#1 2022-09-26 17:04
hopperman
[SOLVED] Pulse Audio - problem on "toggle mute on/off" keyboard button
Hi, I am a new user of Q4OS. I am highly satisfied to choose Q4OS.
I have small problems, I am using standard desktop environment(Trinity Desktop Environment -TDE).
In my keyboard, there is a mute on/off button and when I used it, it only work for mute on, not for mute off. Although it says "mute off" in the screen, it falses me. Toggle switch did not work, it remained muted. How can I correct it? Thanks.
#2 2022-09-26 17:13
hopperman
Re: [SOLVED] Pulse Audio - problem on "toggle mute on/off" keyboard button
I reinstalled KMix but problem still exist.
#3 2022-09-26 17:44
hopperman
In syslog I found these errors :
Sep 23 04:34:39 q4os-desktop systemd[1]: console-setup.service: Failed with result 'exit-code'.
Sep 23 04:34:39 q4os-desktop systemd[1]: Failed to start Set console font and keymap.
Sep 23 04:34:39 q4os-desktop systemd-udevd[300]: controlC1: Process '/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore 1' failed with exit code 99.
Sep 23 04:34:39 q4os-desktop systemd-udevd[298]: controlC0: Process '/usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore 0' failed with exit code 99.
Sep 23 04:34:39 q4os-desktop alsactl[514]: alsa-lib main.c:1014:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
Sep 23 04:34:39 q4os-desktop alsactl[514]: alsa-lib main.c:1014:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
Sep 23 04:34:41 q4os-desktop avahi-daemon[555]: chroot.c: open() failed: No such file or directory
Sep 23 04:34:41 q4os-desktop avahi-daemon[516]: Failed to open /etc/resolv.conf: Invalid argument
Sep 23 04:34:43 q4os-desktop udisksd[525]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
Sep 23 04:34:44 q4os-desktop udisksd[525]: Failed to load the 'mdraid' libblockdev plugin
Sep 23 04:34:53 q4os-desktop wpa_supplicant[526]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
Sep 23 04:35:58 q4os-desktop pulseaudio[911]: Failed to open cookie file '/home/user/.config/pulse/cookie': No such file or directory
Sep 23 04:35:58 q4os-desktop pulseaudio[911]: Failed to load authentication key '/home/user/.config/pulse/cookie': No such file or directory
Sep 23 04:35:58 q4os-desktop pulseaudio[911]: Failed to open cookie file '/home/user/.pulse-cookie': No such file or directory
I tried the related errorenous command line and got below error in detail :
$ /usr/sbin/alsactl -E HOME=/run/alsa -E XDG_RUNTIME_DIR=/run/alsa/runtime restore 1
/usr/sbin/alsactl: state_lock:125: file /var/lib/alsa/asound.state lock error: File exists
/usr/sbin/alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for reading: File exists
Failed to create secure directory (/run/alsa/runtime/pulse): Permission denied
alsa-lib parser.c:260:(error_node) UCM is not supported for this HDA model (HDA ATI HDMI at 0xf5010000 irq 27)
Found hardware: "HDA-Intel" "ATI R6xx HDMI" "HDA:1002aa01,00aa0100,00100100" "0x1043" "0xaa38"
Hardware is initialized using a generic method
Then , since it says permission denied, I tried the same command as root and it gives no error, but problem is still there.
I checked that is there a "cookie file" under  /home/user/.config/pulse/ it exists, but not  "/home/user/.pulse-cookie" file or directory.
Thanks.
#4 2022-09-26 17:52
hopperman
I reinstalled pulse audio package and reboot.
All journal errors about "alsa" and "pulse audio" disappeared but toggle button error still exists.
#5 2022-09-26 18:23
hopperman
Oh my god, although I searched the forum before posting I could not find this thread which is the exactly the same issue with mine :
in the forum pages with "id=3667" ( I could not write a page name since it contains php? forum does not allow it)
In there, it is saying that is is a well know bug and will be solved in Gemini. I am using  :
Desktop :Trinity R14.0.12
Distro : Q4OS 4.10.2-n1 (Gemini)
I tried using Humming Owl's "keyboard-action" input mapping method(i.e using Alt+M) but none of the commands worked as expected. I do not know why?
But same thing still exists. Is there any solution to it?
#6 2022-09-27 07:53
Yes, we can confirm this bug, unfortunately we know no solution at the moment. It apparently persists in O4OS Gemini Trinity desktop R14.0.12. We have concluded this is a Trinity bug, so it should be appropriate to report that for TDE developers. The identical issue has been reported in the past https://www.q4os.org/forum/viewtopic.php?id=3667
#7 2022-09-28 11:39
hopperman
Thanks, I will do as you said.
#8 2022-10-05 19:26
hopperman
Update :
I did these :
1. removed kmilo package by using
sudo apt remove kmilo
2. restarted my machine
3. deleted the XF86_Mute shortcut key from KMix
and now, my button worked without any problem. That is the solution for me.
