#1 2022-04-22 02:56
JSM
[solved]Screen distorted, SIS771/671, Bangho Mov / Clevo M540SS
Hi
I have just installed Q4OS on a rather old notebook (about 12 years old). Everything is magnificent, except the screen is not.
The image is slightly distorted, wider than it should be. For example, a circle is an oval, slightly wider than high. I attached a photo.
Unfortunately, the distortion also blurs the font.
Can I fix this somehow?
#2 2022-04-22 14:05
Re: [solved]Screen distorted, SIS771/671, Bangho Mov / Clevo M540SS
On the image, the circle is perfect, but it seems to be a screen capture, not a photo.
Anyway, go to the screen configuration (depends whether you use Trinity or Plasma desktop) and check that the resolution is matching the native screen resolution.
#3 2022-04-22 15:15
JSM
@hchiper
Where exactly can I find this at Trinity? I have not found a way to change the screen resolution so far, except very roughly with 3 levels. But I need something very hostile.
About half a year ago I had the same problem on another old notebook. But there with Tiny Core Linux. Q4OS was good and so was Trisquel. Well, on this notebook it is at Q4OS. I have not installed a second Linux yet.
Could it be a problem with a driver?
#4 2022-04-22 15:41
Search for "tderandrtray" in the main menu.
#5 2022-04-22 23:01
JSM
@Q4OS Team
Yes, I had seen that. Is it the one in the snapshot? But there I can only select 3 settings in the second tab:
1024x768
800x600
640x480
But in all settings the distortion remains.
Meanwhile, I have installed a trisquel on sda2 and there the problem also exists. So it is probably a problem of the driver?
q4os@q4os-desktop:~$ lspci
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] AGP Port (virtual PCI-to-PCI bridge)
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01)
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 IDE Controller (rev 01)
00:03.0 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.1 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f)
00:03.3 USB controller: Silicon Integrated Systems [SiS] USB 2.0 Controller
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter (rev 02)
00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03)
00:06.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:07.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller
00:1f.0 PCI bridge: Silicon Integrated Systems [SiS] PCI-to-PCI bridge
01:00.0 VGA compatible controller: Silicon Integrated Systems [SiS] 771/671 PCIE VGA Display Adapter (rev 10)
03:00.0 System peripheral: JMicron Technology Corp. SD/MMC Host Controller
03:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller
03:00.3 System peripheral: JMicron Technology Corp. MS Host Controller
03:00.4 System peripheral: JMicron Technology Corp. xD Host Controller
Maybe you can find out something? Using a different driver or using a boot code? I understand very little about this.
#6 2022-04-23 01:24
Humming Owl
@JSM
Try following the steps on this post (just the commands) --> https://www.q4os.org/forum/viewtopic.ph … 776#p22776
if no changes after the reboot then share the contents of this file "/var/log/Xorg.0.log".
And also the contents of the "xorg.conf" file in the "/etc/X11/" path.
Maybe Xorg is failing applying correct resolution for some reason.
Cheers.
#7 2022-04-23 02:16
JSM
@Humming Owl
Thanks for helping. Here first the try in the terminal:
q4os@q4os-desktop:~$ sudo Xorg -configure
(EE)
Fatal server error:
(EE) Server is already active for display 0
        If this server is no longer running, remove /tmp/.X0-lock
        and start again.
(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE)
q4os@q4os-desktop:~$ sudo cp /root/xorg.conf.new /etc/X11/xorg.conf
cp: cannot stat '/root/xorg.conf.new': No such file or directory
Then the file Xorg.0.log :
[    36.505]
X.Org X Server 1.20.11
X Protocol Version 11, Revision 0
[    36.505] Build Operating System: linux Debian
[    36.505] Current Operating System: Linux q4os-desktop 5.10.0-13-amd64 #1 SMP Debian 5.10.106-1 (2022-03-17) x86_64
[    36.505] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10.0-13-amd64 root=UUID=79f87549-58bf-4949-9910-0f05517f07d0 ro quiet
[    36.505] Build Date: 16 December 2021  05:08:23PM
[    36.505] xorg-server 2:1.20.11-1+deb11u1 (https://www.debian.org/support)
[    36.505] Current version of pixman: 0.40.0
[    36.505] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    36.505] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    36.506] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 22 21:55:08 2022
[    36.749] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    36.749] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    37.056] (==) No Layout section.  Using the first Screen section.
[    37.056] (==) No screen section available. Using defaults.
[    37.056] (**) |-->Screen "Default Screen Section" (0)
[    37.056] (**) |   |-->Monitor "<default monitor>"
[    37.117] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    37.117] (==) Automatically adding devices
[    37.117] (==) Automatically enabling devices
[    37.117] (==) Automatically adding GPU devices
[    37.117] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    37.263] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[    37.263] 	Entry deleted from font path.
[    37.263] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    37.263] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    37.263] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    37.263] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[    37.263] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    37.263] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    37.263] (==) FontPath set to:
	built-ins
[    37.263] (==) ModulePath set to "/usr/lib/xorg/modules"
[    37.263] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    37.263] (II) Loader magic: 0x56536234ae40
[    37.263] (II) Module ABI versions:
[    37.263] 	X.Org ANSI C Emulation: 0.4
[    37.264] 	X.Org Video Driver: 24.1
[    37.264] 	X.Org XInput driver : 24.1
[    37.264] 	X.Org Server Extension : 10.0
[    37.266] (++) using VT number 7
[    37.266] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    37.276] (--) PCI:*(1@0:0:0) 1039:6351:1558:0803 rev 16, Mem @ 0xc0000000/268435456, 0xd4000000/131072, I/O @ 0x00009000/128, BIOS @ 0x????????/131072
[    37.356] (II) LoadModule: "glx"
[    37.577] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    38.193] (II) Module glx: vendor="X.Org Foundation"
[    38.193] 	compiled for 1.20.11, module version = 1.0.0
[    38.193] 	ABI class: X.Org Server Extension, version 10.0
[    38.193] (==) Matched sis as autoconfigured driver 0
[    38.193] (==) Matched modesetting as autoconfigured driver 1
[    38.193] (==) Matched fbdev as autoconfigured driver 2
[    38.193] (==) Matched vesa as autoconfigured driver 3
[    38.193] (==) Assigned the driver to the xf86ConfigLayout
[    38.193] (II) LoadModule: "sis"
[    38.194] (WW) Warning, couldn't open module sis
[    38.194] (EE) Failed to load module "sis" (module does not exist, 0)
[    38.194] (II) LoadModule: "modesetting"
[    38.194] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    38.386] (II) Module modesetting: vendor="X.Org Foundation"
[    38.386] 	compiled for 1.20.11, module version = 1.20.11
[    38.386] 	Module class: X.Org Video Driver
[    38.386] 	ABI class: X.Org Video Driver, version 24.1
[    38.386] (II) LoadModule: "fbdev"
[    38.386] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    38.407] (II) Module fbdev: vendor="X.Org Foundation"
[    38.407] 	compiled for 1.20.0, module version = 0.5.0
[    38.407] 	Module class: X.Org Video Driver
[    38.407] 	ABI class: X.Org Video Driver, version 24.0
[    38.407] (II) LoadModule: "vesa"
[    38.407] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    38.430] (II) Module vesa: vendor="X.Org Foundation"
[    38.430] 	compiled for 1.20.9, module version = 2.5.0
[    38.430] 	Module class: X.Org Video Driver
[    38.430] 	ABI class: X.Org Video Driver, version 24.1
[    38.430] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    38.430] (II) FBDEV: driver for framebuffer: fbdev
[    38.430] (II) VESA: driver for VESA chipsets: vesa
[    38.434] (EE) open /dev/dri/card0: No such file or directory
[    38.435] (WW) Falling back to old probe method for modesetting
[    38.435] (EE) open /dev/dri/card0: No such file or directory
[    38.435] (II) Loading sub module "fbdevhw"
[    38.435] (II) LoadModule: "fbdevhw"
[    38.435] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    38.515] (II) Module fbdevhw: vendor="X.Org Foundation"
[    38.515] 	compiled for 1.20.11, module version = 0.0.2
[    38.515] 	ABI class: X.Org Video Driver, version 24.1
[    38.516] (EE) Unable to find a valid framebuffer device
[    38.516] (WW) Falling back to old probe method for fbdev
[    38.516] (II) Loading sub module "fbdevhw"
[    38.516] (II) LoadModule: "fbdevhw"
[    38.516] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    38.516] (II) Module fbdevhw: vendor="X.Org Foundation"
[    38.516] 	compiled for 1.20.11, module version = 0.0.2
[    38.516] 	ABI class: X.Org Video Driver, version 24.1
[    38.516] (EE) open /dev/fb0: No such file or directory
[    38.516] (EE) Screen 0 deleted because of no matching config section.
[    38.516] (II) UnloadModule: "modesetting"
[    38.516] (II) UnloadModule: "fbdev"
[    38.516] (II) UnloadSubModule: "fbdevhw"
[    38.516] (II) Loading sub module "vbe"
[    38.516] (II) LoadModule: "vbe"
[    38.517] (II) Loading /usr/lib/xorg/modules/libvbe.so
[    38.536] (II) Module vbe: vendor="X.Org Foundation"
[    38.536] 	compiled for 1.20.11, module version = 1.1.0
[    38.536] 	ABI class: X.Org Video Driver, version 24.1
[    38.536] (II) Loading sub module "int10"
[    38.536] (II) LoadModule: "int10"
[    38.536] (II) Loading /usr/lib/xorg/modules/libint10.so
[    38.691] (II) Module int10: vendor="X.Org Foundation"
[    38.691] 	compiled for 1.20.11, module version = 1.0.0
[    38.691] 	ABI class: X.Org Video Driver, version 24.1
[    38.692] (II) VESA(0): initializing int10
[    38.699] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[    38.702] (II) VESA(0): VESA BIOS detected
[    38.702] (II) VESA(0): VESA VBE Version 3.0
[    38.702] (II) VESA(0): VESA VBE Total Mem: 131072 kB
[    38.702] (II) VESA(0): VESA VBE OEM: SiS
[    38.702] (II) VESA(0): VESA VBE OEM Software Rev: 1.0
[    38.702] (II) VESA(0): VESA VBE OEM Vendor: Silicon Integrated Systems Corp.
