Hi Team,
am so happy to join the Q4OS community. I have old desktop with Intel Pentium D 2.66 Ghz processor and 2 GB RAM. Please find the more details below.
Operating System: Debian GNU/Linux 11
KDE Plasma Version: 5.20.5
KDE Frameworks Version: 5.78.0
Qt Version: 5.15.2
Kernel Version: 5.10.0-16-amd64
OS Type: 64-bit
Processors: 2 × Intel® Pentium® D CPU 2.66GHz
Memory: 1.9 GiB of RAM
Graphics Processor: Mesa DRI Intel® 945G
The desktop doesn't have inbuilt support for Wifi, wireless keyboard and audio devices. So I bought external dongles to enhance the system which works great except for the Headphones. I have read many posts on this forum related to audio issues but didn't found anything that matches my issue. So i collected the information about the audio driver suggested in a post and please find the details below.
Link to the alsa report report
alsa-project.org/db/?f=7ef5a131062b47fb7ab4db7a69bd1477d4fe494f
Is this headset being used via Bluetooth dongle, 3.5mm jack, or USB? We need more information to proceed.
Hi Team,
Sorry for the delay in reply.
I have tried 2 options. 1 Boat R_510 bluetooth headset ( https://www.boat-lifestyle.com/products/rockerz-510 ) and Zebronics Zeb-County 3 ( https://zebronics.com/collections/wirel … b-county-3 )
Both has options to connect via Bluetooth, Aux, or USB. but my computer doesn't have hardware for Bluetooth, so I have tried using AUX/USB.
Kindly guide me the installation, if its bcz of some missing drivers.
regards,
Ragunath
So the Aux connection should "just work" if all features of your sound card is working (most specifically headphone port,which is odd since I'm pretty sure that's the hp_out in devices of your alsa report). When you put it in USB mode and plug it in, can you verify that the system even SEES that it got plugged in (dmesg, look for anything about multimedia devices in the last 50 or so lines)?
Hello, am not sure if you asked for this, but i pulled this from not last 50 lines. but more top. I can retry if you give exact command or instructions.
2.506883] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000429-0x0000000000000429 (\PM2S) (20200925/utaddress-204)
[ 2.506897] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.506902] ACPI Warning: SystemIO range 0x00000000000004B0-0x00000000000004BF conflicts with OpRegion 0x00000000000004B8-0x00000000000004BB (\GPO2) (20200925/utaddress-204)
[ 2.506911] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.506913] ACPI Warning: SystemIO range 0x0000000000000480-0x00000000000004AF conflicts with OpRegion 0x000000000000048C-0x000000000000048F (\GPO) (20200925/utaddress-204)
[ 2.506921] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.506923] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 2.514117] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 2.514784] i2c i2c-0: 1/4 memory slots populated (from DMI)
[ 2.521170] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 2.532749] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 2.532759] 8139cp 0000:02:04.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 2.551315] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 2.552758] 8139too 0000:02:04.0 eth0: RealTek RTL8139 at 0x(____ptrval____), 00:30:18:ae:fe:26, IRQ 19
[ 2.576584] SCSI subsystem initialized
[ 2.577353] ACPI: bus type USB registered
[ 2.577410] usbcore: registered new interface driver usbfs
[ 2.577433] usbcore: registered new interface driver hub
[ 2.577466] usbcore: registered new device driver usb
[ 2.600041] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.603248] ehci-pci: EHCI PCI platform driver
[ 2.603539] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 2.603552] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 2.605637] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.607476] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 2.607507] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfdfff000
[ 2.620194] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.620364] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.620368] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.620371] usb usb1: Product: EHCI Host Controller
[ 2.620373] usb usb1: Manufacturer: Linux 5.10.0-16-amd64 ehci_hcd
[ 2.620376] usb usb1: SerialNumber: 0000:00:1d.7
[ 2.620716] hub 1-0:1.0: USB hub found
[ 2.620737] hub 1-0:1.0: 8 ports detected
[ 2.625593] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.625615] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 2.625655] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 2.625687] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fe00
[ 2.626612] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.626617] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.626622] usb usb2: Product: UHCI Host Controller
[ 2.626624] usb usb2: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.626627] usb usb2: SerialNumber: 0000:00:1d.0
[ 2.627640] hub 2-0:1.0: USB hub found
[ 2.627660] hub 2-0:1.0: 2 ports detected
[ 2.629053] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.629068] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 2.629080] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 2.629110] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fd00
[ 2.630059] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.630064] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.630067] usb usb3: Product: UHCI Host Controller
