#51 2025-05-19 16:01
minuccio63
Re: File Transfert too slow
Another Very Important Test:
Test on another Pc with same S.O. Q4OS 6 Basic (Andromeda) Copy File = (FAST)
results of cpuqinfo.exu on PC 1 (slow) and PC 2 (fast)
PC 1  (copy slow)
System:
     Host: mino-6730s Kernel: 6.12.27-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0 clocksource: hpet avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.12.27-amd64 root=UUID=0e0c67f6-978d-4300-9c0d-6f65587893fe ro quiet loglevel=3 systemd.log_color=0 systemd.show_status=1
     Desktop: TDE (Trinity) v: R14.1.4 tk: Qt v: 3.5.0 wm: Twin v: 3.0 with: kicker vt: 7 dm: 1: TDM 2: XDM Distro: Q4OS 6.0.0-n1 base: Debian GNU/Linux trixie/sid
Machine:
     Type: Laptop System: Hewlett-Packard product: HP Compaq 6730s v: F.0C serial: Chassis: type: 10 serial:
     Mobo: Hewlett-Packard model: 30E8 v: KBC Version 94.1C serial: part-nu: VC168ES#ABZ uuid: BIOS: Hewlett-Packard v: 68PZU Ver. F.0C date: 03/12/2009
Battery:
     ID-1: BAT0 charge: 32.2 Wh (97.3%) condition: 33.1/56.2 Wh (59.0%) volts: 12.2 min: 10.8 model: Hewlett-Packard Primary type: Li-ion serial: 00007 2021/01/10 status: not charging
Memory:
     System RAM: total: 4 GiB available: 3.73 GiB used: 709.3 MiB (18.6%)
     Message: For most reliable report, use superuser + dmidecode.
     Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None max-module-size: 4 GiB note: est.
     Device-1: Top type: DDR2 detail: synchronous size: 2 GiB speed: 667 MT/s volts: N/A width (bits): data: 64 total: 64 manufacturer: Samsung part-no: M4 70T5663QZ3-CF7 serial: 78991AC3
     Device-2: Bottom type: DDR2 detail: synchronous size: 2 GiB speed: 667 MT/s volts: N/A width (bits): data: 64 total: 64 manufacturer: Samsung part-no: M4 70T5663QZ3-CE6 serial: 9675ED3F
CPU:
     Info: model: Intel Core2 Duo T5870 bits: 64 type: MCP arch: Core2 Merom level: v1 built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15) stepping: 0xD (13) microcode: 0xA4
     Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 2 MiB desc: 1x2 MiB
     Speed (MHz): avg: 800 min/max: 800/2001 boost: enabled scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 800 2: 800 bogomips: 7979
     Flags: ht lm nx pae sse sse2 sse3 ssse3
     Type: gather_data_sampling status: Not affected
     Type: itlb_multihit status: KVM: VMX unsupported
     Type: mmio_stale_data status: Unknown: No mitigations
     Type: reg_file_data_sampling status: Not affected
     Type: retbleed status: Not affected
     Type: spec_rstack_overflow status: Not affected
     Type: srbds status: Not affected
     Type: tsx_async_abort status: Not affected
Graphics:
     Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-5 process: Intel 45nm built: 2008 ports: active: LVDS-1 empty: DP-1,SVIDEO-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
     Display: x11 server: X.Org v: 21.1.16 compositor: Twin v: 3.0 driver: X: loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915 display-ID: :0 screens: 1
     Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31") s-diag: 398mm (15.69")
     Monitor-1: LVDS-1 model: LG Philips LP154WX4-TLAB built: 2008 res: mode: 1280x800 hz: 60 scale: 100% (1) dpi: 98 gamma: 1.2 size: 331x207mm (13.03x8.15") diag: 390mm (15.4") ratio: 16:10 modes: 1280x800
     API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11: drv: crocus inactive: wayland
     API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa v: 25.0.5-1 glx-v: 1.4 direct-render: yes renderer: Mesa Mobile Intel GM45 Express (CTG) device-ID: 8086:2a42 memory: 1.46 GiB unified: yes
     API: Vulkan v: 1.4.309 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM 19.1.7 128 bits) driver: mesa llvmpipe v: 25.0.5-1 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
     Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo x11: xdriinfo, xdpyinfo, xprop, xrandr
Audio:
     Device-1: Intel 82801I HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e class-ID: 0403
     API: ALSA v: k6.12.27-amd64 status: kernel-api tools: alsactl,alsamixer,amixer
     Server-1: aRts v: 1.5.10 status: active with: artswrapper status: off tools: artsdsp
     Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
Network:
     Device-1: Broadcom BCM4312 802.11b/g LP-PHY vendor: Hewlett-Packard driver: b43-pci-bridge v: N/A modules: ssb pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4315 class-ID: 0280
     Device-2: Marvell 88E8042 PCI-E Fast Ethernet vendor: Hewlett-Packard driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 85:00.0 chip-ID: 11ab:4357 class-ID: 0200
     IF: ens5 state: down mac: 00:24:81:68:d5:98
     IF-ID-1: wlan0 state: up mac: 00:21:00:db:c8:20
     Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
     Device-1: HP Bluetooth 2.0 Interface [Broadcom BCM2045] driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 03f0:171d class-ID: fe01
     Report: hciconfig ID: hci0 rfk-id: 0 state: up address: 00:24:7E:5E:F5:D9 bt-v: 2.0 lmp-v: 3 sub-v: 41cf hci-v: 3 rev: 2129 class-ID: 6c010c
     Info: acl-mtu: 1017:8 sco-mtu: 64:8 link-policy: rswitch hold sniff park link-mode: peripheral accept service-classes: rendering, capturing, audio, telephony
Drives:
     Local Storage: total: 2.05 TiB used: 1.57 TiB (76.7%)
     SMART Message: Required tool smartctl not installed. Check --recommends
     ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS543225L9A300 size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: 090430FBCF06LLEPU0YC fw-rev: C40J scheme: MBR
     ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04UBD200 size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400 serial: 72OGT0KVT scheme: MBR
     Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW TS-L633M rev: 0200 dev-links: cdrom
     Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition:
     ID-1: / raw-size: 27.94 GiB size: 27.34 GiB (97.83%) used: 4.01 GiB (14.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 0e0c67f6-978d-4300-9c0d-6f65587893fe
     ID-2: /home raw-size: 55.06 GiB size: 54.02 GiB (98.11%) used: 46.62 GiB (86.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: home uuid: 46bbd2e3-bdd2-4f41-9dac-ed8ee99720c1
     ID-3: /media/mino/TOSHIBA EXT raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.52 TiB (83.6%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: TOSHIBA EXT uuid: DA8275F98275DB09
Swap:
     Alert: No swap data was found.
Unmounted:
     ID-1: /dev/sda3 maj-min: 8:3 size: 500 MiB fs: ntfs label: Riservato per il sistema uuid: D09EC8229EC7FF4A
     ID-2: /dev/sda4 maj-min: 8:4 size: 149.39 GiB fs: ntfs label: N/A uuid: 9AF2F0FCF2F0DD87
USB:
     Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
     Hub-2: 2-0:1 info: full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
     Device-1: 2-6:6 info: Toshiba America EXTERNAL_USB type: mass storage driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 0480:0901 class-ID: 0806 serial: 20220724009632F
     Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
     Device-1: 3-1:2 info: HP Bluetooth 2.0 Interface [Broadcom BCM2045] type: bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 03f0:171d class-ID: fe01
     Hub-4: 4-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
     Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
     Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
     Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
     Hub-8: 8-0:1 info: full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001 class-ID: 0900
     Device-1: 8-1:2 info: USB OPTICAL MOUSE type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA chip-ID: 0000:3825 class-ID: 0301
Sensors:
     System Temperatures: cpu: 47.0 C mobo: N/A
     Fan Speeds (rpm): N/A
Info:
     Processes: 166 Power: uptime: 2h 35m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 1.47 GiB services: tdepowersave Init: systemd v: 257 default: graphical tool: systemctl
     Packages: pm: dpkg pkgs: 1466 libs: 854 tools: apt,apt-get Compilers: N/A Shell: cpuqinfo.exu default: Bash v: 5.2.37 running-in: kdesktop inxi: 3.3.38
PC 2   (copy fast)
System:
     Host: mino-hpstream Kernel: 6.12.27-amd64 arch: x86_64 bits: 64 compiler: gcc v: 14.2.0 clocksource: tsc avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.12.27-amd64 root=UUID=2adc2802-a930-490b-9101-678875ba4143 ro quiet resume=UUID=05f55726-0124-4877-b171-3c315d994e31 loglevel=3 systemd.log_color=0 systemd.show_status=1
