#1 2023-04-18 18:29
ivandebcn
I can't open files from usb memory
Hello I have a problem.
When I connect the usb memory to the computer I can't open any file... But when I copy those files to the hard drive I can open them without problems. What is happening? Somebody could help me?
I am using Q4OS Trinity
Thank you.
#2 2023-04-18 23:44
PeterLinu
Re: I can't open files from usb memory
Hiyall,
I think you need to format your USB stick as ext4. Remember to back up the contents before!
#3 2023-04-19 02:22
just1acc
PeterLinu wrote:
Hiyall,
Don't format. NTFS/FAT32 is fine. I had also faced that problem with Gemini (Trinity), even during playing media through VLC. Can't remember how it got resolved.
#4 2023-04-19 06:18
This may well be the issue you are describing https://www.q4os.org/forum/viewtopic.php?id=3826
I thought this had been fixed....or maybe it's in the next version in Q4OS 5.......
#5 2023-04-19 11:47
ivandebcn
In addition to not being able to open the files that I have on the usb stick, I can't change the name of these files, I can't delete them, I can't do anything,
Does anyone know the reason? Do I have to change some type of permission? Or what do I have to do?
Thank you
#6 2023-04-19 11:56
PeterLinu
You have;
1. to copy/paste the data to somewhere safe.
2. Format the USB stick to ext4.
3. Copy/paste the data back on to the stick
4. Try 'reading it again
PS: if it's music files, many audio programs are only able to read/play the music if the files are on the computer and then sent to the audio software.
#7 2023-04-19 12:40
PeterLinu wrote:
... Format the USB stick to ext4. ...
No, it's not good advice, don't do that. You should have read/write permissions on different regular filesystems. Try to check, if your USB device could have some write protection switch.
#8 2023-04-19 12:57
ivandebcn
I have check it with another computer (with windows 10) and the usb stick runs ok, I can open all files whithout problems, so i don't know what is happening.
#9 2023-04-19 13:28
PeterLinu
and that's why I gave my advice.
#10 2023-04-19 14:42
EDIT: See solution in post #16.
#11 2023-04-19 15:50
@ivandebcn
Insert the USB stick in and run in terminal:
$ sudo blkid
Post the output here.
#12 2023-04-19 18:04
ivandebcn
/dev/sda1: UUID="93d9588d-5716-4f31-bf6c-dffbccf48adb" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f65e86d9-01"
/dev/sda5: UUID="7c681bec-e94f-44bf-9f2e-1fedd215aaa7" TYPE="swap" PARTUUID="f65e86d9-05"
/dev/sdf1: LABEL_FATBOOT="TOSHIBA" LABEL="TOSHIBA" UUID="04AD-6276" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="40340a3b-01"
#13 2023-04-19 21:19
Does a popup window appear, when you insert the USB stick ? Would you post a screenshot ?
#14 2023-04-20 10:13
ivandebcn
When i try to open files from usb stick:
#15 2023-04-20 10:14
ivandebcn
And this:
#16 2023-04-20 12:33
It seems, you have encountered known Trinity bug https://www.q4os.org/forum/viewtopic.php?id=3826 as @bin mentioned above. It should be fixed in the new Trinity 14.1.0 version, what will be available in the upcoming Q4OS 5 Aquarius edition.