[ 2.630069] usb usb3: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.630072] usb usb3: SerialNumber: 0000:00:1d.1
[ 2.631055] hub 3-0:1.0: USB hub found
[ 2.631076] hub 3-0:1.0: 2 ports detected
[ 2.631652] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 2.631665] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 2.631675] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 2.631725] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fc00
[ 2.634270] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.634276] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.634280] usb usb4: Product: UHCI Host Controller
[ 2.634283] usb usb4: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.634286] usb usb4: SerialNumber: 0000:00:1d.2
[ 2.636858] hub 4-0:1.0: USB hub found
[ 2.636879] hub 4-0:1.0: 2 ports detected
[ 2.637425] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 2.637437] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 2.637449] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 2.637497] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fb00
[ 2.638352] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.638357] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.638361] usb usb5: Product: UHCI Host Controller
[ 2.638363] usb usb5: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.638366] usb usb5: SerialNumber: 0000:00:1d.3
[ 2.639084] hub 5-0:1.0: USB hub found
[ 2.639103] hub 5-0:1.0: 2 ports detected
[ 2.647780] libata version 3.00 loaded.
[ 2.649879] 8139too 0000:02:04.0 enp2s4: renamed from eth0
[ 2.653673] ata_piix 0000:00:1f.2: version 2.13
[ 2.653860] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 2.657070] scsi host0: ata_piix
[ 2.657427] scsi host1: ata_piix
[ 2.657545] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf800 irq 14
[ 2.657550] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf808 irq 15
[ 2.848309] ata2.00: ATAPI: ATAPI iHAS124 F, CL08, max UDMA/133
[ 2.884167] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 2.891740] ata2.01: ATA-7: ST3160212SCE, 3.ACF, max UDMA/133
[ 2.891745] ata2.01: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.970437] scsi 1:0:0:0: CD-ROM ATAPI iHAS124 F CL08 PQ: 0 ANSI: 5
[ 2.976159] tsc: Refined TSC clocksource calibration: 2666.665 MHz
[ 2.976170] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26703c1dc80, max_idle_ns: 440795287231 ns
[ 2.976200] clocksource: Switched to clocksource tsc
[ 2.999803] scsi 1:0:1:0: Direct-Access ATA ST3160212SCE F PQ: 0 ANSI: 5
[ 3.049805] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.55
[ 3.049813] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.049817] usb 1-1: Product: USB2.1 Hub
[ 3.049819] usb 1-1: Manufacturer: GenesysLogic
[ 3.050258] hub 1-1:1.0: USB hub found
[ 3.050548] hub 1-1:1.0: 4 ports detected
[ 3.054931] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.054940] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.112326] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 3.175521] sd 1:0:1:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 3.175553] sd 1:0:1:0: [sda] Write Protect is off
[ 3.175557] sd 1:0:1:0: [sda] Mode Sense: 00 3a 00 00
[ 3.175597] sd 1:0:1:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.296274] sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 3.359442] sd 1:0:1:0: [sda] Attached SCSI disk
[ 3.364203] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
[ 3.497050] usb 1-1.1: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
[ 3.497058] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.497061] usb 1-1.1: Product: 802.11n NIC
[ 3.497063] usb 1-1.1: Manufacturer: Realtek
[ 3.497066] usb 1-1.1: SerialNumber: 00E04C0001
[ 3.600163] usb 1-1.4: new full-speed USB device number 4 using ehci-pci
[ 3.734423] usb 1-1.4: New USB device found, idVendor=25a7, idProduct=fa67, bcdDevice= 7.00
[ 3.734428] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.734431] usb 1-1.4: Product: 2.4G Receiver
[ 3.734434] usb 1-1.4: Manufacturer: CX
[ 3.746900] hid: raw HID events driver (C) Jiri Kosina
[ 3.756865] usbcore: registered new interface driver usbhid
[ 3.756870] usbhid: USB HID core driver
[ 3.762380] input: CX 2.4G Receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.4/1-1.4:1.0/0003:25A7:FA67.0001/input/input1
[ 3.821234] hid-generic 0003:25A7:FA67.0001: input,hidraw0: USB HID v1.10 Keyboard [CX 2.4G Receiver] on usb-0000:00:1d.7-1.4/input0
[ 3.822475] input: CX 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA67.0002/input/input2
[ 3.822968] input: CX 2.4G Receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA67.0002/input/input3
[ 3.823228] input: CX 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA67.0002/input/input4
[ 3.880467] input: CX 2.4G Receiver System Control as /devices/pci0000:00/0000:00:1d.7/usb1/1-1/1-1.4/1-1.4:1.1/0003:25A7:FA67.0002/input/input5
[ 3.881433] hid-generic 0003:25A7:FA67.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [CX 2.4G Receiver] on usb-0000:00:1d.7-1.4/input1
[ 6.853532] fuse: init (API version 7.32)
[ 8.640205] loop: module loaded
[ 9.894166] random: crng init done
[ 10.120992] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
[ 10.408535] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 11.726116] systemd[1]: RTC configured in localtime, applying delta of 330 minutes to system time.