[    38.702] (II) VESA(0): VESA VBE OEM Product: 6330
[    38.702] (II) VESA(0): VESA VBE OEM Product Rev: 3.72.1E
[    38.722] (II) VESA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[    38.723] (==) VESA(0): Depth 24, (--) framebuffer bpp 32
[    38.723] (==) VESA(0): RGB weight 888
[    38.723] (==) VESA(0): Default visual is TrueColor
[    38.723] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[    38.723] (II) Loading sub module "ddc"
[    38.723] (II) LoadModule: "ddc"
[    38.723] (II) Module "ddc" already built-in
[    38.815] (II) VESA(0): VESA VBE DDC supported
[    38.815] (II) VESA(0): VESA VBE DDC Level none
[    38.815] (II) VESA(0): VESA VBE DDC transfer in appr. 0 sec.
[    38.848] (II) VESA(0): VESA VBE DDC read failed
[    38.848] (II) VESA(0): VESA VBE PanelID read failed
[    38.848] (II) VESA(0): Searching for matching VESA mode(s):
[    38.848] Mode: 11c (1280x768)
[    38.848] 	ModeAttributes: 0x9f
[    38.848] 	WinAAttributes: 0x7
[    38.848] 	WinBAttributes: 0x0
[    38.848] 	WinGranularity: 64
[    38.848] 	WinSize: 64
[    38.848] 	WinASegment: 0xa000
[    38.848] 	WinBSegment: 0xa000
[    38.848] 	WinFuncPtr: 0xc0008960
[    38.848] 	BytesPerScanline: 1280
[    38.848] 	XResolution: 1280
[    38.848] 	YResolution: 768
[    38.848] 	XCharSize: 8
[    38.848] 	YCharSize: 16
[    38.849] 	NumberOfPlanes: 1
[    38.849] 	BitsPerPixel: 8
[    38.849] 	NumberOfBanks: 1
[    38.849] 	MemoryModel: 4
[    38.849] 	BankSize: 0
[    38.849] 	NumberOfImages: 7
[    38.849] 	RedMaskSize: 0
[    38.849] 	RedFieldPosition: 0
[    38.849] 	GreenMaskSize: 0
[    38.849] 	GreenFieldPosition: 0
[    38.849] 	BlueMaskSize: 0
[    38.849] 	BlueFieldPosition: 0
[    38.849] 	RsvdMaskSize: 0
[    38.849] 	RsvdFieldPosition: 0
[    38.849] 	DirectColorModeInfo: 0
[    38.849] 	PhysBasePtr: 0xc0000000
[    38.849] 	LinBytesPerScanLine: 1280
[    38.849] 	BnkNumberOfImagePages: 7
[    38.849] 	LinNumberOfImagePages: 7
[    38.849] 	LinRedMaskSize: 0
[    38.849] 	LinRedFieldPosition: 0
[    38.849] 	LinGreenMaskSize: 0
[    38.849] 	LinGreenFieldPosition: 0
[    38.849] 	LinBlueMaskSize: 0
[    38.849] 	LinBlueFieldPosition: 0
[    38.849] 	LinRsvdMaskSize: 0
[    38.849] 	LinRsvdFieldPosition: 0
[    38.849] 	MaxPixelClock: 0
[    38.849] Mode: 11d (1280x768)
[    38.849] 	ModeAttributes: 0x9b
[    38.849] 	WinAAttributes: 0x7
[    38.849] 	WinBAttributes: 0x0
[    38.849] 	WinGranularity: 64
[    38.849] 	WinSize: 64
[    38.849] 	WinASegment: 0xa000
[    38.849] 	WinBSegment: 0xa000
[    38.849] 	WinFuncPtr: 0xc0008960
[    38.849] 	BytesPerScanline: 2560
[    38.849] 	XResolution: 1280
[    38.849] 	YResolution: 768
[    38.849] 	XCharSize: 8
[    38.849] 	YCharSize: 16
[    38.849] 	BitsPerPixel: 16
[    38.849] 	MemoryModel: 6
[    38.849] 	NumberOfImages: 3
[    38.849] 	RedMaskSize: 5
[    38.849] 	RedFieldPosition: 11
[    38.849] 	GreenMaskSize: 6
[    38.849] 	GreenFieldPosition: 5
[    38.849] 	BlueMaskSize: 5
[    38.850] 	DirectColorModeInfo: 0
[    38.850] 	PhysBasePtr: 0xc0000000
[    38.850] 	LinBytesPerScanLine: 2560
[    38.850] 	BnkNumberOfImagePages: 3
[    38.850] 	LinNumberOfImagePages: 3
[    38.850] 	LinRedMaskSize: 5
[    38.850] 	LinRedFieldPosition: 11
[    38.850] 	LinGreenMaskSize: 6
[    38.850] 	LinGreenFieldPosition: 5
[    38.850] 	LinBlueMaskSize: 5
[    38.850] 	LinBlueFieldPosition: 0
[    38.850] 	LinRsvdMaskSize: 0
[    38.850] 	LinRsvdFieldPosition: 0
[    38.850] 	MaxPixelClock: 0
[    38.850] *Mode: 11e (1280x768)
[    38.850] 	ModeAttributes: 0x9b
[    38.850] 	WinAAttributes: 0x7
[    38.850] 	WinBAttributes: 0x0
[    38.850] 	WinGranularity: 64
[    38.850] 	WinSize: 64
[    38.850] 	WinASegment: 0xa000
[    38.850] 	WinBSegment: 0xa000
[    38.850] 	WinFuncPtr: 0xc0008960
[    38.850] 	BytesPerScanline: 5120
[    38.850] 	XResolution: 1280
[    38.850] 	YResolution: 768
[    38.850] 	XCharSize: 8
[    38.850] 	YCharSize: 16
[    38.850] 	NumberOfPlanes: 1
[    38.850] 	BitsPerPixel: 32
[    38.850] 	NumberOfBanks: 1
[    38.850] 	MemoryModel: 6
[    38.850] 	BankSize: 0
[    38.850] 	NumberOfImages: 1
[    38.850] 	RedMaskSize: 8
[    38.850] 	RedFieldPosition: 16
[    38.850] 	GreenMaskSize: 8
[    38.850] 	GreenFieldPosition: 8
[    38.850] 	BlueMaskSize: 8
[    38.850] 	BlueFieldPosition: 0
[    38.850] 	RsvdMaskSize: 8
[    38.850] 	RsvdFieldPosition: 24
[    38.850] 	LinBytesPerScanLine: 5120
[    38.850] 	BnkNumberOfImagePages: 1
[    38.850] 	LinNumberOfImagePages: 1
[    38.850] 	LinRedMaskSize: 8
[    38.850] 	LinRedFieldPosition: 16
[    38.850] 	LinGreenMaskSize: 8
[    38.850] 	LinGreenFieldPosition: 8
[    38.850] 	LinBlueMaskSize: 8
[    38.850] 	LinRsvdMaskSize: 8
[    38.851] 	LinRsvdFieldPosition: 24
[    38.851] 	MaxPixelClock: 0
[    38.851] Mode: 101 (640x480)
[    38.851] 	ModeAttributes: 0x9f
[    38.851] 	WinAAttributes: 0x7
[    38.851] 	WinBAttributes: 0x0
[    38.851] 	WinGranularity: 64
[    38.851] 	WinSize: 64
[    38.851] 	WinASegment: 0xa000
[    38.851] 	WinBSegment: 0xa000
[    38.851] 	WinFuncPtr: 0xc0008960
[    38.851] 	BytesPerScanline: 640
[    38.851] 	XResolution: 640
[    38.851] 	YResolution: 480
[    38.851] 	XCharSize: 8
[    38.851] 	YCharSize: 16
[    38.851] 	NumberOfPlanes: 1
[    38.851] 	BitsPerPixel: 8
[    38.851] 	NumberOfBanks: 1
[    38.851] 	MemoryModel: 4
[    38.851] 	BankSize: 0
[    38.851] 	NumberOfImages: 24
[    38.851] 	RedMaskSize: 0
[    38.851] 	RedFieldPosition: 0
[    38.851] 	GreenMaskSize: 0
[    38.851] 	GreenFieldPosition: 0
[    38.851] 	BlueMaskSize: 0
[    38.851] 	BlueFieldPosition: 0
[    38.851] 	RsvdMaskSize: 0
[    38.851] 	RsvdFieldPosition: 0
[    38.851] 	DirectColorModeInfo: 0
[    38.851] 	PhysBasePtr: 0xc0000000
[    38.851] 	LinBytesPerScanLine: 640
[    38.851] 	BnkNumberOfImagePages: 24
[    38.851] 	LinNumberOfImagePages: 24
[    38.851] 	LinRedMaskSize: 0
[    38.851] 	LinRedFieldPosition: 0
[    38.851] 	LinGreenMaskSize: 0
[    38.851] 	LinGreenFieldPosition: 0
[    38.851] 	LinBlueMaskSize: 0
[    38.851] 	LinBlueFieldPosition: 0
[    38.851] 	LinRsvdMaskSize: 0
[    38.851] 	LinRsvdFieldPosition: 0
[    38.852] Mode: 100 (640x400)
[    38.852] 	ModeAttributes: 0x9f
[    38.852] 	WinAAttributes: 0x7
[    38.852] 	WinBAttributes: 0x0
[    38.852] 	WinGranularity: 64
[    38.852] 	WinSize: 64
[    38.852] 	WinASegment: 0xa000
[    38.852] 	WinBSegment: 0xa000
[    38.852] 	WinFuncPtr: 0xc0008960
[    38.852] 	BytesPerScanline: 640
[    38.852] 	XResolution: 640
[    38.852] 	YResolution: 400
[    38.852] 	XCharSize: 8
[    38.852] 	YCharSize: 16
[    38.852] 	NumberOfPlanes: 1
