#1 2025-05-30 12:35
Stiven
I can't open the console
I have a problem Cntrl alt t does not want to open the console, although in the settings set this combination and nothing else I have not changed.How to fix this situation?
#2 2025-06-08 18:32
Oconcal
Re: I can't open the console
I'm assuming this is the Trinity desktop. Which is a spinoff of KDE. The front end to configure hotkeys are in setting-> Configure Shortcuts. But terminal is one of those hotkeys that you had to configure when you manually install KDE and I imagine its the same thing.
I'll look on my 32 bit install I set up last night and see if that is different, but I doubt it. I'm new here but not new to these programs.
#3 2025-06-08 19:21
Take a look at this topic,   www.q4os.org/forum/viewtopic.php?id=5376
Q4OS KDE 5.x-  Lenovo M73 Tiny  4th gen i5 Intel cpu, 16gb ram, 256gb ssd
