#1 2025-03-29 17:08
willmenn
System update
Hello!
I installed Q4OS 5.8 Aquarius version and I can't update it. The system indicates that there is an update, it also indicates which files and options, but it cannot connect to the base to download it.
#2 2025-03-29 17:31
Re: System update
Please be more specific. How the system indicate the update, post error messages, etc.. A screenshot would be helpful.
#3 2025-04-01 09:05
willmenn
Re: System update
There is no error message, the download simply does not start. I did not have this problem with Gemini. The same problem occurs on several PCs.
#4 2025-04-01 09:09
Re: System update
Would you post a screenshot please ?
#5 2025-04-01 09:10
willmenn
Re: System update
I can't upload it. I don't know how.
#6 2025-04-01 09:15
Re: System update
Post reply > Choose file > Submit
#7 2025-04-01 09:17
Re: System update
... or via e-mail support@q4os.org
#8 2025-04-01 09:20
willmenn
Re: System update
I'll try it.
#9 2025-04-01 09:22
willmenn
Re: System update
It's been like this for over half an hour!
#10 2025-04-01 09:28
Re: System update
Well, now we understand better. Please close the window of Discover application and run commands in terminal:
$ qrepolist
$ sudo apt update
and post the output here
#11 2025-04-01 09:36
willmenn
Re: System update
Thank you, I will send the result.
#12 2025-04-01 09:40
Re: System update
Now run in terminal:
$ sudo apt full-upgrade
That should proceed all updates. If it ends up with an error please post it here.
Next run Discover and check what it says.
#13 2025-04-01 09:49
willmenn
Re: System update
Thank you, that's how it was updated. I installed the new loader as well. I hope it will work normally from now on.
Thanks for the help!
#14 2025-04-01 09:53
Re: System update
Yes, it should. You are welcome.
#15 2025-04-01 18:09
Re: System update
Discover has issues at times, but its certainly better than it use to be. For those who dont want to use the terminal, you can close Discover and use Synaptic package manager, to do your updates. Ive never had any issues with Synaptic in this situation.
#16 2025-05-13 09:31
sub13
Re: System update
Hello
Can you explain me how to update Q4os, before there was a windows for update when q4os start.
Sorry for my english I'm french.
thank you
Asus Eee PC 1000H Atom N270 à 1.6 GHz ram 2go avec Q4os 3.16.1 centaurus
#17 2025-05-13 12:24
Re: System update
@sub13
You can install Update Manager from the Software Centre. It will check automatically from time to time whether upgrades are available and enable you to accept them if you want.
#18 2025-05-13 18:47
Re: System update
As we said above, you can use Synaptic package manager to check for updates as well at anytime and Discover can also do this depending on the version of Q4OS you are using.
#19 2025-05-14 16:13
noseph
Re: System update
I find that using "sudo apt update && sudo apt upgrade -y" works every time.
Quidquid Latine dictum sit, altum sonatur.
#20 2025-05-14 16:33
Re: System update
@willmenn
We recommend you to install Update manager from the Q4OS software center. It will show notification icon in the system tray as soon as any updates are available.
#21 2025-05-14 19:13
Re: System update
Nothing wrong with CLI but installing update manager to  notify and using package managers like Synaptic are still a good option.
