I have installed Q4OS5 on /dev/sda2 to replace Q4OS 4.
The installer has created a /home/<user> inside that partition, but my real home directory is on a separate partition, /dev/sda3.
I'd like to add a line into /etc/fstab to have /dev/dsa3 mounted into /home. Unfortunately, I didn't think to make a copy of fstab before installing. I think it should be something like
UUID=35e18f2b-11ad-b8e4-f62135702f22 /home ext4 ?options? ?dump? ?pass?I'd like to know the appropriate parameters for options, dump (0?) and pass (1?)
After having edited /etc/fstab and before rebooting, I suppose I'll have to delete the newly created /home content
$ sudo rm -rf /home/<user>Thanks for your advice.
According to https://www.tecmint.com/convert-home-di … ion-linux/ , the fstab line should look like this:
UUID=[ uid ] /home ext4 defaults 0 2-
We would recommend to move /home to something like /.home.backup for case of need and remove it later.
Thanks a lot.
