#1 2025-01-06 15:52
Luigi
Text Editor only
Hi, I have Q4OS-Trinity recently, and I would like a text editor that is as light and simple as possible, especially for txt format.
I have tried Kwrite, but it does not allow me (or I am not able) to underline text or highlight it.
I would also like to avoid something like Openoffice, due to size issues.
From forum searches I have had no results, and from the web it seems rather confusing, some say one thing, some another, some that I have to install wine, and I would like to avoid that.
What do you recommend, and above all could you tell me the procedure?
Thank you
#2 2025-01-06 16:18
Re: Text Editor only
You could check kword-trinity, install it from package manager or from command line:
$ sudo apt install kword-trinity
#3 2025-01-06 17:23
Luigi
Thank you, I will try it now.
Is perfect, thanks!
#4 2025-01-06 22:28
You could try Kate as its a great text editor and its fairly light.
#5 2025-01-07 11:00
Luigi
thanks.
#6 2025-01-07 21:32
Kate is actually the default text editor with a lot of distros that use Trinity. Hope it works out for you.