[ 11.726175] systemd[1]: System time before build time, advancing clock.
[ 12.153448] systemd[1]: Inserted module 'autofs4'
[ 12.382216] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 12.382533] systemd[1]: Detected architecture x86-64.
[ 12.411624] systemd[1]: Set hostname to <q4os-pc>.
regards,
Ragunath
This is after plugging your headset in? This looks like a dmesg of a system that was just booted.
Took this after some time deom boot. do the device not detected? i can see keyboard, mouse and wlan !
[ 2.509478] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.509510] ACPI Warning: SystemIO range 0x00000000000004B0-0x00000000000004BF conflicts with OpRegion 0x00000000000004B8-0x00000000000004BB (\GPO2) (20200925/utaddress-204)
[ 2.509520] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.509523] ACPI Warning: SystemIO range 0x0000000000000480-0x00000000000004AF conflicts with OpRegion 0x000000000000048C-0x000000000000048F (\GPO) (20200925/utaddress-204)
[ 2.509531] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 2.509533] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 2.510199] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 2.522588] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 2.522601] 8139cp 0000:02:04.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 2.531055] Floppy drive(s): fd0 is 1.44M
[ 2.553806] SCSI subsystem initialized
[ 2.562388] FDC 0 is a post-1991 82077
[ 2.564837] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 2.567251] 8139too 0000:02:04.0 eth0: RealTek RTL8139 at 0x(____ptrval____), 00:30:18:ae:fe:26, IRQ 19
[ 2.575422] ACPI: bus type USB registered
[ 2.576680] usbcore: registered new interface driver usbfs
[ 2.576714] usbcore: registered new interface driver hub
[ 2.576748] usbcore: registered new device driver usb
[ 2.596701] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.601146] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.603615] ehci-pci: EHCI PCI platform driver
[ 2.614637] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.614657] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 2.614671] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 2.614718] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000fe00
[ 2.615529] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.615535] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.615538] usb usb1: Product: UHCI Host Controller
[ 2.615541] usb usb1: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.615543] usb usb1: SerialNumber: 0000:00:1d.0
[ 2.617115] hub 1-0:1.0: USB hub found
[ 2.617137] hub 1-0:1.0: 2 ports detected
[ 2.618391] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 2.618411] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 2.622341] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 2.631409] 8139too 0000:02:04.0 enp2s4: renamed from eth0
[ 2.632471] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfdfff000
[ 2.633266] libata version 3.00 loaded.
