#76 2024-03-26 22:11
Re: Q4OS 5 for Raspberry Pi
If you would make some more polished video review of Q4OS (with your theme and tweaks), we could publish it in external links section of our frontpage https://q4os.org/
Yes, I can totally do that smile This little one was just to show quickly the overall reactivity with q4os on the pi 400,(I'll try to do another one more complete with pi 5),  but I think I can do something a lot more polished about Q4os with my win10 theme, not especially with raspberry. I Will try do it in the coming days smile
#77 2024-03-28 11:15
Testing test release 3 on a Raspberry Pi 5 right now, first impressions: really impressive, this is a REAL desktop replacement solution. I'm testing with an sd card, and it is already very good, performance is good and reactivity is night and day with Pi 4. Will try with an usb enclosure with nvme disk as soon as possible. Some videos coming soon smile
#78 2024-03-28 13:08
New testing release "q4os-5.4-rpi.r2-testing4.img.xz" is out for download, see https://www.q4os.org/forum/viewtopic.ph … 261#p26261 . This is considered as first release candidate, so testing is appreciated smile
#79 2024-03-28 17:05
Very good, will test it soon smile
I have made a little video of q4os raspberry test on Pi5: (based on test release 3)
https://youtu.be/pgrMvIIgfVs
(quality not very good, but the camera doesn't like shooting lcd monitor tongue But with raspberry version I have not the choice to run it in a virtual machine, which would be easier to make a movie capture).
I will do a more general Q4OS trinity video with win10 theme and with cleaner image soon smile
#80 2024-03-28 20:57
NoMoreWindows
Nice video. Q4OS + Pi 5 team up very well. Pi 4 is just a bit too slow for me to work on it all day. Your tempting me to buy a Pi 5 which in all honesty, I don't need. (I revived too many old PC's already thank to Q4OS!)
Now I'm gonna try the next test version (4) for Pi.
#81 2024-04-01 10:27
NoMoreWindows
For me there is no difference with (improvement over) test version 3.
- BT issues
- VLC hangup on maximized screen
- some warnings users should not get from software center
I already considered test version 3 a release candidate so version 4 is also a valid release candidate as far as I can see.
#82 2024-04-01 21:11
seb3773 wrote:
I have made a little video ...
Great one smile and the soundtrack, tweeted https://twitter.com/q4osteam/status/1774893934830907439 and https://floss.social/@q4os/112197803477562634
#83 2024-04-02 11:28
NoMoreWindows wrote:
- BT issues
We would need to see if Q4OS receives these issues from PiOS, so a comparison would be helpful.
#84 2024-04-06 19:18
The final release of Q4OS for RPi is out https://sourceforge.net/projects/q4os/files/unofficial/ . This is an unofficial release with limited support. It may become official in the future, if some QA are met. Announcement: https://www.q4os.org/forum/viewtopic.php?id=4852
#85 2024-04-07 16:18
NoMoreWindows
- BT issues
I tried Pi OS 32 bit and did not see the issues.
For Q4OS Pi there are workarounds:
- Reinstall BT
- Run VLC maximized instead of full screen.
#86 2024-05-10 21:34
Crowman
Hi
I am having problems with a Raspberry Pi 5 installation.
I have successfully installed q4os-5.4-rpi.r3 to an SD card.
However, it only boots to a black text screen with terminal options.
I thought with a 1.2GB file, the desktop would have been there?
It won't connect to the internet when I try and install a desktop/lightdm as it refuses to notice the internet connection.
It just throws up errors.
I connect to the internet by tethering an Android phone as I don't have home internet.
Any help would be appreciated as I only use Q4OS now.
Thanks
#87 2024-05-10 22:25
What method did you use to create SD card, details ?
What hardware did you run Q4OS on, details ?
#88 2024-05-11 18:28
Crowman
I used Raspberry Pi Imager to Flash to the SD card (and a USB thumb drive when that didn't work).
the hardware was a Raspberry Pi 5. What exact info do you need?
#89 2024-05-11 18:41
Please use Q4OS imager, or a method recommended https://www.q4os.org/dqa010.html and post back. Q4OS should work on RPi-5 , does anyone else encounter described issue ?
