#1 2025-06-06 18:35
Durhammer
Cannot install Update Manager!!! [SOLVED]
@q4osteam just advised me to install the Update Manager, so I tried. It gets to a point where it sees my Brother printer software and throws its hands up. The Setup Wizard shows a dialog box with this:
Package system is in non consistent state, it has to be recovered manually. Installation cannot continue now.
Cleaning and canceling ...
Here's what it seems to be complaining about:
Calculating progress ...
Testing Internet connection ...
Testing Internet connection ... OK
Extracting archive ...
Extracting archive ... Done
Checking package system ...
The following packages have an unknown foreign architecture, which will
cause dependency issues on front-ends. This can be fixed by registering
the foreign architecture with dpkg --add-architecture:
mfcj5720dwcupswrapper:i386 Brother CUPS Inkjet Printer Definitions
mfcj5720dwlpr:i386 Brother lpr Inkjet Printer Definitions
Package system not consistent ...
Trying to recover APT integrity ...
Reading package lists... 4%
Reading package lists... Done
Building dependency tree... 50%
Reading state information... 0%
The following packages were automatically installed and are no longer required:
libindex0-trinity libksieve0-trinity libmimelib1c2a-trinity
linux-headers-6.12.12-2-liquorix-amd64 linux-image-6.12.12-2-liquorix-amd64
tdepim-tdeio-plugins-trinity
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 201 not upgraded.
0% [Working]
Hit:1 http://security.debian.org bookworm-security InRelease
0% [Waiting for headers] [Connecting to liquorix.net] [Waiting for headers]
Hit:2 http://deb.debian.org/debian bookworm InRelease
0% [Connected to liquorix.net (172.67.184.200)] [Waiting for headers]
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://ftp.debian.org/debian bookworm-backports InRelease
Hit:5 https://liquorix.net/debian bookworm InRelease
0% [Connecting to download.opensuse.org]
0% [Connecting to download.opensuse.org (195.135.223.226)]
Hit:6 http://download.opensuse.org/repositories/home:/obs_mhogomchungu/Debian_12 InRelease
0% [Working]
0% [Connecting to q4os.org (81.95.96.231)]
0% [Working]
0% [Working]
0% [Connected to q4os.org (81.95.96.231)]
Hit:7 https://q4os.org/q4repo q4os-5-0-cn InRelease
0% [Working]
Hit:8 https://q4os.org/qtderepo bookworm InRelease
0% [Working]
Hit:9 https://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease
20% [Working]
Reading package lists... 97%
Reading package lists... 100%
Package system still not consistent, canceling installation ...
What do I need to do to fix this? Not sure what the dpkg --add-architecture command would look like.
#2 2025-06-06 18:41
Re: Cannot install Update Manager!!! [SOLVED]
It's not issue with update manager, but some deeper problem with package system, what is inconsistent. We can see you have installed Liquorix kernel what is an external third party package, so it's likely the culprit.
First remove the external repositories and run:
$ sudo apt update
and post back.
#3 2025-06-06 19:11
Durhammer
I'm a bit embarrassed that I do not know what the command(s) are that I need to run to remove the external repositories. And once I do, what does that do to the maintenance of the Liquorix kernel? (I THINK it just got upgraded when I did the sudo apt full-upgrade recommended in a separate topic, FWIW.)
#4 2025-06-06 19:43
Durhammer
The same issue occurs if I try to install Synaptic Package Manager. I tried running the dpkg --add-architecture commands for the Brother printer items it seems to be complaining about, but that didn't help.
AH! I was able to install q4os-synaptic-trinity via apt. Just trying to update/upgrade Brave Browser, which the sofware center installed as a flatpak and is out of date.
#5 2025-06-06 21:26
Please run in terminal:
$ qrepolist
and post back the output.
The Liquorix kernel seems to be fine after all, some other external repositories may pull the error.