Machine:
     Type: Laptop System: Hewlett-Packard product: HP Stream Notebook PC 14 v: 0978100000405F00000420180 serial: Chassis: type: 10 serial:
     Mobo: Hewlett-Packard model: 22EA v: 95.10 serial: part-nu: K3G49EA#ABZ uuid: UEFI-[Legacy]: American Megatrends v: F.06 date: 03/07/2017
Battery:
     ID-1: BAT0 charge: 32.8 Wh (100.0%) condition: 32.8/32.8 Wh (100.0%) volts: 12.7 min: 11.4 model: Hewlett-Packard Primary type: Li-ion serial: N/A status: full cycles: 295
Memory:
     System RAM: total: 2 GiB available: 1.64 GiB used: 830.8 MiB (49.6%)
     Array-1: capacity: 2 GiB slots: 1 modules: 1 EC: None max-module-size: 2 GiB note: est.
     Device-1: Bottom-Slot 1 (left) type: DDR3 detail: synchronous unbuffered (unregistered) size: 2 GiB speed: spec: 1600 MT/s actual: 1333 MT/s volts: curr: 1.35 min: 1.25 max: 1.35 width (bits): data: 64 total: 64 manufacturer: Micron part-no: MT41K256M16HA-125 serial: N/A
CPU:
     Info: model: AMD A4 Micro-6400T APU + AMD Radeon R3 Graphics bits: 64 type: MCP arch: Puma level: v2 built: 2014-15 process: GF 28nm family: 0x16 (22) model-id: 0x30 (48) stepping: 1 microcode: 0x7030105
     Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 1x2 MiB
     Speed (MHz): avg: 800 min/max: 800/1000 boost: enabled scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 7985
     Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
     Type: itlb_multihit status: Not affected
     Type: l1tf status: Not affected
     Type: mds status: Not affected
     Type: meltdown status: Not affected
     Type: mmio_stale_data status: Not affected
Graphics:
     Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R3E Graphics] vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu arch: GCN-2 code: Sea Islands process: GF/TSMC 16-28nm built: 2013-17 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:9854 class-ID: 0300
     Device-2: Suyin HP Truevision HD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.2:3 chip-ID: 064e:c342 class-ID: 0e02 serial: HF1016-P82A-HM02-2-REV0101
     Display: x11 server: X.Org v: 21.1.16 compositor: Twin v: 3.0 driver: X: loaded: radeon unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1
     Screen-1: 0 s-res: 1366x768 s-dpi: 112 s-size: 309x174mm (12.17x6.85") s-diag: 355mm (13.96")
     Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x363c built: 2013 res: mode: 1366x768 hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes: max: 1366x768 min: 640x480
     API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
     API: OpenGL v: 4.5 vendor: amd mesa v: 25.0.5-1 glx-v: 1.4 direct-render: yes renderer: KABINI (radeonsi ACO DRM 2.50 6.12.27-amd64) device-ID: 1002:9854 memory: 250 MiB unified: no
     API: Vulkan v: 1.4.309 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe v: 25.0.5-1 (LLVM 19.1.7) device-ID: 10005:0000 surfaces: xcb,xlib
Audio:
     Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
     Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Network:
     Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: N/A pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 14e4:4365 class-ID: 0280
     Device-2: ICS Advent USB 10/100 LAN driver: cdc_ether type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:5 chip-ID: 0fe6:9900 class-ID: 0a00 serial: 00E099000A0B
     IF: enx00e099000a0b state: up speed: 100 Mbps duplex: half mac: 00:e0:99:00:0a:0b
Bluetooth:
     Device-1: Broadcom BCM43142A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:4 chip-ID: 0a5c:216d class-ID: fe01 serial: 38B1DBF4B462
     Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: no address: 38:B1:DB:F4:B4:62
     Info: acl-mtu: 0:0 sco-mtu: 0:0 link-mode: peripheral accept
Drives:
     Local Storage: total: 29.12 GiB used: 4.82 GiB (16.5%)
     ID-1: /dev/sda maj-min: 8:0 vendor: BHT model: WR202A1032G 670215F5 size: 29.12 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD serial: P02702A12G10c35bb66a fw-rev: 00 scheme: MBR
     Message: No optical or floppy data found.