[    38.852] 	BitsPerPixel: 8
[    38.852] 	NumberOfBanks: 1
[    38.852] 	MemoryModel: 4
[    38.852] 	BankSize: 0
[    38.852] 	NumberOfImages: 31
[    38.852] 	RedMaskSize: 0
[    38.852] 	RedFieldPosition: 0
[    38.852] 	GreenMaskSize: 0
[    38.852] 	GreenFieldPosition: 0
[    38.852] 	BlueMaskSize: 0
[    38.852] 	BlueFieldPosition: 0
[    38.852] 	RsvdMaskSize: 0
[    38.852] 	RsvdFieldPosition: 0
[    38.852] 	DirectColorModeInfo: 0
[    38.852] 	PhysBasePtr: 0xc0000000
[    38.852] 	LinBytesPerScanLine: 640
[    38.852] 	BnkNumberOfImagePages: 31
[    38.852] 	LinNumberOfImagePages: 31
[    38.852] 	LinRedMaskSize: 0
[    38.852] 	LinRedFieldPosition: 0
[    38.852] 	LinGreenMaskSize: 0
[    38.852] 	LinGreenFieldPosition: 0
[    38.852] 	LinBlueMaskSize: 0
[    38.852] 	LinBlueFieldPosition: 0
[    38.852] 	LinRsvdMaskSize: 0
[    38.852] 	LinRsvdFieldPosition: 0
[    38.852] 	MaxPixelClock: 0
[    38.853] Mode: 103 (800x600)
[    38.853] 	ModeAttributes: 0x9f
[    38.853] 	WinAAttributes: 0x7
[    38.853] 	WinBAttributes: 0x0
[    38.853] 	WinGranularity: 64
[    38.853] 	WinSize: 64
[    38.853] 	WinASegment: 0xa000
[    38.853] 	WinBSegment: 0xa000
[    38.853] 	WinFuncPtr: 0xc0008960
[    38.853] 	BytesPerScanline: 800
[    38.853] 	XResolution: 800
[    38.853] 	YResolution: 600
[    38.853] 	XCharSize: 8
[    38.853] 	YCharSize: 16
[    38.853] 	NumberOfPlanes: 1
[    38.853] 	BitsPerPixel: 8
[    38.853] 	NumberOfBanks: 1
[    38.853] 	MemoryModel: 4
[    38.853] 	BankSize: 0
[    38.853] 	NumberOfImages: 15
[    38.853] 	RedMaskSize: 0
[    38.853] 	RedFieldPosition: 0
[    38.853] 	GreenMaskSize: 0
[    38.853] 	GreenFieldPosition: 0
[    38.853] 	BlueMaskSize: 0
[    38.853] 	BlueFieldPosition: 0
[    38.853] 	RsvdMaskSize: 0
[    38.853] 	RsvdFieldPosition: 0
[    38.853] 	DirectColorModeInfo: 0
[    38.853] 	PhysBasePtr: 0xc0000000
[    38.853] 	LinBytesPerScanLine: 800
[    38.853] 	BnkNumberOfImagePages: 15
[    38.853] 	LinNumberOfImagePages: 15
[    38.853] 	LinRedMaskSize: 0
[    38.853] 	LinRedFieldPosition: 0
[    38.853] 	LinGreenMaskSize: 0
[    38.853] 	LinGreenFieldPosition: 0
[    38.853] 	LinBlueMaskSize: 0
[    38.853] 	LinBlueFieldPosition: 0
[    38.853] 	LinRsvdMaskSize: 0
[    38.853] 	LinRsvdFieldPosition: 0
[    38.853] 	MaxPixelClock: 0
[    38.854] Mode: 104 (1024x768)
[    38.854] 	ModeAttributes: 0x1f
[    38.854] 	WinAAttributes: 0x7
[    38.854] 	WinBAttributes: 0x0
[    38.854] 	WinGranularity: 64
[    38.854] 	WinSize: 64
[    38.854] 	WinASegment: 0xa000
[    38.854] 	WinBSegment: 0xa000
[    38.854] 	WinFuncPtr: 0xc0008960
[    38.854] 	BytesPerScanline: 128
[    38.854] 	XResolution: 1024
[    38.854] 	YResolution: 768
[    38.854] 	XCharSize: 8
[    38.854] 	YCharSize: 16
[    38.854] 	NumberOfPlanes: 4
[    38.854] 	BitsPerPixel: 4
[    38.854] 	NumberOfBanks: 1
[    38.854] 	MemoryModel: 3
[    38.854] 	BankSize: 0
[    38.854] 	NumberOfImages: 15
[    38.854] 	RedMaskSize: 0
[    38.854] 	RedFieldPosition: 0
[    38.854] 	GreenMaskSize: 0
[    38.854] 	GreenFieldPosition: 0
[    38.854] 	BlueMaskSize: 0
[    38.854] 	BlueFieldPosition: 0
[    38.854] 	RsvdMaskSize: 0
[    38.854] 	RsvdFieldPosition: 0
[    38.854] 	DirectColorModeInfo: 0
[    38.854] 	PhysBasePtr: 0xc0000000
[    38.854] 	LinBytesPerScanLine: 128
[    38.855] 	BnkNumberOfImagePages: 15
[    38.855] 	LinNumberOfImagePages: 15
[    38.855] 	LinRedMaskSize: 0
[    38.855] 	LinRedFieldPosition: 0
[    38.855] 	LinGreenMaskSize: 0
[    38.855] 	LinGreenFieldPosition: 0
[    38.855] 	LinBlueMaskSize: 0
[    38.855] 	LinBlueFieldPosition: 0
[    38.855] 	LinRsvdMaskSize: 0
[    38.855] 	LinRsvdFieldPosition: 0
[    38.855] 	MaxPixelClock: 0
[    38.855] Mode: 105 (1024x768)
[    38.855] 	ModeAttributes: 0x9f
[    38.855] 	WinAAttributes: 0x7
[    38.855] 	WinBAttributes: 0x0
[    38.855] 	WinGranularity: 64
[    38.855] 	WinSize: 64
[    38.855] 	WinASegment: 0xa000
[    38.855] 	WinBSegment: 0xa000
[    38.855] 	WinFuncPtr: 0xc0008960
[    38.855] 	BytesPerScanline: 1024
[    38.855] 	XResolution: 1024
[    38.855] 	YResolution: 768
[    38.855] 	XCharSize: 8
[    38.855] 	YCharSize: 16
[    38.855] 	NumberOfPlanes: 1
[    38.855] 	BitsPerPixel: 8
[    38.855] 	NumberOfBanks: 1
[    38.855] 	MemoryModel: 4
[    38.855] 	BankSize: 0
[    38.855] 	NumberOfImages: 9
[    38.855] 	RedMaskSize: 0
[    38.855] 	RedFieldPosition: 0
[    38.855] 	GreenMaskSize: 0
[    38.855] 	GreenFieldPosition: 0
[    38.855] 	BlueMaskSize: 0
[    38.855] 	BlueFieldPosition: 0
[    38.855] 	RsvdMaskSize: 0
[    38.855] 	RsvdFieldPosition: 0
[    38.855] 	DirectColorModeInfo: 0
[    38.855] 	PhysBasePtr: 0xc0000000
[    38.855] 	LinBytesPerScanLine: 1024
[    38.855] 	BnkNumberOfImagePages: 9
[    38.856] 	LinNumberOfImagePages: 9
[    38.856] 	LinRedMaskSize: 0
[    38.856] 	LinRedFieldPosition: 0
[    38.856] 	LinGreenMaskSize: 0
[    38.856] 	LinGreenFieldPosition: 0
[    38.856] 	LinBlueMaskSize: 0
[    38.856] 	LinBlueFieldPosition: 0
[    38.856] 	LinRsvdMaskSize: 0
[    38.856] 	LinRsvdFieldPosition: 0
[    38.856] 	MaxPixelClock: 0
[    38.856] Mode: 10d (320x200)
[    38.856] 	ModeAttributes: 0x9b
[    38.856] 	WinAAttributes: 0x7
[    38.856] 	WinBAttributes: 0x0
[    38.856] 	WinGranularity: 64
[    38.856] 	WinSize: 64
[    38.856] 	WinASegment: 0xa000
[    38.856] 	WinBSegment: 0xa000
[    38.856] 	WinFuncPtr: 0xc0008960
[    38.856] 	BytesPerScanline: 640
[    38.856] 	XResolution: 320
[    38.856] 	YResolution: 200
[    38.856] 	XCharSize: 8
[    38.856] 	YCharSize: 8
[    38.856] 	NumberOfPlanes: 1
[    38.856] 	BitsPerPixel: 15
[    38.856] 	NumberOfBanks: 1
[    38.856] 	MemoryModel: 6
[    38.856] 	BankSize: 0
[    38.856] 	NumberOfImages: 63
[    38.856] 	RedMaskSize: 5
[    38.856] 	RedFieldPosition: 10
[    38.856] 	GreenMaskSize: 5
[    38.856] 	GreenFieldPosition: 5
[    38.856] 	BlueMaskSize: 5
[    38.856] 	BlueFieldPosition: 0
[    38.856] 	RsvdMaskSize: 0
[    38.856] 	RsvdFieldPosition: 0
[    38.856] 	DirectColorModeInfo: 0
[    38.856] 	PhysBasePtr: 0xc0000000
[    38.856] 	LinBytesPerScanLine: 640
[    38.856] 	BnkNumberOfImagePages: 63
[    38.856] 	LinNumberOfImagePages: 63
[    38.856] 	LinRedMaskSize: 5
[    38.856] 	LinRedFieldPosition: 10
[    38.856] 	LinGreenMaskSize: 5
[    38.856] 	LinGreenFieldPosition: 5
[    38.856] 	LinBlueMaskSize: 5
[    38.857] 	LinBlueFieldPosition: 0
[    38.857] 	LinRsvdMaskSize: 0
[    38.857] 	LinRsvdFieldPosition: 0
[    38.857] 	MaxPixelClock: 0
[    38.857] Mode: 10e (320x200)
[    38.857] 	ModeAttributes: 0x9b
[    38.857] 	WinAAttributes: 0x7
