it.
Cause in my case: using other apps like thunar which uses gvfs-trash protocol instead of trinity's (kio-trinity?) protocol
