Hello,
after installing Q4OS 4.10, i don't have a swappfile, not present in fstab. I do have a swap partition.
Desktop is trinity.
In q4os 3.15 it workt perfectly.
thanks
Kevin
During installation the Calamares partition tool allows you to define the file system for each partition. Your swap ptn could be sda2, 3, 4, 5 or whatever. If you told it to set that ptn as SWAP file system then that's all you need.
If the swap ptn is from a previous install it will not just be automatically picked up on a new install.
There's a world of difference between a swap file and swap partition.
Please run
inxi -SMCGxPand copy/paste output here.
Hello,
results of inxi -SMCGxP
quicky@quicky-pr111:~$ inxi -SMCGxP
System:
Host: quicky-pr111 Kernel: 5.10.0-19-amd64 x86_64 bits: 64 compiler: gcc
v: 10.2.1 Desktop: Trinity R14.0.12 Distro: Q4OS 4.10.2-n1
base: Debian GNU/Linux 11 (bullseye)
Machine:
Type: Desktop Mobo: Intel model: PR111 v: 1.0
serial: <superuser required> BIOS: American Megatrends v: L1.03
date: 10/21/2010
CPU:
Info: Quad Core model: Intel Core2 Quad Q8200 bits: 64 type: MCP
arch: Penryn rev: 7 L2 cache: 2 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 18663
Speed: 2000 MHz min/max: 2003/2336 MHz Core speeds (MHz): 1: 2000 2: 2000
3: 2000 4: 2000
Graphics:
Device-1: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series]
vendor: Micro-Star MSI driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1280x1024~60Hz
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.10.0-19-amd64 LLVM 11.0.1)
v: 3.3 Mesa 20.3.5 direct render: Yes
Partition:
ID-1: / size: 31.21 GiB used: 8.5 GiB (27.3%) fs: ext4 dev: /dev/sda9
grts,
Kevin
So there's no swap partition defined.
Are you expecting to share one with the other OS on your drive?
Do you feel you need swap - haven't bothered with it for years on anything with 4gb ram or more.
A swap partition isn't required anymore, it seems -- and for safety proofing, a swap file can be enough...
E.g., a set of instructions is at linuxize.com/post/how-to-add-swap-space-on-debian-10/, it should still work.
OK, thanks,
i have a swapfile of 4GiB,
the swapfile is used by Linux Mint 18.3 & Linux Mint 20.3 & Maegia 8 end before Q4OS 3.15 on the same HD without problems.
grts,
Kevin
Solution,
i did a blkid & added to fstab.
UUID=8678ec49-4e91-4074-809a-bf22b2c76b89 none swap sw 0 0