[    38.857] 	WinBAttributes: 0x0
[    38.857] 	WinGranularity: 64
[    38.857] 	WinSize: 64
[    38.857] 	WinASegment: 0xa000
[    38.857] 	WinBSegment: 0xa000
[    38.857] 	WinFuncPtr: 0xc0008960
[    38.857] 	BytesPerScanline: 640
[    38.857] 	XResolution: 320
[    38.857] 	YResolution: 200
[    38.857] 	XCharSize: 8
[    38.857] 	YCharSize: 8
[    38.857] 	NumberOfPlanes: 1
[    38.857] 	BitsPerPixel: 16
[    38.857] 	NumberOfBanks: 1
[    38.857] 	MemoryModel: 6
[    38.857] 	BankSize: 0
[    38.857] 	NumberOfImages: 63
[    38.857] 	RedMaskSize: 5
[    38.857] 	RedFieldPosition: 11
[    38.857] 	GreenMaskSize: 6
[    38.857] 	GreenFieldPosition: 5
[    38.857] 	BlueMaskSize: 5
[    38.857] 	BlueFieldPosition: 0
[    38.857] 	RsvdMaskSize: 0
[    38.857] 	RsvdFieldPosition: 0
[    38.857] 	DirectColorModeInfo: 0
[    38.857] 	PhysBasePtr: 0xc0000000
[    38.857] 	LinBytesPerScanLine: 640
[    38.857] 	BnkNumberOfImagePages: 63
[    38.857] 	LinNumberOfImagePages: 63
[    38.857] 	LinRedMaskSize: 5
[    38.857] 	LinRedFieldPosition: 11
[    38.857] 	LinGreenMaskSize: 6
[    38.857] 	LinGreenFieldPosition: 5
[    38.857] 	LinBlueMaskSize: 5
[    38.858] Mode: 110 (640x480)
[    38.858] 	ModeAttributes: 0x9b
[    38.858] 	WinAAttributes: 0x7
[    38.858] 	WinBAttributes: 0x0
[    38.858] 	WinGranularity: 64
[    38.858] 	WinSize: 64
[    38.858] 	WinASegment: 0xa000
[    38.858] 	WinBSegment: 0xa000
[    38.858] 	WinFuncPtr: 0xc0008960
[    38.858] 	BytesPerScanline: 1280
[    38.858] 	XResolution: 640
[    38.858] 	YResolution: 480
[    38.858] 	XCharSize: 8
[    38.858] 	YCharSize: 16
[    38.858] 	NumberOfPlanes: 1
[    38.858] 	BitsPerPixel: 15
[    38.858] 	NumberOfBanks: 1
[    38.858] 	MemoryModel: 6
[    38.858] 	BankSize: 0
[    38.858] 	NumberOfImages: 11
[    38.858] 	RedMaskSize: 5
[    38.858] 	RedFieldPosition: 10
[    38.858] 	GreenMaskSize: 5
[    38.858] 	GreenFieldPosition: 5
[    38.858] 	BlueMaskSize: 5
[    38.858] 	BlueFieldPosition: 0
[    38.858] 	RsvdMaskSize: 0
[    38.858] 	RsvdFieldPosition: 0
[    38.858] 	DirectColorModeInfo: 0
[    38.858] 	PhysBasePtr: 0xc0000000
[    38.858] 	LinBytesPerScanLine: 1280
[    38.858] 	BnkNumberOfImagePages: 11
[    38.858] 	LinNumberOfImagePages: 11
[    38.858] 	LinRedMaskSize: 5
[    38.858] 	LinRedFieldPosition: 10
[    38.858] 	LinGreenMaskSize: 5
[    38.858] 	LinGreenFieldPosition: 5
[    38.858] 	LinBlueMaskSize: 5
[    38.858] 	LinBlueFieldPosition: 0
[    38.858] 	LinRsvdMaskSize: 0
[    38.858] 	LinRsvdFieldPosition: 0
[    38.858] 	MaxPixelClock: 0
[    38.859] Mode: 111 (640x480)
[    38.859] 	ModeAttributes: 0x9b
[    38.859] 	WinAAttributes: 0x7
[    38.859] 	WinBAttributes: 0x0
[    38.859] 	WinGranularity: 64
[    38.859] 	WinSize: 64
[    38.859] 	WinASegment: 0xa000
[    38.859] 	WinBSegment: 0xa000
[    38.859] 	WinFuncPtr: 0xc0008960
[    38.859] 	BytesPerScanline: 1280
[    38.859] 	XResolution: 640
[    38.859] 	YResolution: 480
[    38.859] 	XCharSize: 8
[    38.859] 	YCharSize: 16
[    38.859] 	NumberOfPlanes: 1
[    38.859] 	BitsPerPixel: 16
[    38.859] 	NumberOfBanks: 1
[    38.859] 	MemoryModel: 6
[    38.859] 	BankSize: 0
[    38.859] 	NumberOfImages: 11
[    38.859] 	RedMaskSize: 5
[    38.859] 	RedFieldPosition: 11
[    38.859] 	GreenMaskSize: 6
[    38.859] 	GreenFieldPosition: 5
[    38.859] 	BlueMaskSize: 5
[    38.859] 	BlueFieldPosition: 0
[    38.859] 	RsvdMaskSize: 0
[    38.859] 	RsvdFieldPosition: 0
[    38.859] 	DirectColorModeInfo: 0
[    38.859] 	PhysBasePtr: 0xc0000000
[    38.859] 	LinBytesPerScanLine: 1280
[    38.859] 	BnkNumberOfImagePages: 11
[    38.859] 	LinNumberOfImagePages: 11
[    38.859] 	LinRedMaskSize: 5
[    38.859] 	LinRedFieldPosition: 11
[    38.859] 	LinGreenMaskSize: 6
[    38.859] 	LinGreenFieldPosition: 5
[    38.859] 	LinBlueMaskSize: 5
[    38.859] 	LinBlueFieldPosition: 0
[    38.859] 	LinRsvdMaskSize: 0
[    38.859] 	LinRsvdFieldPosition: 0
[    38.859] 	MaxPixelClock: 0
[    38.860] Mode: 113 (800x600)
[    38.860] 	ModeAttributes: 0x9b
[    38.860] 	WinAAttributes: 0x7
[    38.860] 	WinBAttributes: 0x0
[    38.860] 	WinGranularity: 64
[    38.860] 	WinSize: 64
[    38.860] 	WinASegment: 0xa000
[    38.860] 	WinBSegment: 0xa000
[    38.860] 	WinFuncPtr: 0xc0008960
[    38.860] 	BytesPerScanline: 1600
[    38.860] 	XResolution: 800
[    38.860] 	YResolution: 600
[    38.860] 	XCharSize: 8
[    38.860] 	YCharSize: 16
[    38.860] 	NumberOfPlanes: 1
[    38.860] 	BitsPerPixel: 15
[    38.860] 	NumberOfBanks: 1
[    38.860] 	MemoryModel: 6
[    38.860] 	BankSize: 0
[    38.860] 	NumberOfImages: 7
[    38.860] 	RedMaskSize: 5
[    38.860] 	RedFieldPosition: 10
[    38.860] 	GreenMaskSize: 5
[    38.860] 	GreenFieldPosition: 5
[    38.860] 	BlueMaskSize: 5
[    38.860] 	BlueFieldPosition: 0
[    38.860] 	RsvdMaskSize: 0
[    38.860] 	RsvdFieldPosition: 0
[    38.860] 	DirectColorModeInfo: 0
[    38.860] 	PhysBasePtr: 0xc0000000
[    38.860] 	LinBytesPerScanLine: 1600
[    38.860] 	BnkNumberOfImagePages: 7
[    38.860] 	LinNumberOfImagePages: 7
[    38.860] 	LinRedMaskSize: 5
[    38.860] 	LinRedFieldPosition: 10
[    38.860] 	LinGreenMaskSize: 5
[    38.860] 	LinGreenFieldPosition: 5
[    38.860] 	LinBlueMaskSize: 5
[    38.860] 	LinBlueFieldPosition: 0
[    38.860] 	LinRsvdMaskSize: 0
[    38.860] 	LinRsvdFieldPosition: 0
[    38.860] 	MaxPixelClock: 0
[    38.861] Mode: 114 (800x600)
[    38.861] 	ModeAttributes: 0x9b
[    38.861] 	WinAAttributes: 0x7
[    38.861] 	WinBAttributes: 0x0
[    38.861] 	WinGranularity: 64
[    38.861] 	WinSize: 64
[    38.861] 	WinASegment: 0xa000
[    38.861] 	WinBSegment: 0xa000
[    38.861] 	WinFuncPtr: 0xc0008960
[    38.861] 	BytesPerScanline: 1600
[    38.861] 	XResolution: 800
[    38.861] 	YResolution: 600
[    38.861] 	XCharSize: 8
[    38.861] 	YCharSize: 16
[    38.861] 	NumberOfPlanes: 1
[    38.861] 	BitsPerPixel: 16
[    38.861] 	NumberOfBanks: 1
[    38.861] 	MemoryModel: 6
[    38.861] 	BankSize: 0
[    38.861] 	NumberOfImages: 7
[    38.861] 	RedMaskSize: 5
[    38.861] 	RedFieldPosition: 11
[    38.861] 	GreenMaskSize: 6
[    38.861] 	GreenFieldPosition: 5
[    38.861] 	BlueMaskSize: 5
[    38.861] 	BlueFieldPosition: 0
[    38.861] 	RsvdMaskSize: 0
[    38.861] 	RsvdFieldPosition: 0
[    38.861] 	DirectColorModeInfo: 0
[    38.861] 	PhysBasePtr: 0xc0000000
[    38.861] 	LinBytesPerScanLine: 1600
[    38.861] 	BnkNumberOfImagePages: 7
[    38.861] 	LinNumberOfImagePages: 7
[    38.861] 	LinRedMaskSize: 5
[    38.861] 	LinRedFieldPosition: 11
[    38.861] 	LinGreenMaskSize: 6
[    38.861] 	LinGreenFieldPosition: 5
[    38.861] 	LinBlueMaskSize: 5
[    38.861] 	LinBlueFieldPosition: 0
