#1 2025-06-11 13:34
PxDemaR
kate
Is it possible to fully uninstall and/or prevent KATE from Autostarting to the Tray area?
Sincerely /PxDemaR - Respect the Elderly & Honor Knowledge! - 60+ Viking Swede living in Netherlands! PTSD & ADD - Music Production & Graphic Creator - ROCK-RABBIT-STUDIO NPA © 2002 – 2026 - Game Squad-Manager “VETERAN VIKINGS” [X10] © 2006 – 2026
#2 2025-06-11 13:38
Re: kate
Welcome to the forum smile
What Q4OS version and what desktop are you using ?
#3 2025-06-11 13:40
PxDemaR
Re: kate
KDE Plasma
#4 2025-06-11 13:47
Re: kate
Run in termianl:
$ sudo apt autoremove kate
and reboot
#5 2025-06-11 14:05
PxDemaR
Re: kate
Thanks mate! But KATE still starts a Tray icon and also stays in the Start Menu. However, the program cannot be started, as it says that the software is uninstalled.
#6 2025-06-11 14:10
Re: kate
What if you right click on the icon in systray ?
#7 2025-06-11 14:16
PxDemaR
Re: kate
Yes, it shows KATE Sessions, but of course nothing can be started. It's really weird that KATE also stays in the Start menu.
#8 2025-06-11 14:18
Re: kate
So go to system settings > autostart and remove kate shortcut from autostarting
#9 2025-06-11 14:33
PxDemaR
Re: kate
Back in 5
#10 2025-06-11 14:46
PxDemaR
Re: kate
It's not there. Submitting Screenshot...
#11 2025-06-11 14:50
Re: kate
You can safely remove 50frst-rsession script as it's useless and reboot. Plasma may keep trying open the script with Kate. Post back the result.
#12 2025-06-11 14:57
PxDemaR
Re: kate
Sure do. Thanks!
#13 2025-06-11 15:11
PxDemaR
Re: kate
Nope.. still in Tray and Start Menu. Did a file search on KATE, and there are still many directories and files left. Submitting 2 Screenshots.
#14 2025-06-11 15:31
Re: kate
Would you post a screenshot of kate in tray ? What happens if you left/right-click on the icon ?
If you install Kate again, run it and disable systray actions:
Open Kate and navigate to Settings > Configure Kate.
Go to the Application tab.
In the Window section, locate the Minimize to System Tray option.
Disable this option.
#15 2025-06-11 15:34
PxDemaR
Re: kate
Hover just say Kate Sessions. Click is on the screenshot.
I really appreciate you taking the time to help.
#16 2025-06-11 15:59
Re: kate
So install Kate again, run it and disable systray actions:
Reboot and see if still sitting in systray
#17 2025-06-11 16:21
PxDemaR
Re: kate
Okay... back soon!
#18 2025-06-11 19:26
PxDemaR
Re: kate
I discovered that KATE has 2 applications, a regular and a Plasma Desktop version (see picture). I had both installed. The Plasma version is probably included with the Q4 installation, which I missed, and also installed the regular one. The Plasma version was still installed after your assistance, which you couldn't know. Both are uninstalled now. But and the icon in the Tray bar is gone, but the icon in the Start Menu is still stuck. When I right-click and request Edit Application, I get the window in the 2nd picture. So still a bit wonky.
#19 2025-06-11 20:44
Oconcal
Re: kate
Since Kate was a stock item in plasma, when you uninstall it will will remain this link so its a one click reinstall or install if it wasn't installed in the first place. You actually have to remove the .desktop file out of /usr/share/applications if you don't want the one click installer in the applications menu.
I'll look at it tonight, when I get home, but that should be the path on a plasma install.
#20 2025-06-11 20:49
PxDemaR
Re: kate
Alright! Thanks mate!
Appreciated your time. 5 Star support!
#21 2025-06-11 20:53
Oconcal
Re: kate
no problem I am VPN to my network at the house, but I don't have my computer on so I can't see it  on my Q4os install
