#1 2024-08-08 12:07
Ventus
Installation without user error
Hello,
I had installed q4os from an windows old laptop because it was slow with windows.
On the process of installation, it asks you for creating an user and a password. I didn't want the laptop with a password to work on it so I put an ne for the user and I let in blank the password, but it doesn't work, you may put an password.
So I went back the steps of installation and it shows an screen with all the steps, I was on the user and password one and I skiped it to the next one.
It installed properly and when it started, It asks an user and password, there apears an user that has the name that I have tried to create, but it doesn't have password so I can't login on the laptop.
I tried with a flash drive to install again windows 10 but the screen of installation doesn't appear.
What can I do?
Thanks
#2 2024-08-08 12:14
Re: Installation without user error
What Q4OS installation media did you use ? What login screen are you experiencing, a screenshot would be helpful ?
#3 2024-08-08 12:17
Ventus
I had installed q4os aquarius, trinity, install-cd -64 bit.
How can I uploade an picture here?
#4 2024-08-08 12:24
Post reply > attachment > choose file > up to 300kb
#5 2024-08-08 12:25
Well, are you able to log in with empty password ?
#6 2024-08-08 12:25
Senas Komunistas
Hello.
Simply take a screenshot, upload it to this site https://postimages.org/, copy the link and paste link to your screenshot in your message here.
#7 2024-08-08 12:28
Ventus
No, I can't log in without password
#8 2024-08-08 12:29
Ventus
Image of the login screen: https://i.postimg.cc/jqX3mtnB/Imagen-de … b4cc4d.jpg
#9 2024-08-08 12:37
You need to type your username "q4os" into the username field, let password empty and click on login button. What will happen ?
#10 2024-08-08 12:41
Ventus
It says login failed.
I also can start aquarius on recovery mode. That's all, but windows doesn't appear.
#11 2024-08-08 12:47
So, if you can start the recovery mode, you should be able to set a password for the user with terminal command:
# passwd q4os
set the password, reboot, try to login and post back
#13 2024-08-08 13:00
You can also try to switch to console:
Menu > Console login > login with your username and empty password > change your password as described above
If it will not work, we would recommend you to install Q4OS once again, set a password for the first user. You will be able to setup automatic passwordless login from the Welcome screen.
#14 2024-08-08 13:03
Ventus
Okay, thank you, but I tried to install it againg and it doesn't appear the installation screen neither the windows one for ereasing q4os and install it
#15 2024-08-08 13:08
Ventus
#16 2024-08-08 13:10
You need to boot from the install media, exactly the same way as you did it before. Tap some keyboard shortcut throughout the boot, for example F11, to get the boot menu table. It differs by hardware, see https://www.q4os.org/dqa014.html#boome
#17 2024-08-08 13:16
Ventus
I'm sorry, I don't know much about this things.
Can you help me, please?
https://i.postimg.cc/DwHxLc8c/IMG20240808141611.jpg
#18 2024-08-08 13:36
You need to tap some keyboard shortcut throughout the boot, to get the boot menu table. The following list provides the function keys for common computer manufacturers:
Acer - Esc, F9, F12
ASUS - Esc, F8
Compaq - Esc, F9
Dell - F12
EMachines - F12
HP - Esc, F9
Intel - F10
Lenovo - F8, F10, F12
NEC - F5
Packard Bell - F8
Samsung - Esc, F12
Sony - F11, F12
Toshiba - F12
You must tap the function key immediately after turning on the computer. A menu will appear and you can choose to boot from the installation media.
#19 2024-08-08 13:38
Ventus
Thanks for the help and the quick replying.
#20 2024-08-08 13:40
You're welcome. What's a little weird, the installer doesn't allow you to leave the password blank, so you must have screwed it up somehow.
#21 2024-08-08 13:42
Ventus
I will try to reinstall later, and If I can't, I think I will change the hdd or something.
#22 2024-08-08 13:47
Ventus
Well, I skipped the creation of an user on the installation.
#23 2024-08-08 13:52
How did you do that ? We are not able to reproduce it, so we assume it's not possible.
#24 2024-08-08 13:55
The screen with error appears if you set epty password
#25 2024-08-08 13:58
Ventus
While the installation, you have the option of submit and go back, on the step of cration of an user and password, I saw that it doesn't let you to skip the step or let the password in blank, so I just went back and appeared an menu that sayed something like: where would you like to continue the installation? And there were all the steps of the instalation, I was on creation of user and password and I selected the next step