[    38.861] 	LinRsvdMaskSize: 0
[    38.861] 	LinRsvdFieldPosition: 0
[    38.861] 	MaxPixelClock: 0
[    38.862] Mode: 116 (1024x768)
[    38.862] 	ModeAttributes: 0x9b
[    38.862] 	WinAAttributes: 0x7
[    38.862] 	WinBAttributes: 0x0
[    38.862] 	WinGranularity: 64
[    38.862] 	WinSize: 64
[    38.862] 	WinASegment: 0xa000
[    38.862] 	WinBSegment: 0xa000
[    38.862] 	WinFuncPtr: 0xc0008960
[    38.862] 	BytesPerScanline: 2048
[    38.862] 	XResolution: 1024
[    38.862] 	YResolution: 768
[    38.862] 	XCharSize: 8
[    38.862] 	YCharSize: 16
[    38.862] 	NumberOfPlanes: 1
[    38.862] 	BitsPerPixel: 15
[    38.862] 	NumberOfBanks: 1
[    38.862] 	MemoryModel: 6
[    38.862] 	BankSize: 0
[    38.862] 	NumberOfImages: 4
[    38.862] 	RedMaskSize: 5
[    38.862] 	RedFieldPosition: 10
[    38.862] 	GreenMaskSize: 5
[    38.862] 	GreenFieldPosition: 5
[    38.862] 	BlueMaskSize: 5
[    38.862] 	BlueFieldPosition: 0
[    38.862] 	RsvdMaskSize: 0
[    38.862] 	RsvdFieldPosition: 0
[    38.862] 	DirectColorModeInfo: 0
[    38.862] 	PhysBasePtr: 0xc0000000
[    38.862] 	LinBytesPerScanLine: 2048
[    38.862] 	BnkNumberOfImagePages: 4
[    38.862] 	LinNumberOfImagePages: 4
[    38.862] 	LinRedMaskSize: 5
[    38.862] 	LinRedFieldPosition: 10
[    38.862] 	LinGreenMaskSize: 5
[    38.862] 	LinGreenFieldPosition: 5
[    38.862] 	LinBlueMaskSize: 5
[    38.862] 	LinBlueFieldPosition: 0
[    38.862] 	LinRsvdMaskSize: 0
[    38.862] 	LinRsvdFieldPosition: 0
[    38.862] 	MaxPixelClock: 0
[    38.862] Mode: 117 (1024x768)
[    38.863] 	ModeAttributes: 0x9b
[    38.863] 	WinAAttributes: 0x7
[    38.863] 	WinBAttributes: 0x0
[    38.863] 	WinGranularity: 64
[    38.863] 	WinSize: 64
[    38.863] 	WinASegment: 0xa000
[    38.863] 	WinBSegment: 0xa000
[    38.863] 	WinFuncPtr: 0xc0008960
[    38.863] 	BytesPerScanline: 2048
[    38.863] 	XResolution: 1024
[    38.863] 	YResolution: 768
[    38.863] 	XCharSize: 8
[    38.863] 	YCharSize: 16
[    38.863] 	NumberOfPlanes: 1
[    38.863] 	BitsPerPixel: 16
[    38.863] 	NumberOfBanks: 1
[    38.863] 	MemoryModel: 6
[    38.863] 	BankSize: 0
[    38.863] 	NumberOfImages: 4
[    38.863] 	RedMaskSize: 5
[    38.863] 	RedFieldPosition: 11
[    38.863] 	GreenMaskSize: 6
[    38.863] 	GreenFieldPosition: 5
[    38.863] 	BlueMaskSize: 5
[    38.863] 	BlueFieldPosition: 0
[    38.863] 	RsvdMaskSize: 0
[    38.863] 	RsvdFieldPosition: 0
[    38.863] 	DirectColorModeInfo: 0
[    38.863] 	PhysBasePtr: 0xc0000000
[    38.863] 	LinBytesPerScanLine: 2048
[    38.863] 	BnkNumberOfImagePages: 4
[    38.863] 	LinNumberOfImagePages: 4
[    38.863] 	LinRedMaskSize: 5
[    38.863] 	LinRedFieldPosition: 11
[    38.863] 	LinGreenMaskSize: 6
[    38.863] 	LinGreenFieldPosition: 5
[    38.863] 	LinBlueMaskSize: 5
[    38.863] 	LinBlueFieldPosition: 0
[    38.863] 	LinRsvdMaskSize: 0
[    38.863] 	LinRsvdFieldPosition: 0
[    38.863] 	MaxPixelClock: 0
[    38.863] Mode: 127 (320x240)
[    38.863] 	ModeAttributes: 0x9f
[    38.864] 	WinAAttributes: 0x7
[    38.864] 	WinBAttributes: 0x0
[    38.864] 	WinGranularity: 64
[    38.864] 	WinSize: 64
[    38.864] 	WinASegment: 0xa000
[    38.864] 	WinBSegment: 0xa000
[    38.864] 	WinFuncPtr: 0xc0008960
[    38.864] 	BytesPerScanline: 320
[    38.864] 	XResolution: 320
[    38.864] 	YResolution: 240
[    38.864] 	XCharSize: 8
[    38.864] 	YCharSize: 8
[    38.864] 	NumberOfPlanes: 1
[    38.864] 	BitsPerPixel: 8
[    38.864] 	NumberOfBanks: 1
[    38.864] 	MemoryModel: 4
[    38.864] 	BankSize: 0
[    38.864] 	NumberOfImages: 63
[    38.864] 	RedMaskSize: 0
[    38.864] 	RedFieldPosition: 0
[    38.864] 	GreenMaskSize: 0
[    38.864] 	GreenFieldPosition: 0
[    38.864] 	BlueMaskSize: 0
[    38.864] 	BlueFieldPosition: 0
[    38.864] 	RsvdMaskSize: 0
[    38.864] 	RsvdFieldPosition: 0
[    38.864] 	DirectColorModeInfo: 0
[    38.864] 	PhysBasePtr: 0xc0000000
[    38.864] 	LinBytesPerScanLine: 320
[    38.864] 	BnkNumberOfImagePages: 63
[    38.864] 	LinNumberOfImagePages: 63
[    38.864] 	LinRedMaskSize: 0
[    38.864] 	LinRedFieldPosition: 0
[    38.864] 	LinGreenMaskSize: 0
[    38.864] 	LinGreenFieldPosition: 0
[    38.864] 	LinBlueMaskSize: 0
[    38.864] 	LinBlueFieldPosition: 0
[    38.864] 	LinRsvdMaskSize: 0
[    38.864] 	LinRsvdFieldPosition: 0
[    38.864] 	MaxPixelClock: 0
[    38.864] Mode: 128 (400x300)
[    38.864] 	ModeAttributes: 0x9f
[    38.865] 	WinBSegment: 0xa000
[    38.865] 	WinFuncPtr: 0xc0008960
[    38.865] 	BytesPerScanline: 400
[    38.865] 	XResolution: 400
[    38.865] 	YResolution: 300
[    38.865] 	XCharSize: 8
[    38.865] 	YCharSize: 8
[    38.865] 	NumberOfPlanes: 1
[    38.865] 	BitsPerPixel: 8
[    38.865] 	NumberOfBanks: 1
[    38.865] 	MemoryModel: 4
[    38.865] 	BankSize: 0
[    38.865] 	NumberOfImages: 63
[    38.865] 	RedMaskSize: 0
[    38.865] 	RedFieldPosition: 0
[    38.865] 	GreenMaskSize: 0
[    38.865] 	GreenFieldPosition: 0
[    38.865] 	BlueMaskSize: 0
[    38.865] 	BlueFieldPosition: 0
[    38.865] 	RsvdMaskSize: 0
[    38.865] 	RsvdFieldPosition: 0
[    38.865] 	DirectColorModeInfo: 0
[    38.865] 	PhysBasePtr: 0xc0000000
[    38.865] 	LinBytesPerScanLine: 400
[    38.865] 	BnkNumberOfImagePages: 63
[    38.865] 	LinNumberOfImagePages: 63
[    38.865] 	LinRedMaskSize: 0
[    38.865] 	LinRedFieldPosition: 0
[    38.865] 	LinGreenMaskSize: 0
[    38.865] 	LinGreenFieldPosition: 0
[    38.865] 	LinBlueMaskSize: 0
[    38.865] 	LinBlueFieldPosition: 0
[    38.865] 	LinRsvdMaskSize: 0
[    38.865] 	LinRsvdFieldPosition: 0
[    38.865] 	MaxPixelClock: 0
[    38.865] Mode: 129 (512x384)
[    38.865] 	ModeAttributes: 0x9f
[    38.865] 	WinAAttributes: 0x7
[    38.865] 	WinBAttributes: 0x0
[    38.865] 	WinGranularity: 64
[    38.865] 	WinSize: 64
[    38.865] 	WinASegment: 0xa000
[    38.865] 	BytesPerScanline: 512
[    38.865] 	XResolution: 512
[    38.865] 	YResolution: 384
[    38.866] 	XCharSize: 8
[    38.866] 	YCharSize: 8
[    38.866] 	NumberOfPlanes: 1
[    38.866] 	BitsPerPixel: 8
[    38.866] 	NumberOfBanks: 1
[    38.866] 	MemoryModel: 4
[    38.866] 	BankSize: 0
[    38.866] 	NumberOfImages: 41
[    38.866] 	RedMaskSize: 0
[    38.866] 	RedFieldPosition: 0
[    38.866] 	GreenMaskSize: 0
[    38.866] 	GreenFieldPosition: 0
[    38.866] 	BlueMaskSize: 0
[    38.866] 	BlueFieldPosition: 0
[    38.866] 	RsvdMaskSize: 0
[    38.866] 	RsvdFieldPosition: 0
[    38.866] 	DirectColorModeInfo: 0
[    38.866] 	PhysBasePtr: 0xc0000000
[    38.866] 	LinBytesPerScanLine: 512
[    38.866] 	BnkNumberOfImagePages: 41
[    38.866] 	LinNumberOfImagePages: 41
[    38.866] 	LinRedMaskSize: 0
[    38.866] 	LinRedFieldPosition: 0