#6 2025-06-06 22:44
Durhammer
Here ya go:
$ qrepolist
deb http://q4os.org/q4repo q4os-5-0-cn main
deb http://q4os.org/qtderepo bookworm main
deb http://deb.debian.org/debian/ bookworm main contrib non-free non-free-firmware
deb http://security.debian.org/ bookworm-security main contrib non-free non-free-firmware
deb http://deb.debian.org/debian/ bookworm-updates main contrib non-free non-free-firmware
deb http://q4os.org/qextrepo bookworm-plasmalooks-cn main
deb [signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg] https://brave-browser-apt-release.s3.brave.com/ stable main
deb http://download.opensuse.org/repositories/home:/obs_mhogomchungu/Debian_12/ /
deb [arch=amd64] https://liquorix.net/debian bookworm main
deb http://ftp.debian.org/debian/ bookworm-backports main contrib non-free
Note that I just today installed Brave Browser via command line and uninstalled the Flatpak version of it that I got from the Q4OS Software Centre, which was out of date and not updatable. So that repo wasn't there when I had this problem originally. Sorry for dirtying the picture!
#7 2025-06-07 09:46
Run:
$ sudo apt update
$ sudo apt-get check
$ sudo apt full-upgrade
and post the output.
If all the commands run without errors, the software center application should install fine. So also try to install Update manger from the SC. We would also recommend to uninstall Flatpak, if you don't plan installing Flatpak apps.
#8 2025-06-07 15:10
Durhammer
Got rid of Flatpak. The only apt command returning anything that looked useful is the first one:
~$ sudo apt update
Hit:1 http://ftp.debian.org/debian bookworm-backports InRelease
Hit:4 https://brave-browser-apt-release.s3.brave.com stable InRelease
Hit:5 http://security.debian.org bookworm-security InRelease
Hit:7 https://liquorix.net/debian bookworm InRelease
Hit:8 https://q4os.org/q4repo q4os-5-0-cn InRelease
Hit:9 https://q4os.org/qtderepo bookworm InRelease
Hit:10 https://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease
All packages are up to date.
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://ftp.debian.org/debian bookworm-backports InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'http://ftp.debian.org/debian bookworm-backports InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://ftp.debian.org/debian bookworm-backports InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwlpr/Packages' as repository 'http://ftp.debian.org/debian bookworm-backports InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://ftp.debian.org/debian bookworm-backports InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwlpr/Packages' as repository 'http://ftp.debian.org/debian bookworm-backports InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'non-free-firmware/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'non-free-firmware/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free-firmware/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'non-free-firmware/binary-mfcj5720dwlpr/Packages' as repository 'http://deb.debian.org/debian bookworm-updates InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'https://brave-browser-apt-release.s3.brave.com stable InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'https://brave-browser-apt-release.s3.brave.com stable InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'contrib/binary-mfcj5720dwlpr/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'non-free/binary-mfcj5720dwlpr/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free-firmware/binary-mfcj5720dwlpr/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'non-free-firmware/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://security.debian.org bookworm-security InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://q4os.org/q4repo q4os-5-0-cn InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'http://q4os.org/q4repo q4os-5-0-cn InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'http://q4os.org/qtderepo bookworm InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://q4os.org/qtderepo bookworm InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwlpr/Packages' as repository 'http://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease' doesn't support architecture 'mfcj5720dwlpr'
N: Skipping acquire of configured file 'main/binary-mfcj5720dwcupswrapper/Packages' as repository 'http://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease' doesn't support architecture 'mfcj5720dwcupswrapper'
#9 2025-06-07 15:56
It seems you have misconfigured apt somehow. You need to look at the files in /etc/apt/soutces.list.d/*.list and fix the lines in the repository that contain something like "...mfcj5720d...". If you need help with this, please post the contents of the suspect .list files.
#10 2025-06-07 16:05
Durhammer
Alas, NONE of the *.list files therein contain any text with "mfc" alone (I first used Xfe's search tool, then manually looked at each file in turn anyway).
I'm going to try just removing the Brother printer stuff. I can re-install it later if need be (and it do need be!).
EDIT: Uninstalling the Brother printer software allowed me to install the Update Manager. SHEESH! So wonder what happens when I now re-install the printer drivers? Stay tuned!
#11 2025-06-07 16:07
Wait a moment, try removing cached apt files first:
$ sudo rm /var/lib/apt/lists/*
and update again:
$ sudo apt update
#12 2025-06-07 16:13
Durhammer
and update again:
$ sudo apt update
Ooops. Too late! See previous post, edited.
#13 2025-06-07 16:14
Ok smile
Does "apt update" run without errors now ?
#14 2025-06-07 16:17
Durhammer
Okay, tried the commands anyway --
rm: cannot remove '/var/lib/apt/lists/auxfiles': Is a directory
rm: cannot remove '/var/lib/apt/lists/partial': Is a directory
The apt update command pretty much returned the same as before, however.