[ 2.636630] ata_piix 0000:00:1f.2: version 2.13
[ 2.636811] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 2.638611] scsi host0: ata_piix
[ 2.639435] scsi host1: ata_piix
[ 2.639828] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf800 irq 14
[ 2.639832] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf808 irq 15
[ 2.649426] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.649596] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.649600] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.649604] usb usb2: Product: EHCI Host Controller
[ 2.649608] usb usb2: Manufacturer: Linux 5.10.0-16-amd64 ehci_hcd
[ 2.649610] usb usb2: SerialNumber: 0000:00:1d.7
[ 2.649899] hub 2-0:1.0: USB hub found
[ 2.649933] hub 2-0:1.0: 8 ports detected
[ 2.677568] hub 1-0:1.0: USB hub found
[ 2.677593] hub 1-0:1.0: 2 ports detected
[ 2.677834] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.677861] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 2.677877] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 2.677911] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000fd00
[ 2.678092] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.678096] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.678099] usb usb3: Product: UHCI Host Controller
[ 2.678102] usb usb3: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.678104] usb usb3: SerialNumber: 0000:00:1d.1
[ 2.679002] hub 3-0:1.0: USB hub found
[ 2.679024] hub 3-0:1.0: 2 ports detected
[ 2.679641] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 2.679653] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 2.679664] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 2.679714] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000fc00
[ 2.679901] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.679905] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.679908] usb usb4: Product: UHCI Host Controller
[ 2.679911] usb usb4: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.679913] usb usb4: SerialNumber: 0000:00:1d.2
[ 2.680199] hub 4-0:1.0: USB hub found
[ 2.680221] hub 4-0:1.0: 2 ports detected
[ 2.680670] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 2.680681] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 2.680690] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 2.680727] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000fb00
[ 2.680880] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 2.680884] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.680887] usb usb5: Product: UHCI Host Controller
[ 2.680889] usb usb5: Manufacturer: Linux 5.10.0-16-amd64 uhci_hcd
[ 2.680892] usb usb5: SerialNumber: 0000:00:1d.3
[ 2.681124] hub 5-0:1.0: USB hub found
[ 2.681141] hub 5-0:1.0: 2 ports detected
[ 2.829551] ata2.00: ATAPI: ATAPI iHAS124 F, CL08, max UDMA/133
[ 2.872927] ata2.01: ATA-7: ST3160212SCE, 3.ACF, max UDMA/133
[ 2.872931] ata2.01: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.905409] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 2.951963] scsi 1:0:0:0: CD-ROM ATAPI iHAS124 F CL08 PQ: 0 ANSI: 5
[ 2.973679] tsc: Refined TSC clocksource calibration: 2666.665 MHz
[ 2.973689] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26703c1dc80, max_idle_ns: 440795287231 ns
[ 2.973719] clocksource: Switched to clocksource tsc
[ 2.981646] scsi 1:0:1:0: Direct-Access ATA ST3160212SCE F PQ: 0 ANSI: 5
[ 3.042520] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 3.042527] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 3.063788] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.55
[ 3.063796] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.063799] usb 2-1: Product: USB2.1 Hub
[ 3.063802] usb 2-1: Manufacturer: GenesysLogic
[ 3.064248] hub 2-1:1.0: USB hub found
[ 3.064661] hub 2-1:1.0: 4 ports detected
[ 3.105496] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 3.108593] sd 1:0:1:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 3.108623] sd 1:0:1:0: [sda] Write Protect is off
[ 3.108628] sd 1:0:1:0: [sda] Mode Sense: 00 3a 00 00
[ 3.108667] sd 1:0:1:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.202381] sda: sda1 sda2 sda3 sda4 < sda5 sda6 >
[ 3.217713] sd 1:0:1:0: [sda] Attached SCSI disk
[ 3.381428] usb 2-1.1: new high-speed USB device number 3 using ehci-pci
[ 3.518290] usb 2-1.1: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
[ 3.518296] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.518300] usb 2-1.1: Product: 802.11n NIC
[ 3.518302] usb 2-1.1: Manufacturer: Realtek
[ 3.518305] usb 2-1.1: SerialNumber: 00E04C0001
[ 3.621420] usb 2-1.4: new full-speed USB device number 4 using ehci-pci
[ 3.755668] usb 2-1.4: New USB device found, idVendor=25a7, idProduct=fa67, bcdDevice= 7.00
[ 3.755676] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.755679] usb 2-1.4: Product: 2.4G Receiver
[ 3.755681] usb 2-1.4: Manufacturer: CX
[ 3.768124] hid: raw HID events driver (C) Jiri Kosina
[ 3.777237] usbcore: registered new interface driver usbhid
[ 3.777242] usbhid: USB HID core driver
[ 3.782685] input: CX 2.4G Receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.0/0003:25A7:FA67.0001/input/input1
[ 3.841730] hid-generic 0003:25A7:FA67.0001: input,hidraw0: USB HID v1.10 Keyboard [CX 2.4G Receiver] on usb-0000:00:1d.7-1.4/input0
[ 3.842638] input: CX 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:25A7:FA67.0002/input/input2
[ 3.842774] input: CX 2.4G Receiver as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:25A7:FA67.0002/input/input3
[ 3.842863] input: CX 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:25A7:FA67.0002/input/input4
[ 3.901513] input: CX 2.4G Receiver System Control as /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1.4/2-1.4:1.1/0003:25A7:FA67.0002/input/input5
[ 3.901716] hid-generic 0003:25A7:FA67.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [CX 2.4G Receiver] on usb-0000:00:1d.7-1.4/input1
[ 6.938720] fuse: init (API version 7.32)
[ 8.745462] loop: module loaded
[ 9.448421] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
[ 9.545864] random: crng init done
[ 9.681783] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 11.015931] systemd[1]: RTC configured in localtime, applying delta of 330 minutes to system time.