[    38.866] 	LinGreenMaskSize: 0
[    38.866] 	LinGreenFieldPosition: 0
[    38.866] 	LinBlueMaskSize: 0
[    38.866] 	LinBlueFieldPosition: 0
[    38.866] 	LinRsvdMaskSize: 0
[    38.866] 	LinRsvdFieldPosition: 0
[    38.866] 	MaxPixelClock: 0
[    38.866] Mode: 12a (320x240)
[    38.866] 	ModeAttributes: 0x9b
[    38.866] 	WinAAttributes: 0x7
[    38.866] 	WinBAttributes: 0x0
[    38.866] 	WinGranularity: 64
[    38.866] 	WinSize: 64
[    38.866] 	WinASegment: 0xa000
[    38.866] 	WinBSegment: 0xa000
[    38.866] 	WinFuncPtr: 0xc0008960
[    38.866] 	BytesPerScanline: 640
[    38.866] 	XResolution: 320
[    38.866] 	YResolution: 240
[    38.866] 	BitsPerPixel: 16
[    38.866] 	MemoryModel: 6
[    38.867] 	BankSize: 0
[    38.867] 	NumberOfImages: 41
[    38.867] 	RedMaskSize: 5
[    38.867] 	RedFieldPosition: 11
[    38.867] 	GreenMaskSize: 6
[    38.867] 	GreenFieldPosition: 5
[    38.867] 	BlueMaskSize: 5
[    38.867] 	BlueFieldPosition: 0
[    38.867] 	RsvdMaskSize: 0
[    38.867] 	RsvdFieldPosition: 0
[    38.867] 	DirectColorModeInfo: 0
[    38.867] 	PhysBasePtr: 0xc0000000
[    38.867] 	LinBytesPerScanLine: 640
[    38.867] 	BnkNumberOfImagePages: 41
[    38.867] 	LinNumberOfImagePages: 41
[    38.867] 	LinRedMaskSize: 5
[    38.867] 	LinRedFieldPosition: 11
[    38.867] 	LinGreenMaskSize: 6
[    38.867] 	LinGreenFieldPosition: 5
[    38.867] 	LinBlueMaskSize: 5
[    38.867] 	LinBlueFieldPosition: 0
[    38.867] 	LinRsvdMaskSize: 0
[    38.867] 	LinRsvdFieldPosition: 0
[    38.867] 	MaxPixelClock: 0
[    38.867] Mode: 12b (400x300)
[    38.867] 	ModeAttributes: 0x9b
[    38.867] 	WinAAttributes: 0x7
[    38.867] 	WinBAttributes: 0x0
[    38.867] 	WinGranularity: 64
[    38.867] 	WinSize: 64
[    38.867] 	WinASegment: 0xa000
[    38.867] 	WinBSegment: 0xa000
[    38.867] 	WinFuncPtr: 0xc0008960
[    38.867] 	BytesPerScanline: 800
[    38.867] 	XResolution: 400
[    38.867] 	YResolution: 300
[    38.867] 	XCharSize: 8
[    38.867] 	YCharSize: 8
[    38.867] 	NumberOfPlanes: 1
[    38.867] 	BitsPerPixel: 16
[    38.867] 	NumberOfBanks: 1
[    38.867] 	MemoryModel: 6
[    38.867] 	NumberOfImages: 31
[    38.868] 	RedFieldPosition: 11
[    38.868] 	GreenMaskSize: 6
[    38.868] 	GreenFieldPosition: 5
[    38.868] 	BlueMaskSize: 5
[    38.868] 	BlueFieldPosition: 0
[    38.868] 	RsvdMaskSize: 0
[    38.868] 	RsvdFieldPosition: 0
[    38.868] 	DirectColorModeInfo: 0
[    38.868] 	PhysBasePtr: 0xc0000000
[    38.868] 	LinBytesPerScanLine: 800
[    38.868] 	BnkNumberOfImagePages: 31
[    38.868] 	LinNumberOfImagePages: 31
[    38.868] 	LinRedMaskSize: 5
[    38.868] 	LinRedFieldPosition: 11
[    38.868] 	LinGreenMaskSize: 6
[    38.868] 	LinGreenFieldPosition: 5
[    38.868] 	LinBlueMaskSize: 5
[    38.868] 	LinBlueFieldPosition: 0
[    38.868] 	LinRsvdMaskSize: 0
[    38.868] 	LinRsvdFieldPosition: 0
[    38.868] 	MaxPixelClock: 0
[    38.868] Mode: 12c (512x384)
[    38.868] 	ModeAttributes: 0x9b
[    38.868] 	WinAAttributes: 0x7
[    38.868] 	WinBAttributes: 0x0
[    38.868] 	WinGranularity: 64
[    38.868] 	WinSize: 64
[    38.868] 	WinASegment: 0xa000
[    38.868] 	WinBSegment: 0xa000
[    38.868] 	WinFuncPtr: 0xc0008960
[    38.868] 	BytesPerScanline: 1024
[    38.868] 	XResolution: 512
[    38.868] 	YResolution: 384
[    38.868] 	XCharSize: 8
[    38.868] 	YCharSize: 8
[    38.868] 	NumberOfPlanes: 1
[    38.868] 	BitsPerPixel: 16
[    38.868] 	NumberOfBanks: 1
[    38.868] 	MemoryModel: 6
[    38.868] 	BankSize: 0
[    38.868] 	NumberOfImages: 20
[    38.868] 	RedMaskSize: 5
[    38.869] 	BlueMaskSize: 5
[    38.869] 	BlueFieldPosition: 0
[    38.869] 	RsvdMaskSize: 0
[    38.869] 	RsvdFieldPosition: 0
[    38.869] 	DirectColorModeInfo: 0
[    38.869] 	PhysBasePtr: 0xc0000000
[    38.869] 	LinBytesPerScanLine: 1024
[    38.869] 	BnkNumberOfImagePages: 20
[    38.869] 	LinNumberOfImagePages: 20
[    38.869] 	LinRedMaskSize: 5
[    38.869] 	LinRedFieldPosition: 11
[    38.869] 	LinGreenMaskSize: 6
[    38.869] 	LinGreenFieldPosition: 5
[    38.869] 	LinBlueMaskSize: 5
[    38.869] 	LinBlueFieldPosition: 0
[    38.869] 	LinRsvdMaskSize: 0
[    38.869] 	LinRsvdFieldPosition: 0
[    38.869] 	MaxPixelClock: 0
[    38.869] Mode: 12d (320x200)
[    38.869] 	ModeAttributes: 0x9f
[    38.869] 	WinAAttributes: 0x7
[    38.869] 	WinBAttributes: 0x0
[    38.869] 	WinGranularity: 64
[    38.869] 	WinSize: 64
[    38.869] 	WinASegment: 0xa000
[    38.869] 	WinBSegment: 0xa000
[    38.869] 	WinFuncPtr: 0xc0008960
[    38.869] 	BytesPerScanline: 320
[    38.869] 	XResolution: 320
[    38.869] 	YResolution: 200
[    38.869] 	XCharSize: 8
[    38.869] 	YCharSize: 8
[    38.869] 	NumberOfPlanes: 1
[    38.869] 	BitsPerPixel: 8
[    38.869] 	NumberOfBanks: 1
[    38.869] 	MemoryModel: 4
[    38.869] 	BankSize: 0
[    38.869] 	NumberOfImages: 127
[    38.869] 	RedMaskSize: 0
[    38.869] 	RedFieldPosition: 0
[    38.869] 	GreenMaskSize: 0
[    38.869] 	GreenFieldPosition: 0
[    38.869] 	BlueMaskSize: 0
[    38.870] 	PhysBasePtr: 0xc0000000
[    38.870] 	LinBytesPerScanLine: 320
[    38.870] 	BnkNumberOfImagePages: 127
[    38.870] 	LinNumberOfImagePages: 127
[    38.870] 	LinRedMaskSize: 0
[    38.870] 	LinRedFieldPosition: 0
[    38.870] 	LinGreenMaskSize: 0
[    38.870] 	LinGreenFieldPosition: 0
[    38.870] 	LinBlueMaskSize: 0
[    38.870] 	LinBlueFieldPosition: 0
[    38.870] 	LinRsvdMaskSize: 0
[    38.870] 	LinRsvdFieldPosition: 0
[    38.870] 	MaxPixelClock: 0
[    38.870] Mode: 131 (640x400)
[    38.870] 	ModeAttributes: 0x9b
[    38.870] 	WinAAttributes: 0x7
[    38.870] 	WinBAttributes: 0x0
[    38.870] 	WinGranularity: 64
[    38.870] 	WinSize: 64
[    38.870] 	WinASegment: 0xa000
[    38.870] 	WinBSegment: 0xa000
[    38.870] 	WinFuncPtr: 0xc0008960
[    38.870] 	BytesPerScanline: 1280
[    38.870] 	XResolution: 640
[    38.870] 	YResolution: 400
[    38.870] 	XCharSize: 8
[    38.870] 	YCharSize: 16
[    38.870] 	NumberOfPlanes: 1
[    38.870] 	BitsPerPixel: 16
[    38.870] 	NumberOfBanks: 1
[    38.870] 	MemoryModel: 6
[    38.870] 	BankSize: 0
[    38.870] 	NumberOfImages: 15
[    38.870] 	RedMaskSize: 5
[    38.870] 	RedFieldPosition: 11
[    38.870] 	GreenMaskSize: 6
[    38.870] 	GreenFieldPosition: 5
[    38.870] 	BlueMaskSize: 5
[    38.870] 	BlueFieldPosition: 0
[    38.870] 	RsvdMaskSize: 0
[    38.870] 	RsvdFieldPosition: 0
[    38.870] 	DirectColorModeInfo: 0
[    38.871] 	PhysBasePtr: 0xc0000000
[    38.871] 	LinBytesPerScanLine: 1280
[    38.871] 	BnkNumberOfImagePages: 15
[    38.871] 	LinNumberOfImagePages: 15
[    38.871] 	LinRedMaskSize: 5
[    38.871] 	LinRedFieldPosition: 11
[    38.871] 	LinGreenMaskSize: 6
