#1 2022-11-02 13:03
johnnyh4
Installation in VirtualBox for Desktop mode boots to command line only
(q4os-4.10-x64-tde.r2)
Installation in VirtualBox for Desktop mode boots to command line only.
(Saw the same problem posted by somebody else on the Site; they were told to go to the (this) Forum, but I did not find it nor any response here)
#2 2022-11-02 13:07
Re: Installation in VirtualBox for Desktop mode boots to command line only
What Virtualbox version and configuration ? The installation works fine here Virtualbox 6.0.24 configured for 64bit Debian Linux guest
#3 2022-11-02 13:12
johnnyh4
Version 6.1.40 r154048 (Qt5.15.2) 64 bit
[ Team: Thanks for immediate response  ;-)  ]
#4 2022-11-02 13:15
What host ? Windows/Linux/MacOS
#5 2022-11-02 13:17
johnnyh4
Oops - forgot to confirm for Debian Linux guest
In case it matters host's running on Devuan Stable, up-to-date.
#6 2022-11-02 13:23
Well, we will try testing installation and post back a result later.
#7 2022-11-02 17:35
Testing installation passed fine here.
Virtualbox 6.1.40 r154048 (Qt5.6.2)
  Host: Windows 10
Guest settings, just default:
  Debian Linux 64bit
  1GB RAM
  8GB harddisk
Q4OS installation:
  ISO file: q4os-4.10-x64-tde.r2.iso
  Profile: Basic, Trinity
What desktop profile did you choose upon Q4OS install process ?
#8 2022-11-02 18:02
johnnyh4
Thanks. I selected Desktop, which was one of the options offered by the installer.
I will re-install as Basic as per your testing installation, and report back in due course.
BTW I also used defaults:
  Debian Linux 64bit
  1GB RAM
  8GB harddisk
#9 2022-11-02 18:53
johnnyh4
Works fine now with Basic installation. Thanks very much for excellent support.
#10 2022-11-03 17:11
You can install Q4OS with Desktop profile in Virtualbox, but you need to start with 16GB virtual disk instead of 8GB, as it is not just enough space.
#11 2022-11-03 17:37
johnnyh4
Good to know - thanks again.