[ 11.015989] systemd[1]: System time before build time, advancing clock.
[ 11.501588] systemd[1]: Inserted module 'autofs4'
[ 11.746964] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 11.747282] systemd[1]: Detected architecture x86-64.
[ 11.776408] systemd[1]: Set hostname to <q4os-pc>.
[ 14.163210] systemd-fstab-generator[192]: Checking was requested for "/mnt/host/Linux64/Debian11/disks/root.disk", but it is not a device.
[ 15.711790] systemd[1]: mnt-host.mount: Unit is bound to inactive unit dev-sda5.device. Stopping, too.
[ 15.713957] systemd[1]: Queued start job for default target Graphical Interface.
[ 15.716786] systemd[1]: Created slice system-getty.slice.
[ 15.718025] systemd[1]: Created slice system-modprobe.slice.
[ 15.718917] systemd[1]: Created slice User and Session Slice.
[ 15.719333] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 15.719655] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 15.720313] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 15.720621] systemd[1]: Reached target Local Encrypted Volumes.
[ 15.720881] systemd[1]: Reached target User and Group Name Lookups.
[ 15.721087] systemd[1]: Reached target Slices.
[ 15.731919] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 15.732615] systemd[1]: Listening on Syslog Socket.
[ 15.732995] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 15.733802] systemd[1]: Listening on Journal Audit Socket.
[ 15.734334] systemd[1]: Listening on Journal Socket (/dev/log).
[ 15.734914] systemd[1]: Listening on Journal Socket.
[ 15.745104] systemd[1]: Listening on udev Control Socket.
[ 15.745796] systemd[1]: Listening on udev Kernel Socket.
[ 15.748418] systemd[1]: Mounting Huge Pages File System...
[ 15.751700] systemd[1]: Mounting POSIX Message Queue File System...
[ 15.755053] systemd[1]: Mounting RPC Pipe File System...
[ 15.758446] systemd[1]: Mounting Kernel Debug File System...
[ 15.761762] systemd[1]: Mounting Kernel Trace File System...
[ 15.762514] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 15.766091] systemd[1]: Starting Set the console keyboard layout...
[ 15.770148] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 15.774410] systemd[1]: Starting Load Kernel Module configfs...
[ 15.780221] systemd[1]: Starting Load Kernel Module drm...
[ 15.803926] systemd[1]: Starting Load Kernel Module fuse...
[ 15.923597] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 15.928493] systemd[1]: Starting Journal Service...
[ 16.084579] systemd[1]: Starting Load Kernel Modules...
[ 16.087645] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 16.090510] systemd[1]: Starting Coldplug All udev Devices...
[ 16.093567] systemd[1]: Starting Uncomplicated firewall...
[ 16.102104] systemd[1]: Mounted Huge Pages File System.
[ 16.102677] systemd[1]: Mounted POSIX Message Queue File System.
[ 16.103124] systemd[1]: Mounted Kernel Debug File System.
[ 16.103575] systemd[1]: Mounted Kernel Trace File System.
[ 16.104674] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 16.105893] systemd[1]: modprobe@configfs.service: Succeeded.
[ 16.106586] systemd[1]: Finished Load Kernel Module configfs.
[ 16.107643] systemd[1]: modprobe@fuse.service: Succeeded.
[ 16.108310] systemd[1]: Finished Load Kernel Module fuse.