[    38.871] 	LinGreenFieldPosition: 5
[    38.871] 	LinBlueMaskSize: 5
[    38.871] 	LinBlueFieldPosition: 0
[    38.871] 	LinRsvdMaskSize: 0
[    38.871] 	LinRsvdFieldPosition: 0
[    38.871] 	MaxPixelClock: 0
[    38.871] *Mode: 112 (640x480)
[    38.871] 	ModeAttributes: 0x9b
[    38.871] 	WinAAttributes: 0x7
[    38.871] 	WinBAttributes: 0x0
[    38.871] 	WinGranularity: 64
[    38.871] 	WinSize: 64
[    38.871] 	WinASegment: 0xa000
[    38.871] 	WinBSegment: 0xa000
[    38.871] 	WinFuncPtr: 0xc0008960
[    38.871] 	BytesPerScanline: 2560
[    38.871] 	XResolution: 640
[    38.871] 	YResolution: 480
[    38.871] 	XCharSize: 8
[    38.871] 	YCharSize: 16
[    38.871] 	NumberOfPlanes: 1
[    38.871] 	BitsPerPixel: 32
[    38.871] 	NumberOfBanks: 1
[    38.871] 	MemoryModel: 6
[    38.871] 	BankSize: 0
[    38.871] 	NumberOfImages: 5
[    38.871] 	RedMaskSize: 8
[    38.871] 	RedFieldPosition: 16
[    38.871] 	GreenMaskSize: 8
[    38.871] 	GreenFieldPosition: 8
[    38.871] 	BlueMaskSize: 8
[    38.871] 	BlueFieldPosition: 0
[    38.871] 	RsvdMaskSize: 8
[    38.871] 	RsvdFieldPosition: 24
[    38.871] 	DirectColorModeInfo: 0
[    38.872] 	PhysBasePtr: 0xc0000000
[    38.872] 	LinBytesPerScanLine: 2560
[    38.872] 	BnkNumberOfImagePages: 5
[    38.872] 	LinNumberOfImagePages: 5
[    38.872] 	LinRedMaskSize: 8
[    38.872] 	LinRedFieldPosition: 16
[    38.872] 	LinGreenMaskSize: 8
[    38.872] 	LinGreenFieldPosition: 8
[    38.872] 	LinBlueMaskSize: 8
[    38.872] 	LinBlueFieldPosition: 0
[    38.872] 	LinRsvdMaskSize: 8
[    38.872] 	LinRsvdFieldPosition: 24
[    38.872] 	MaxPixelClock: 0
[    38.872] *Mode: 115 (800x600)
[    38.872] 	ModeAttributes: 0x9b
[    38.872] 	WinAAttributes: 0x7
[    38.872] 	WinBAttributes: 0x0
[    38.872] 	WinGranularity: 64
[    38.872] 	WinSize: 64
[    38.872] 	WinASegment: 0xa000
[    38.872] 	WinBSegment: 0xa000
[    38.872] 	WinFuncPtr: 0xc0008960
[    38.872] 	BytesPerScanline: 3200
[    38.872] 	XResolution: 800
[    38.872] 	YResolution: 600
[    38.872] 	XCharSize: 8
[    38.872] 	YCharSize: 16
[    38.872] 	NumberOfPlanes: 1
[    38.872] 	BitsPerPixel: 32
[    38.872] 	NumberOfBanks: 1
[    38.872] 	MemoryModel: 6
[    38.872] 	BankSize: 0
[    38.872] 	NumberOfImages: 3
[    38.872] 	RedMaskSize: 8
[    38.872] 	RedFieldPosition: 16
[    38.872] 	GreenMaskSize: 8
[    38.872] 	GreenFieldPosition: 8
[    38.872] 	BlueMaskSize: 8
[    38.872] 	BlueFieldPosition: 0
[    38.872] 	RsvdMaskSize: 8
[    38.873] 	RsvdFieldPosition: 24
[    38.873] 	DirectColorModeInfo: 0
[    38.873] 	PhysBasePtr: 0xc0000000
[    38.873] 	LinBytesPerScanLine: 3200
[    38.873] 	BnkNumberOfImagePages: 3
[    38.873] 	LinNumberOfImagePages: 3
[    38.873] 	LinRedMaskSize: 8
[    38.873] 	LinRedFieldPosition: 16
[    38.873] 	LinGreenMaskSize: 8
[    38.873] 	LinGreenFieldPosition: 8
[    38.873] 	LinBlueMaskSize: 8
[    38.873] 	LinBlueFieldPosition: 0
[    38.873] 	LinRsvdMaskSize: 8
[    38.873] 	LinRsvdFieldPosition: 24
[    38.873] 	MaxPixelClock: 0
[    38.873] *Mode: 118 (1024x768)
[    38.873] 	ModeAttributes: 0x9b
[    38.873] 	WinAAttributes: 0x7
[    38.873] 	WinBAttributes: 0x0
[    38.873] 	WinGranularity: 64
[    38.873] 	WinSize: 64
[    38.873] 	WinASegment: 0xa000
[    38.873] 	WinBSegment: 0xa000
[    38.873] 	WinFuncPtr: 0xc0008960
[    38.873] 	BytesPerScanline: 4096
[    38.873] 	XResolution: 1024
[    38.873] 	YResolution: 768
[    38.873] 	XCharSize: 8
[    38.873] 	YCharSize: 16
[    38.873] 	NumberOfPlanes: 1
[    38.873] 	BitsPerPixel: 32
[    38.873] 	NumberOfBanks: 1
[    38.873] 	MemoryModel: 6
[    38.873] 	BankSize: 0
[    38.873] 	NumberOfImages: 1
[    38.873] 	RedMaskSize: 8
[    38.873] 	RedFieldPosition: 16
[    38.873] 	GreenMaskSize: 8
[    38.873] 	GreenFieldPosition: 8
[    38.873] 	BlueMaskSize: 8
[    38.873] 	BlueFieldPosition: 0
[    38.874] 	RsvdMaskSize: 8
[    38.874] 	RsvdFieldPosition: 24
[    38.874] 	DirectColorModeInfo: 0
[    38.874] 	PhysBasePtr: 0xc0000000
[    38.874] 	LinBytesPerScanLine: 4096
[    38.874] 	BnkNumberOfImagePages: 1
[    38.874] 	LinNumberOfImagePages: 1
[    38.874] 	LinRedMaskSize: 8
[    38.874] 	LinRedFieldPosition: 16
[    38.874] 	LinGreenMaskSize: 8
[    38.874] 	LinGreenFieldPosition: 8
[    38.874] 	LinBlueMaskSize: 8
[    38.874] 	LinBlueFieldPosition: 0
[    38.874] 	LinRsvdMaskSize: 8
[    38.874] 	LinRsvdFieldPosition: 24
[    38.874] 	MaxPixelClock: 0
[    38.875] Mode: 102 (800x600)
[    38.875] 	ModeAttributes: 0x1f
[    38.875] 	WinAAttributes: 0x7
[    38.875] 	WinBAttributes: 0x0
[    38.875] 	WinGranularity: 64
[    38.875] 	WinSize: 64
[    38.875] 	WinASegment: 0xa000
[    38.875] 	WinBSegment: 0xa000
[    38.875] 	WinFuncPtr: 0xc0008960
[    38.875] 	BytesPerScanline: 100
[    38.875] 	XResolution: 800
[    38.875] 	YResolution: 600
[    38.875] 	XCharSize: 8
[    38.875] 	YCharSize: 16
[    38.875] 	NumberOfPlanes: 4
[    38.875] 	BitsPerPixel: 4
[    38.875] 	NumberOfBanks: 1
[    38.875] 	MemoryModel: 3
[    38.875] 	BankSize: 0
[    38.875] 	NumberOfImages: 31
[    38.875] 	RedMaskSize: 0
[    38.875] 	RedFieldPosition: 0
[    38.875] 	GreenMaskSize: 0
[    38.875] 	GreenFieldPosition: 0
[    38.875] 	BlueMaskSize: 0
[    38.875] 	BlueFieldPosition: 0
[    38.875] 	RsvdMaskSize: 0
[    38.875] 	RsvdFieldPosition: 0
[    38.875] 	DirectColorModeInfo: 0
[    38.875] 	PhysBasePtr: 0xc0000000
[    38.875] 	LinBytesPerScanLine: 100
[    38.875] 	BnkNumberOfImagePages: 31
[    38.875] 	LinNumberOfImagePages: 31
[    38.875] 	LinRedMaskSize: 0
[    38.875] 	LinRedFieldPosition: 0
[    38.875] 	LinGreenMaskSize: 0
[    38.875] 	LinGreenFieldPosition: 0
[    38.875] 	LinBlueMaskSize: 0
[    38.875] 	LinBlueFieldPosition: 0
[    38.875] 	LinRsvdMaskSize: 0
[    38.875] 	LinRsvdFieldPosition: 0
[    38.875] 	MaxPixelClock: 0
[    38.875]
[    38.875] (II) VESA(0): Total Memory: 2048 64KB banks (131072kB)
[    38.876] (II) VESA(0): <default monitor>: Using default hsync range of 31.50-48.00 kHz
[    38.876] (II) VESA(0): <default monitor>: Using default vrefresh range of 50.00-70.00 Hz
[    38.876] (II) VESA(0): <default monitor>: Using default maximum pixel clock of 65.00 MHz
[    38.876] (WW) VESA(0): Unable to estimate virtual size
[    38.876] (II) VESA(0): Not using built-in mode "1280x768" (no mode of this name)
[    38.876] (II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
[    38.876] (II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
[    38.876] (II) VESA(0): Not using built-in mode "640x480" (no mode of this name)
[    38.876] (WW) VESA(0): No valid modes left. Trying less strict filter...
