#1 2022-10-06 19:40
jlsborges
Access shared files
I was surprised with the performance of Q4OS Trinity and I would like to use it in my company.
But when testing shared files access, I can't open the files.
I have an Active Directory Server (NethServer), simply by accessing the folder and trying to open the file, Libreoffice opens and closes.
I tested with OnlyOffice and the error also happens.
I can browse the shared folder, create, edit, copy and delete files, I just can't open it.
Tried through Nautilus and get the same error.
Any suggestion?
NOTE: I used Google Translate to write this content. I apologize if there is any sentence that is out of place.
#2 2022-10-06 20:20
jlsborges
Re: Access shared files
I said I accessed it through Nautilus, but it was actually through Dolphin.
I recorded a video to show what is happening.
Can I post the link?
Thanks.
#3 2022-10-06 21:03
jlsborges
I followed the steps in this post:
3600#p23600
- Go to "/usr/share/applications/"
- Locate the .desktop file of the program that doesn't open the file you are trying to open (e.g. VLC would be "vlc.desktop")
- Right-click and select "Edit as system administrator"
- Search for the "Exec=" entry
- Replace the "%U" entry on the same line by "%F"
- Save and test if it now works.
It worked for me.
#4 2022-10-06 22:31
@jlsborges
Your account has been promoted, now you can post links and attach files up to 300kB of size.