[ 16.111668] systemd[1]: Mounting FUSE Control File System...
[ 16.115236] systemd[1]: Mounting Kernel Configuration File System...
[ 16.120815] systemd[1]: Mounted FUSE Control File System.
[ 16.124742] systemd[1]: Mounted Kernel Configuration File System.
[ 16.424616] RPC: Registered named UNIX socket transport module.
[ 16.424621] RPC: Registered udp transport module.
[ 16.424623] RPC: Registered tcp transport module.
[ 16.424625] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 16.428651] systemd[1]: Mounted RPC Pipe File System.
[ 16.557020] EXT4-fs (loop0): re-mounted. Opts: errors=remount-ro
[ 16.561725] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 16.779256] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 16.779425] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 16.781920] systemd[1]: Starting Load/Save Random Seed...
[ 16.785000] systemd[1]: Starting Create System Users...
[ 16.786144] systemd[1]: Started Journal Service.
[ 16.904375] systemd-journald[216]: Received client request to flush runtime journal.
[ 17.118374] lp: driver loaded but no devices found
[ 17.172224] ppdev: user-space parallel port driver
[ 17.249718] parport_pc 00:04: reported by Plug and Play ACPI
[ 17.249832] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 17.345696] lp0: using parport0 (interrupt-driven).
[ 18.802513] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input7
[ 18.802589] ACPI: Power Button [PWRB]
[ 18.802741] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input8
[ 18.825489] ACPI: Power Button [PWRF]
[ 19.133692] intel_rng: FWH not detected
[ 19.234866] leds_ss4200: no LED devices found
[ 19.347542] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ 19.675089] at24 0-0050: supply vcc not found, using dummy regulator
[ 19.675621] sr 1:0:0:0: Attached scsi generic sg0 type 5
[ 19.675701] sd 1:0:1:0: Attached scsi generic sg1 type 0
[ 19.678941] at24 0-0050: 256 byte spd EEPROM, read-only
[ 19.849385] iTCO_vendor_support: vendor-support=0
[ 21.775360] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 21.775465] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0460)
[ 21.775815] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 21.993006] pci 0000:00:00.0: Intel 945G Chipset
[ 21.993030] pci 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 21.993504] pci 0000:00:00.0: detected 8192K stolen memory
[ 21.993592] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 21.994525] Console: switching to colour dummy device 80x25
[ 21.999520] resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than pnp 00:08 [mem 0x000cae00-0x000cbfff]
[ 21.999531] caller pci_map_rom+0x7c/0x1d0 mapping multiple BARs
[ 22.000184] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 22.077843] i915 0000:00:02.0: [drm] Initialized overlay support.
[ 22.082194] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
[ 22.165799] fbcon: i915drmfb (fb0) is primary device
[ 22.245662] Console: switching to colour frame buffer device 170x48
[ 22.262275] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 25.639844] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 25.640434] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 25.640961] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 25.641562] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 25.852745] lib80211: common routines for IEEE802.11 drivers
[ 25.852756] lib80211_crypt: registered algorithm 'NULL'
[ 26.249814] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[ 26.301693] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[ 26.403184] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 26.413831] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 26.448509] usbcore: registered new interface driver r8188eu
[ 26.521716] r8188eu 2-1.1:1.0 wlx7cc2c6273c42: renamed from wlan0
Hello, Any suggestion on the system audio issues ?
No idea if this will work.
If we're looking at the Zeb box, you're connecting via the charging/aux port from what you say.
If that's the case then it should appear as a set of headphones - as has been stated above.
First grab a set of ordinary wired headphones with 3.5mm jack.
Plug in to laptop
Right click on Volume icon>Select Master Channel (I'm working from memory here!!!) Select Pulse - if it's there.
Then using the Volume icon open the mixer and make sure the headphones are not muted. Should see a little green indicator at top of slider.
Test headphones for output - if they don't work then that's a problem - try with Alsa instead.
If they do work, switch on the Zeb box - connect via aux and see if that works.
Nope, it doesn't works. I have a desktop not laptop. and the desktop got two set of AUX ports. one set always gives random noise. another set is dead ! Am attaching the screenshots. I don't have idea how to do the same with Alsa.
regards,
Ragu
Input side is OK - what about the output?
output also seems same.. but can't hear anything !!