Partition:
     ID-1: / raw-size: 25.52 GiB size: 24.95 GiB (97.77%) used: 4.65 GiB (18.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: 2adc2802-a930-490b-9101-678875ba4143
Swap:
     Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: no
     ID-1: swap-1 type: partition size: 3.6 GiB used: 168.9 MiB (4.6%) priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap uuid: 05f55726-0124-4877-b171-3c315d994e31
Unmounted:
     Message: No unmounted partitions found.
USB:
     Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
     Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA chip-ID: 0438:7900 class-ID: 0900
     Device-1: 1-1.1:3 info: USB OPTICAL MOUSE type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA chip-ID: 0000:3825 class-ID: 0301
     Device-2: 1-1.2:5 info: ICS Advent USB 10/100 LAN type: ethernet network,CDC-data driver: cdc_ether interfaces: 2 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA chip-ID: 0fe6:9900 class-ID: 0a00 serial: 00E099000A0B
     Device-3: 1-1.3:4 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a5c:216d class-ID: fe01 serial: 38B1DBF4B462
     Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
     Hub-4: 2-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA chip-ID: 0438:7900 class-ID: 0900
     Device-1: 2-1.2:3 info: Suyin HP Truevision HD type: video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 064e:c342 class-ID: 0e02 serial: HF1016-P82A-HM02-2-REV0101
     Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
     Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 1d6b:0003 class-ID: 0900
Sensors:
     System Temperatures: cpu: 48.8 C mobo: N/A gpu: radeon temp: 49.0 C
Info:
     Processes: 186 Power: uptime: 1h 3m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 647.5 MiB services: tdepowersave Init: systemd v: 257 default: graphical tool: systemctl
     Packages: pm: dpkg pkgs: 1510 libs: 884 tools: apt,apt-get Compilers: N/A Shell: cpuqinfo.exu default: Bash v: 5.2.37 running-in: kdesktop inxi: 3.3.38
#52 2025-05-19 16:11
Yes, we will examine these tests. If we understand correctly the first "PC 1  (copy slow)" took place on the original computer in question, while the second test on completely another hardware "PC 2   (copy fast)".
#53 2025-05-19 16:16
At this point it would be helpful if you could ship the debug files "reportq4" https://www.q4os.org/forum/viewtopic.php?id=3502 of two systems. Both tests on the same original computer. The first on the slow system and the second on the fast one - i.e. with Plasma installed. This will allow us to compare them and find the differences. It is important to run both tests on the exactly same hardware.
You can attach the debug files to the forum post or send them by email to support@q4os.org.
#54 2025-05-19 17:57
minuccio63
Same computer, S.O. Q4OS 6 Andromeda Trinity File copy slow
#55 2025-05-19 18:07
minuccio63
Report files sent to email because they cannot be attached here as they are too large 450 KB per file
#56 2025-05-19 18:31
Great, we confirm we have received the files. We will post back as the examination goes.
#57 2025-05-20 12:06
We have found a suspicious system service, however it may not be the culprit. Please try to disable "rtkit" service on the slow system:
$ sudo systemctl stop rtkit-daemon.service
$ sudo systemctl mask rtkit-daemon.service
Reboot and report the transfer speed.
#58 2025-05-20 15:53
minuccio63
mino@mino-6730s:~$ rsync -ah --progress /home/mino/Prova/Andor.avi /media/mino/TOSHIBA\ EXT//prova
sending incremental file list
Andor.avi
          3,77M   0%   64,53kB/s    1:59:46
#59 2025-05-21 10:40
minuccio63
I realize that we are going crazy but we were not born to remain ignorant...
