#1 2023-02-27 19:44
drp
q4os windows installer stuck while downloading
q4os windows installer stuck while downloading...no further progress
#2 2023-02-27 21:25
Re: q4os windows installer stuck while downloading
Which link did you use to download?
Probably you just have to retry after some time.
#3 2023-02-27 22:06
We would recommend just to run the installer once again and repeat the action.
#4 2023-02-28 17:49
drp
I have tried two/three times, the same problem persists...download of the image not completed...installer stucks...showing 2,3, or 5 second remaining...Plz. provide the solution for this problem....
#5 2023-02-28 17:56
drp
Whats the problem.. i m not getting...i also have downloaded the image and installer in the same folder and tried to install like ubuntu with wubi...but the installer not reading the image and directly going downloading image..
#6 2023-02-28 18:12
We will try investigate the issue and post back.
You can also proceed the installation this way:
1. Download the "q4os4a-x64-loop.img.xz" loop image from here:
https://sourceforge.net/projects/q4os/files/loopimage/
2. Run from Windows command line tool "cmd":
q4os-winsetup.exe --dimagepath=c:\absolute_path_to_image\q4os4a-x64-loop.img.xz
What Windows version do you use ?
Does anyone else notice this issue ?
#7 2023-02-28 18:16
drp
02-28 22:39 ERROR  TaskList: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\Linux64\\Debian11\\disks\\q4os4a-x64-loop.img.xz'
Traceback (most recent call last):
  File "\lib\wubi\backends\common\tasklist.py", line 197, in __call__
  File "\lib\wubi\backends\common\backend.py", line 613, in get_diskimage
  File "\lib\wubi\backends\common\backend.py", line 402, in download_diskimage
WindowsError: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\Linux64\\Debian11\\disks\\q4os4a-x64-loop.img.xz'
02-28 22:39 DEBUG  TaskList: # Cancelling tasklist
02-28 22:39 DEBUG  TaskList: # Finished tasklist
02-28 22:39 ERROR  root: [Error 32] The process cannot access the file because it is being used by another process: 'E:\\Linux64\\Debian11\\disks\\q4os4a-x64-loop.img.xz'
  File "\lib\wubi\application.py", line 58, in run
  File "\lib\wubi\application.py", line 132, in select_task
  File "\lib\wubi\application.py", line 162, in run_installer
#8 2023-02-28 18:19
Maybe the downloaded file is being checked or blocked by an Antivirus software ?
#9 2023-02-28 18:21
drp
Windows 10 Pro
#10 2023-02-28 18:27
(deleted)
Edit:
Sorry, q4osteam already responded while I was writing.
#11 2023-02-28 18:37
drp
Ok i will try...
#12 2023-02-28 19:07
drp
Not working...
#13 2023-02-28 19:09
drp wrote:
Not working...
Any message ? A screenshot would be helpful.
#14 2023-02-28 19:33
drp
drp wrote:
The same problem...installer stucks/stops.. no progress...antivirus disabled...still problem..
Error Message;
The process can not access the file because it is used by another process...see the logfile...
02-28 23:42 DEBUG  TaskList: ## Finished choose_disk_sizes
02-28 23:42 DEBUG  TaskList: ## Running create_preseed_diskimage...
02-28 23:42 DEBUG  TaskList: ## Finished create_preseed_diskimage
02-28 23:42 DEBUG  TaskList: ## Running get_diskimage...
02-28 23:42 DEBUG  TaskList: New task download
02-28 23:42 DEBUG  TaskList: ### Running download...
02-28 23:42 DEBUG  downloader: downloading https://github.com/q4osteam/q4os-instal … oop.img.xz > C:\Linux64\Debian11\disks\q4os4a-x64-loop.img.xz
02-28 23:42 DEBUG  downloader: Download start filename=C:\Linux64\Debian11\disks\q4os4a-x64-loop.img.xz, url=https://github.com/q4osteam/q4os-install-media/releases/download/v4/q4os4a-x64-loop.img.xz, basename=q4os4a-x64-loop.img.xz, length=911768820, text=None
02-28 23:47 DEBUG  downloader: download finished (read 525541376 bytes)
02-28 23:47 DEBUG  TaskList: ### Finished download
02-28 23:47 ERROR  TaskList: [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host
  File "\lib\wubi\backends\common\downloader.py", line 77, in download
  File "\lib\urlgrabber\grabber.py", line 927, in urlgrab
  File "\lib\urlgrabber\grabber.py", line 845, in _retry
  File "\lib\urlgrabber\grabber.py", line 915, in retryfunc
  File "\lib\urlgrabber\grabber.py", line 1208, in _do_grab
  File "\lib\urlgrabber\grabber.py", line 1274, in read
  File "\lib\urlgrabber\grabber.py", line 1253, in _fill_buffer
URLGrabError: [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host
02-28 23:47 ERROR  TaskList: Non fatal error [Errno 4] Socket Error: [Errno 10054] An existing connection was forcibly closed by the remote host in task download
02-28 23:47 ERROR  TaskList: [Error 32] The process cannot access the file because it is being used by another process: 'C:\\Linux64\\Debian11\\disks\\q4os4a-x64-loop.img.xz'
WindowsError: [Error 32] The process cannot access the file because it is being used by another process: 'C:\\Linux64\\Debian11\\disks\\q4os4a-x64-loop.img.xz'
02-28 23:47 DEBUG  TaskList: # Cancelling tasklist
02-28 23:47 DEBUG  TaskList: # Finished tasklist
02-28 23:47 ERROR  root: [Error 32] The process cannot access the file because it is being used by another process: 'C:\\Linux64\\Debian11\\disks\\q4os4a-x64-loop.img.xz'
#15 2023-02-28 19:58
The logfile you have provided shows installer tries to download the loop file. Please run commands in the "cmd" tool and post the output, preferably a screenshot:
> cd c:\absolute_path_to_image
> dir
#16 2023-02-28 20:11
drp
> dir
From where to download "q4os4a-x64-loop.img.xz
#17 2023-03-01 05:15
drp
Thank you its working.......