#90 2024-05-12 03:32
Crowman
"E: Unable to locate package q4os-imager" (using another Debian based to try)
Tried from the img file rather than image.xz and it still boots to the black screen with terminal options.
#91 2024-05-12 10:37
Use Q4OS live media.
Crowman wrote:
... still boots to the black screen with terminal options.
Login with initial credentials and run:
$ sudo systemctl restart tdm
$ sudo systemctl status tdm
and post back
$ Run:
$ reportq4
and attach the debug file here, see https://www.q4os.org/forum/viewtopic.php?id=3502
#92 2024-05-13 15:50
Crowman
Using $ sudo systemctl restart tdm got me to the trinity desktop enviroment.
Using $ sudo systemctl status tdm on the black text screen with terminal options (before desktop)
● tdm.service - Trinity Display Manager
     Loaded: loaded (/lib/systemd/system/tdm.service; enabled; preset: enabled)
     Active: inactive (dead)
       Docs: man:tdm-trinity(1)
Using $ sudo systemctl status tdm on desktop enviroment loading
     Active: active (running) since Sun 2024-05-12 12:44:02 BST; 35s ago
    Process: 1434 ExecStartPre=/bin/sh -c [ "$(basename $(cat /etc/X11/default->
   Main PID: 1437 (tdm)
      Tasks: 10 (limit: 4915)
        CPU: 3.047s
     CGroup: /system.slice/tdm.service
             ├─1437 /opt/trinity/bin/tdm
             ├─1439 /usr/lib/xorg/Xorg -br -deferglyphs 16 -nolisten tcp :0 vt7>
             ├─1451 /opt/trinity/bin/tdekbdledsync
             ├─1452 /opt/trinity/bin/tdecryptocardwatcher
             ├─1461 "[tdeinit] tdeinit Running..."
             ├─1466 "dcopserver [tdeinit] --nosid --suicide"
             └─1547 "tdelauncher [tdeinit]"
May 12 12:44:02 raspberrypi systemd[1]: Starting tdm.service - Trinity Display >
May 12 12:44:02 raspberrypi systemd[1]: Started tdm.service - Trinity Display M>
May 12 12:44:15 raspberrypi tdm[1449]: pam_unix(tdm-trinity:session): session o>
lines 1-20/20 (END)
I have attached reportq4
I can get to the desktop using sudo systemctl restart tdm so thanks. I have to use that every time though to get past the terminal screen
#93 2024-05-13 16:03
Thanks, we can investigate this issue, as soon as you attach the report. You could also mail the report on q4os@q4os.org
#94 2024-05-13 16:17
Crowman
I will go email it now.
#95 2024-05-15 12:04
Thanks, we got it. Please also post /var/log/tdm.log after a fresh boot.
#96 2024-05-25 02:29
Crowman
Thanks. I will be able to do this in a few days when I am back.
#97 2024-05-26 10:44
Crowman
I have attached tdm.log
#98 2024-05-27 14:40
@Crowman
Does your Pi-5 model feature dual hdmi video port ? What happens if you connect your display to the second video port ?
#99 2024-05-30 08:01
Crowman
@Crowman
Yes, it has dual video ports.
Nothing different happens on the 2nd port.
I boot as in the 1st port described above.
Is there anything you want posting from the 2nd port boot?
#100 2024-05-30 09:12
We can't find a clue in the logs you have posted so far. We have got reports of successful ran of Q4OS on RPi-5 see https://www.q4os.org/forum/viewtopic.ph … 532#p26532 . You can even see a video of Q4OS running on Pi-5 https://www.youtube.com/watch?v=pgrMvIIgfVs . So there is some difference, what we are looking for.
@seb3773
Are you still in success running Q4OS on your, or some other, RPi-5 board(s) ? What is the exact revision of your Pi5 ?
@Crowman
Does Raspbian Bookworm 32bit run on your board ? When did you buy your board, is it quite new ?
@All
Are there any other users who can confirm success or failure running Q4OS on a Pi-5?
We may release Q4OS for RPi with updated drivers and kernel soon, so it could solve some hardware compatibility issues too.