I formatted the partition, I installed Q4OS Trinity Basic (Aquarius), I updated the system, in addition to my account (mino) I created a new user (provolino), in my account (mino) copy file = slow, I exit the system, enter (provolino), copy file = FAST (why?)
here are the test results:
USER mino
mino@q4os-desktop:~/Prova$ rsync -ah --progress Andor.avi /media/mino/TOSHIBA\ EXT/prova
Andor.avi
          1,67M   0%   64,24kB/s    2:00:52
USER provolino
provolino@q4os-desktop:~/Prova$ rsync -ah --progress Andor.avi /media/provolino/TOSHIBA\ EXT/prova
Andor.avi
        467,53M 100%   41,39MB/s    0:00:10 (xfr#1, to-chk=0/1)
#60 2025-05-21 10:57
So the issue gets even more muddled. The first user "mino" and superuser "root" experience slow speed, while created user "provolino" experiences fast speed. We will take these findings into account within the investigation.
We would really want to find out what goes wrong, so thanks for your patience and detailed reporting. Please continue to report any findings here. We are still unable to reproduce the issue, it's bound with some hardware only.
#61 2025-05-22 07:38
USER mino
Andor.avi
USER provolino
Andor.avi
You say you changed user, but did you reboot the machine or just log out mino and log in provolino?
NOTE that the provolino file transfer is not the same size as the mino transfer.
I have been doing some testing of this issue and have found that the file appears to be cached somewhere.
As the same user transfer file source>destination.
Delete destination
Repeat source>destination and the speeds are hugely different.
It is possible that may well happen if you swap user rather than reboot between tests.
As a general observation I have been testing with different hardware and with both Q4OS Trinity and Plasma and EndeavourOS on the same machine and have not seen any material difference in transfer speeds.
I would also mention that the HP still has its original Hitachi 5400rpm spinner which is now the best part of 20 years old, the external Toshiba spinner is the best part of 10 years old and you're running over USB2.
The first thing I would suggest is to install gsmartcontrol and test integrity of the drives.
Early on you mentioned that it was OK under Windows and Ubuntu. This suggests that if all else is equal it probably comes down to firmware and or kernel that actually made the difference. Given my experience with a wide range of HP kit of the same era I think firmware may be the reason. At a guess it is just dropping the transfer speed to USB1 speeds as a default.
Happy to be proved wrong but just a few thoughts.
#62 2025-05-22 14:53
minuccio63
I tested it both by logging out and restarting the PC, nothing changes, as you can see with the user "mino" the file takes about 2 hours to be transferred, while the same file in the user "provolino" was transferred in 10 seconds! The same thing happens also installing Plasma on Trinity, On Plasma the copy is fast on Trinity the copy is slow.
If it was a hardware problem or the speed should be the same both changing user and Desktop Environment or am I wrong?
What if it was a hardware problem or the speed should be the same both when changing user and Desktop Environment or am I wrong?
NOTE: the PC is always the same, the OS is always the same (Q4OS Trinity Acquarius), the USB port I use is always the same, the external drive is always the same... the file copy speed varies if I change user or Desktop Environment....
I don't think it's the firmware's fault...
#63 2025-05-22 16:28
You are not wrong, of course. We never said your hardware is faulty. But the issue is hardware dependent obviously, because we are unable to reproduce it on another computer. And that is why it is difficult to investigate.
#64 2025-05-22 18:45
minuccio63
Yes but this hardware is really intelligent because it can recognize even when I change user... really very strange, I continue to think that it could be some file in the home of "mino" that maybe conflicts with Trinity and not with Plasma because it is strange that when I change user it works well
#65 2025-05-22 19:34
minuccio63 wrote:
I continue to think that it could be some file in the home of "mino" that maybe conflicts with Trinity and not with Plasma ...
We would think so too, but the transfer speed is slow for "root" superuser too. This makes the problem confusing.
Would you please proceed the following test:
- Use the Trinity "slow" system
- Add second user provolino to the group "sudo":
$ sudo adduser provolino sudo
- Reboot and login as the first user "mino" and run command in terminal:
$ rsync -ah --progress Andor.avi /media/<path_to_storage>
$ sudo rsync -ah --progress Andor.avi /media/<path_to_storage>
- Reboot and login as the second user "provolino" and run command in terminal:
- Report speeds of all four "rsync" commands.