#15 2025-06-07 16:28
Something in your sources.list must be really ugly. The only idea how to determine it we would think about to rename/backup all the .list files to ".list.bak", run "apt-update". With no sources.list files the output must be clean. Subsequently enable .list files one by one and check the update command again and again.
#16 2025-06-07 21:11
Durhammer
Sounds a bit tedious, but I'll give it a shot.
#17 2025-06-08 02:44
Durhammer
Meanwhile, when I re-installed the printer drivers, I noted messages about some package being for i386, not amd64, so I downloaded the latest Brother printer installer tool and re-ran the install. Even then, there are the same or similar messages. See:
# bash linux-brprinter-installer-2.2.4-1
Input model name ->MFCJ5720DW
You are going to install following packages.
   mfcj5720dwlpr-3.0.1-1.i386.deb
   mfcj5720dwcupswrapper-3.0.1-1.i386.deb
   brscan4-0.4.11-1.amd64.deb
   brscan-skey-0.3.2-0.amd64.deb
OK? [y/N] ->y
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://security.debian.org bookworm-security InRelease
Hit:3 https://brave-browser-apt-release.s3.brave.com stable InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Hit:5 http://ftp.debian.org/debian bookworm-backports InRelease
Hit:6 https://liquorix.net/debian bookworm InRelease
Hit:7 http://download.opensuse.org/repositories/home:/obs_mhogomchungu/Debian_12  InRelease
Package ia32-libs is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  lib32z1
E: Package 'ia32-libs' has no installation candidate
dpkg -x mfcj5720dwlpr-3.0.1-1.i386.deb /
dpkg -x mfcj5720dwcupswrapper-3.0.1-1.i386.deb /
(Reading database ... 394957 files and directories currently installed.)
Removing mfcj5720dwcupswrapper:i386 (3.0.1-1) ...
Restarting cups (via systemctl): cups.service.
Purging configuration files for mfcj5720dwcupswrapper:i386 (3.0.1-1) ...
dpkg-deb: building package 'mfcj5720dwlpr' in 'mfcj5720dwlpr-3.0.1-1a.i386.deb'.
dpkg -b ./brother_driver_packdir mfcj5720dwlpr-3.0.1-1a.i386.deb
dpkg-deb: building package 'mfcj5720dwcupswrapper' in 'mfcj5720dwcupswrapper-3.0.1-1a.i386.deb'.
dpkg -b ./brother_driver_packdir mfcj5720dwcupswrapper-3.0.1-1a.i386.deb
dpkg -i --force-all mfcj5720dwlpr-3.0.1-1a.i386.deb
dpkg: warning: overriding problem because --force enabled:
dpkg: warning: package architecture (i386) does not match system (amd64)
(Reading database ... 394953 files and directories currently installed.)
Preparing to unpack mfcj5720dwlpr-3.0.1-1a.i386.deb ...
Unpacking mfcj5720dwlpr:i386 (3.0.1-1) over (3.0.1-1) ...
Setting up mfcj5720dwlpr:i386 (3.0.1-1) ...
mkdir: cannot create directory ‘/var/spool/lpd/mfcj5720dw’: No such file or directory
chown: cannot access '/var/spool/lpd/mfcj5720dw': No such file or directory
chgrp: cannot access '/var/spool/lpd/mfcj5720dw': No such file or directory
chmod: cannot access '/var/spool/lpd/mfcj5720dw': No such file or directory
dpkg -i --force-all mfcj5720dwcupswrapper-3.0.1-1a.i386.deb
Selecting previously unselected package mfcj5720dwcupswrapper:i386.
Preparing to unpack mfcj5720dwcupswrapper-3.0.1-1a.i386.deb ...
Unpacking mfcj5720dwcupswrapper:i386 (3.0.1-1) ...
Setting up mfcj5720dwcupswrapper:i386 (3.0.1-1) ...
lpadmin -p MFCJ5720DW -E -v dnssd://Brother%20MFC-J5720DW._ipp._tcp.local/?uuid=e3248000-80ce-11db-8000-30055c89c350 -P /usr/share/cups/model/Brother/brother_mfcj5720dw_printer_en.ppd
lpadmin: Printer drivers are deprecated and will stop working in a future version of CUPS.
