#1 2023-02-22 23:13
PeterLinu
[SOLVED] Anydesk
Hiyall,
I am running Q4OS 32bit on an old laptop. I want to install Anydesk. I downloaded a 32bit version (.deb) but it won't install.
Can someone help, please?
#2 2023-02-23 00:00
PeterLinu
Re: [SOLVED] Anydesk
It seems that neither Anydesk nor TeamViewer will work on 32bit Q4OS. Can someone suggest a program that will work, please?
#3 2023-02-23 08:19
What was the problem? Any error message?
From this Anydesk page I see that i386 and i686 32 bit versions (6.0.1) are still available for download, although the latest 64 bit version seems to be 6.2.1.
#4 2023-02-23 10:57
PeterLinu
Message I get is:
"TDEInit could not launch /home/Peter/Desktop/anydesk_6.0.1-1_i386.deb"
#5 2023-02-23 11:50
PeterLinu
I tried the '686.deb' with the same result.
#6 2023-02-23 12:17
You need to run the command from terminal:
$ sudo apt install /home/Peter/Desktop/anydesk_6.0.1-1_i386.deb
You could also give a try experimental Q4OS installer, see https://www.q4os.org/forum/viewtopic.php?id=3624
#7 2023-02-23 12:37
0ver2
You could use
https://github.com/dchapyshev/aspia
https://github.com/Ylianst/MeshCentral (web-based)
or classical Linux VNC technology with something popular like
https://github.com/TigerVNC/tigervnc (but for 32bit you need to build it from source)
#8 2023-02-23 12:42
PeterLinu
Hi Team,
The experimental Anydesk installed as easy as pie.
Thank you.