#66 2025-05-22 19:59
Okay i "used to" have this issue too, file transfer in Q4OS Trinity Basic (Aquarius) used to be too slow, and way faster in window's installation (dual boot). But yesterday when i checked, it was even faster than windows. Windows 10 gives around 15~36mb/s and now my Q4OS installation gives 86~112mb/s for transferring the same file from my HDD to pendrive and even to n from different partitions. I did a lot of tweaks but i dont quite have a list of those changes.
-i did not make/remove any extra user, its the same as the one i made during installation
-my laptop has TOSHIBA MQ01ABF050 HDD installed
-i never installed plasma in current installation
-used dolphin file manager for a while but it was crashing too often(i made a different issue about this) but then switched to thunar
i am willing to give information about my current installation if you require it,
thankyou.
#67 2025-05-23 10:31
minuccio63
provolino added to the "sudo" group
Test 1
mino@q4os-desktop:~$ rsync -ah --progress Prova/Andor.avi /media/mino/TOSHIBA\ EXT/prova
Andor.avi
          1,15M   0%   71,33kB/s    1:48:58  ^Z
[1]+  Fermato                 rsync -ah --progress Prova/Andor.avi /media/mino/TOSHIBA\ EXT/prova
Test 2
mino@q4os-desktop:~$ sudo rsync -ah --progress Prova/Andor.avi /media/mino/TOSHIBA\ EXT/prova
Andor.avi
        884,74K   0%   72,78kB/s    1:46:51  ^Z
[1]+  Fermato                 sudo rsync -ah --progress Prova/Andor.avi /media/mino/TOSHIBA\ EXT/prova
Test 3
provolino@q4os-desktop:~$ rsync -ah --progress Prova/Andor.avi /media/provolino/TOSHIBA\ EXT/prova
Andor.avi
        467,53M 100%   33,54MB/s    0:00:13 (xfr#1, to-chk=0/1)
Test 4
provolino@q4os-desktop:~$ sudo rsync -ah --progress Prova/Andor.avi /media/provolino/TOSHIBA\ EXT/prova
Andor.avi
        467,53M 100%   31,32MB/s    0:00:14 (xfr#1, to-chk=0/1)
#68 2025-05-25 18:23
The info you provided is valuable, we need no more so far. However we may request some later. Thank you for letting us know.
#69 2025-05-25 18:25
@minuccio63
Please would you test, if installing "thunar" package makes the slow system faster ?
#70 2025-05-26 17:48
minuccio63
Ok I installed Thunar, I tried to copy the file to external HD with Thunar... nothing changed, slow copy 2 hours for a 450 MB file
#71 2025-05-27 07:16
Originally it was stated that file transfer speeds were as expected when using Ubuntu.
That being the case it would be interesting to know what desktop environment.
Clearly there must be something in Ubuntu which is not there in Q4OS/Debian so is there a way of working out what it is?
#72 2025-05-27 08:28
@bin
On Q4OS/Debian @minuccio63 experiences slow speed on the Trinity/Basic setup for the first user only. He gets correct speed right after installing Plasma as a secondary desktop. So the question is, what package fixes the speed ?
Moreover, and it's really peculiar, he also gets proper speed for the next regular user, even without installing Plasma.
#73 2025-05-27 08:30
@minuccio63
Please post back an output of commands bellow for both, "mino" and "provolino" users:
- Reboot
- Login to the Trinity session.
- Insert USB device and open its content in a new Konqueror window.
- Run in terminal:
$ mount | tail -n1
- Reboot
#74 2025-05-27 11:31
minuccio63
mino@mino-6730s:~$ mount | tail -n1
/dev/sdb1 on /media/mino/TOSHIBA EXT type fuseblk (rw,nosuid,nodev,relatime,sync,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
provolino@mino-6730s:~$ mount | tail -n1
/dev/sdb1 on /media/provolino/TOSHIBA EXT type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
#75 2025-05-27 11:47
Yes, this test might show some clue, we will examine it and get back. See the "sync" option for the "mino" user.