#18 2025-06-08 09:20
Yes, but first we need to fix your sources.list. It's really misconfigured a wrong way. Fixing Apt is an essential action.
- backup all the /etc/apt/sources.list.d/*.list files to ".list.bak"
- run "sudo apt update" - with no sources.list files the output must be clean.
- subsequently enable .list files one by one and check the update command for each restored file.
- post the result here
This is important and quite easy action and show us the failed sources.list, so we can fix/remove it.
Only as soon as we fix sources.list, you can add i386 architecture.
$ sudo dpkg --add-architecture i386
and update Apt
$ sudo apt update
#19 2025-06-08 15:38
Durhammer
First list re-renamed -- 10_q4os.list -- results:
$ sudo apt update
Hit:1 https://q4os.org/qtderepo bookworm InRelease
Second list re-renamed -- 12_qtde.list -- results:
$ sudo apt update
Hit:1 https://q4os.org/q4repo q4os-5-0-cn InRelease
Get:2 https://q4os.org/qtderepo bookworm InRelease [4,637 B]
Get:3 https://q4os.org/qtderepo bookworm/main amd64 Packages [227 kB]
Fetched 232 kB in 3s (75.9 kB/s)
Third list re-renamed -- 20_debian.list -- results:
$ sudo apt update
Get:1 http://security.debian.org bookworm-security InRelease [48.0 kB]
Get:2 http://security.debian.org bookworm-security/main amd64 Packages [265 kB]
Get:3 http://security.debian.org bookworm-security/main Translation-en [161 kB]
Get:4 http://security.debian.org bookworm-security/contrib amd64 Packages [896 B]
Get:5 http://security.debian.org bookworm-security/contrib Translation-en [652 B]
Get:6 http://security.debian.org bookworm-security/non-free-firmware amd64 Packages [688 B]
Get:7 http://security.debian.org bookworm-security/non-free-firmware Translation-en [472 B]
Get:8 http://deb.debian.org/debian bookworm InRelease [151 kB]
Get:9 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
Get:10 http://deb.debian.org/debian bookworm/main amd64 Packages [8,793 kB]
Get:11 http://deb.debian.org/debian bookworm/main Translation-en [6,109 kB]
Get:12 http://deb.debian.org/debian bookworm/main amd64 DEP-11 Metadata [4,492 kB]
Get:13 http://deb.debian.org/debian bookworm/main DEP-11 48x48 Icons [3,595 kB]
Get:14 http://deb.debian.org/debian bookworm/main DEP-11 64x64 Icons [7,295 kB]
Get:15 http://deb.debian.org/debian bookworm/main DEP-11 128x128 Icons [11.1 MB]
Get:16 http://deb.debian.org/debian bookworm/contrib amd64 Packages [53.5 kB]
Get:17 http://deb.debian.org/debian bookworm/contrib Translation-en [48.4 kB]
Get:18 http://deb.debian.org/debian bookworm/contrib amd64 DEP-11 Metadata [16.5 kB]
Get:19 http://deb.debian.org/debian bookworm/contrib DEP-11 48x48 Icons [52.7 kB]
Get:20 http://deb.debian.org/debian bookworm/contrib DEP-11 64x64 Icons [106 kB]
Get:21 http://deb.debian.org/debian bookworm/contrib DEP-11 128x128 Icons [252 kB]
Get:22 http://deb.debian.org/debian bookworm/non-free amd64 Packages [102 kB]
Get:23 http://deb.debian.org/debian bookworm/non-free Translation-en [68.1 kB]
Get:24 http://deb.debian.org/debian bookworm/non-free amd64 DEP-11 Metadata [4,428 B]
Get:25 http://deb.debian.org/debian bookworm/non-free DEP-11 48x48 Icons [748 B]
Get:26 http://deb.debian.org/debian bookworm/non-free DEP-11 64x64 Icons [27.5 kB]
Get:27 http://deb.debian.org/debian bookworm/non-free DEP-11 128x128 Icons [2,522 B]
Get:28 http://deb.debian.org/debian bookworm/non-free-firmware amd64 Packages [6,372 B]
Get:29 http://deb.debian.org/debian bookworm/non-free-firmware Translation-en [20.9 kB]
Get:30 http://deb.debian.org/debian bookworm/non-free-firmware amd64 DEP-11 Metadata [15.5 kB]
