#1 2024-03-21 15:44
sub13
Faire une image iso, to do an iso-image
Bonjour
Maintenant que mon q4os est configuré et me convient.
Est'il possible via live-USB de sauvegarder la configuration sous forme d'image iso auto-installable que je pourrai restauré si besoin
Merci
Good morning
Now that my q4os is set up and working for me.
Is it possible via live-USB to save the configuration in the form of a self-installing ISO image that I can restore if necessary
THANKS
Asus Eee PC 1000H Atom N270 à 1.6 GHz ram 2go avec Q4os 3.16.1 centaurus
#2 2024-03-22 10:10
sub13
Re: Faire une image iso, to do an iso-image
Hello
I find Rescuezilla and RedoRescue but only for 64 bits, do you something for 32 bits
Thanks you
#3 2024-03-22 14:08
Germ
Clonezilla and Foxclone will supposedly do 32bit.
https://clonezilla.org/
https://www.foxclone.org/downloads.html
#4 2024-03-22 14:29
sub13
Merci
Thank you
#5 2024-03-23 00:45
Germ
You're welcome