Get:31 http://deb.debian.org/debian bookworm/non-free-firmware DEP-11 48x48 Icons [29 B]
Get:32 http://deb.debian.org/debian bookworm/non-free-firmware DEP-11 64x64 Icons [29 B]
Get:33 http://deb.debian.org/debian bookworm/non-free-firmware DEP-11 128x128 Icons [29 B]
Get:34 http://deb.debian.org/debian bookworm-updates/main amd64 Packages [512 B]
Get:35 http://deb.debian.org/debian bookworm-updates/main Translation-en [360 B]
Fetched 42.8 MB in 2min 23s (299 kB/s)
Fourth re-renamed list -- 30_debian_backports.list -- results:
$ sudo apt update
Fifth list re-renamed -- 50-plasmalooks.list -- results:
$ sudo apt update
Get:1 https://q4os.org/qextrepo bookworm-plasmalooks-cn InRelease [3,237 B]
Get:2 https://q4os.org/qextrepo bookworm-plasmalooks-cn/main amd64 Packages [2,560 B]
Fetched 5,797 B in 2s (2,336 B/s)
Sixth re-rename -- brave-browser-release.list -- results:
$ sudo apt update
Get:1 https://brave-browser-apt-release.s3.brave.com stable InRelease [7,546 B]
Get:2 https://brave-browser-apt-release.s3.brave.com stable/main amd64 Packages [21.7 kB]
Fetched 29.2 kB in 0s (59.4 kB/s)
Seventh re-rename -- home:obs_mhogomchungu.list -- results:
$ sudo apt update
Get:1 http://download.opensuse.org/repositories/home:/obs_mhogomchungu/Debian_12  InRelease [1,540 B]
Get:2 http://download.opensuse.org/repositories/home:/obs_mhogomchungu/Debian_12  Packages [5,182 B]
Fetched 6,722 B in 4s (1,803 B/s)
Eighth re-rename -- liquorix.list -- results:
$ sudo apt update
Get:1 https://liquorix.net/debian bookworm InRelease [2,438 B]
Get:2 https://liquorix.net/debian bookworm/main amd64 Packages [8,013 B]
Fetched 10.5 kB in 1s (14.1 kB/s)
Ninth (last) re-renamed -- q4p-debian-backports-20250204103739-pEe.list -- results:
$ sudo apt update
Get:1 http://ftp.debian.org/debian bookworm-backports InRelease [59.4 kB]
Get:2 http://ftp.debian.org/debian bookworm-backports/main amd64 Packages [288 kB]
Get:3 http://ftp.debian.org/debian bookworm-backports/main Translation-en [246 kB]
Get:4 http://ftp.debian.org/debian bookworm-backports/contrib amd64 Packages [5,852 B]
Get:5 http://ftp.debian.org/debian bookworm-backports/contrib Translation-en [5,864 B]
Get:6 http://ftp.debian.org/debian bookworm-backports/non-free amd64 Packages [13.3 kB]
Get:7 http://ftp.debian.org/debian bookworm-backports/non-free Translation-en [8,460 B]
Fetched 627 kB in 1s (1,113 kB/s)
165 packages can be upgraded. Run 'apt list --upgradable' to see them.
What now? Thanks.
#20 2025-06-08 15:45
I wrote a script to do it, maybe it can be helpful (see attachment). I've tested it on my clean system, so no error could be detected.
Minimal instructions in the first few lines.
Could q4osteam confirm it is safe to run (don't interrupt it)?
#21 2025-06-08 15:55
This is not a procedure that will show the problematic file, sorry for the misunderstanding. We thought you would rename all .list files first.
So let's take it in smaller steps, please follow exactly:
- Rename/backup all /etc/apt/sources.list.d/*.list files to ".list.bak". All .list files.
- Run "sudo apt update"
Post back this single output.
#22 2025-06-08 16:00
@hchiper
Yes, the scripts seems to work fine, thanks smile
#23 2025-06-08 16:25
Durhammer
Sorry, should have included the results when ALL list files were renamed *.bak -- here it is:
$ sudo apt update
#24 2025-06-08 16:27
Durhammer
The results shown in my previous last post started renaming the *.bak files individually one by one. Sorry if I misunderstood the instructions!
#25 2025-06-08 16:28
Well it's clean, so the snag must be in some .list. Now enable file "10_q4os.list" and then run "apt update" again and post the output.