[    38.876] (II) VESA(0): <default monitor>: Using hsync range of 31.50-48.00 kHz
[    38.876] (II) VESA(0): <default monitor>: Using vrefresh range of 50.00-70.00 Hz
[    38.876] (II) VESA(0): <default monitor>: Using maximum pixel clock of 65.00 MHz
[    38.876] (II) VESA(0): Not using built-in mode "1280x768" (hsync out of range)
[    38.876] (II) VESA(0): Virtual size is 1024x768 (pitch 1024)
[    38.876] (**) VESA(0): *Built-in mode "1024x768"
[    38.876] (**) VESA(0): *Built-in mode "800x600"
[    38.876] (**) VESA(0): *Built-in mode "640x480"
[    38.876] (==) VESA(0): DPI set to (96, 96)
[    38.876] (**) VESA(0): Using "Shadow Framebuffer"
[    38.876] (II) Loading sub module "shadow"
[    38.876] (II) LoadModule: "shadow"
[    38.876] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    38.901] (II) Module shadow: vendor="X.Org Foundation"
[    38.901] 	compiled for 1.20.11, module version = 1.1.0
[    38.901] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    38.902] (II) Loading sub module "fb"
[    38.902] (II) LoadModule: "fb"
[    38.902] (II) Loading /usr/lib/xorg/modules/libfb.so
[    38.963] (II) Module fb: vendor="X.Org Foundation"
[    38.964] 	compiled for 1.20.11, module version = 1.0.0
[    38.964] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    38.964] (II) Loading sub module "int10"
[    38.964] (II) LoadModule: "int10"
[    38.964] (II) Loading /usr/lib/xorg/modules/libint10.so
[    38.964] (II) Module int10: vendor="X.Org Foundation"
[    38.964] 	ABI class: X.Org Video Driver, version 24.1
[    38.964] (II) VESA(0): initializing int10
[    38.970] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[    38.971] (II) VESA(0): VESA BIOS detected
[    38.971] (II) VESA(0): VESA VBE Version 3.0
[    38.971] (II) VESA(0): VESA VBE Total Mem: 131072 kB
[    38.971] (II) VESA(0): VESA VBE OEM: SiS
[    38.971] (II) VESA(0): VESA VBE OEM Software Rev: 1.0
[    38.971] (II) VESA(0): VESA VBE OEM Vendor: Silicon Integrated Systems Corp.
[    38.971] (II) VESA(0): VESA VBE OEM Product: 6330
[    38.971] (II) VESA(0): VESA VBE OEM Product Rev: 3.72.1E
[    38.972] (II) VESA(0): virtual address = 0x7f7bb4c06000, VGAbase = 0x7f7bbcd4e000
	physical address = 0xc0000000, size = 134217728
[    38.985] (II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
[    39.508] (==) VESA(0): Default visual is TrueColor
[    39.535] (==) VESA(0): Backing store enabled
[    39.537] (==) VESA(0): DPMS enabled
[    39.545] (II) Initializing extension Generic Event Extension
[    39.545] (II) Initializing extension SHAPE
[    39.546] (II) Initializing extension MIT-SHM
[    39.546] (II) Initializing extension XInputExtension
[    39.561] (II) Initializing extension XTEST
[    39.562] (II) Initializing extension BIG-REQUESTS
[    39.563] (II) Initializing extension SYNC
[    39.563] (II) Initializing extension XKEYBOARD
[    39.564] (II) Initializing extension XC-MISC
[    39.564] (II) Initializing extension SECURITY
[    39.564] (II) Initializing extension XFIXES
[    39.565] (II) Initializing extension RENDER
[    39.565] (II) Initializing extension RANDR
[    39.566] (II) Initializing extension COMPOSITE
[    39.590] (II) Initializing extension DAMAGE
[    39.590] (II) Initializing extension MIT-SCREEN-SAVER
[    39.591] (II) Initializing extension DOUBLE-BUFFER
[    39.592] (II) Initializing extension RECORD
[    39.592] (II) Initializing extension DPMS
[    39.593] (II) Initializing extension Present
[    39.593] (II) Initializing extension DRI3
[    39.593] (II) Initializing extension X-Resource
[    39.594] (II) Initializing extension XVideo
[    39.594] (II) Initializing extension XVideo-MotionCompensation
[    39.594] (II) Initializing extension SELinux
[    39.594] (II) SELinux: Disabled on system
[    39.594] (II) Initializing extension GLX
[    39.603] (II) AIGLX: Screen 0 is not DRI2 capable
[    42.496] (II) IGLX: Loaded and initialized swrast
[    42.496] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    42.496] (II) Initializing extension XFree86-VidModeExtension
[    42.497] (II) Initializing extension XFree86-DGA
[    42.497] (II) Initializing extension XFree86-DRI
[    42.497] (II) Initializing extension DRI2
[    42.959] (II) config/udev: Adding input device Power Button (/dev/input/event6)
[    42.959] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    42.959] (II) LoadModule: "libinput"
[    42.960] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    43.019] (II) Module libinput: vendor="X.Org Foundation"
[    43.019] 	compiled for 1.20.8, module version = 0.30.0
[    43.019] 	Module class: X.Org XInput Driver
[    43.019] 	ABI class: X.Org XInput driver, version 24.1
[    43.019] (II) Using input driver 'libinput' for 'Power Button'
[    43.019] (**) Power Button: always reports core events
[    43.019] (**) Option "Device" "/dev/input/event6"
[    43.020] (**) Option "_source" "server/udev"
[    43.057] (II) event6  - Power Button: is tagged by udev as: Keyboard
[    43.057] (II) event6  - Power Button: device is a keyboard
[    43.057] (II) event6  - Power Button: device removed
[    43.084] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input13/event6"
[    43.084] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    43.084] (**) Option "xkb_model" "pc105"
[    43.084] (**) Option "xkb_layout" "es,us"
[    43.084] (**) Option "xkb_options" "grp:alt_space_toggle"
[    43.155] (II) event6  - Power Button: is tagged by udev as: Keyboard
[    43.155] (II) event6  - Power Button: device is a keyboard
[    43.156] (II) config/udev: Adding input device Video Bus (/dev/input/event1)
[    43.156] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    43.157] (II) Using input driver 'libinput' for 'Video Bus'
[    43.157] (**) Video Bus: always reports core events
[    43.157] (**) Option "Device" "/dev/input/event1"
[    43.157] (**) Option "_source" "server/udev"
[    43.159] (II) event1  - Video Bus: is tagged by udev as: Keyboard
[    43.159] (II) event1  - Video Bus: device is a keyboard
[    43.159] (II) event1  - Video Bus: device removed
[    43.176] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:0b/LNXVIDEO:00/input/input5/event1"
[    43.176] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    43.176] (**) Option "xkb_model" "pc105"
[    43.176] (**) Option "xkb_layout" "es,us"
[    43.176] (**) Option "xkb_options" "grp:alt_space_toggle"
[    43.178] (II) event1  - Video Bus: is tagged by udev as: Keyboard
[    43.179] (II) event1  - Video Bus: device is a keyboard
[    43.182] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    43.182] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    43.182] (II) Using input driver 'libinput' for 'Power Button'
[    43.183] (**) Power Button: always reports core events
[    43.183] (**) Option "Device" "/dev/input/event3"
[    43.183] (**) Option "_source" "server/udev"
[    43.185] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    43.185] (II) event3  - Power Button: device is a keyboard
[    43.186] (II) event3  - Power Button: device removed
[    43.200] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input10/event3"
[    43.200] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    43.200] (**) Option "xkb_model" "pc105"
[    43.200] (**) Option "xkb_layout" "es,us"
[    43.200] (**) Option "xkb_options" "grp:alt_space_toggle"
[    43.202] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    43.202] (II) event3  - Power Button: device is a keyboard
[    43.205] (II) config/udev: Adding input device Lid Switch (/dev/input/event5)
[    43.205] (II) No input driver specified, ignoring this device.
[    43.205] (II) This device may have been added with another device file.
[    43.207] (II) config/udev: Adding input device Sleep Button (/dev/input/event4)
[    43.207] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    43.207] (II) Using input driver 'libinput' for 'Sleep Button'
[    43.207] (**) Sleep Button: always reports core events
[    43.207] (**) Option "Device" "/dev/input/event4"
[    43.207] (**) Option "_source" "server/udev"
[    43.209] (II) event4  - Sleep Button: is tagged by udev as: Keyboard
[    43.209] (II) event4  - Sleep Button: device is a keyboard
[    43.210] (II) event4  - Sleep Button: device removed
[    43.220] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input11/event4"
[    43.220] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    43.220] (**) Option "xkb_model" "pc105"
[    43.220] (**) Option "xkb_layout" "es,us"
[    43.220] (**) Option "xkb_options" "grp:alt_space_toggle"
[    43.222] (II) event4  - Sleep Button: is tagged by udev as: Keyboard
[    43.223] (II) event4  - Sleep Button: device is a keyboard
[    43.224] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event8)
[    43.224] (II) No input driver specified, ignoring this device.
[    43.224] (II) This device may have been added with another device file.
[    43.226] (II) config/udev: Adding input device HDA SIS966 Mic (/dev/input/event9)
[    43.226] (II) No input driver specified, ignoring this device.
[    43.226] (II) This device may have been added with another device file.
[    43.231] (II) config/udev: Adding input device HDA SIS966 Line (/dev/input/event10)
[    43.232] (II) No input driver specified, ignoring this device.
[    43.232] (II) This device may have been added with another device file.
[    43.233] (II) config/udev: Adding input device HDA SIS966 Headphone (/dev/input/event11)
[    43.233] (II) No input driver specified, ignoring this device.
[    43.233] (II) This device may have been added with another device file.
[    43.235] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    43.235] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    43.235] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    43.235] (**) AT Translated Set 2 keyboard: always reports core events
[    43.235] (**) Option "Device" "/dev/input/event0"
[    43.235] (**) Option "_source" "server/udev"
[    43.238] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    43.238] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[    43.239] (II) event0  - AT Translated Set 2 keyboard: device removed
[    43.247] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    43.248] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[    43.248] (**) Option "xkb_model" "pc105"
[    43.248] (**) Option "xkb_layout" "es,us"
[    43.248] (**) Option "xkb_options" "grp:alt_space_toggle"
[    43.252] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    43.252] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[    43.255] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event2)
[    43.255] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[    43.255] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Touchpad"
[    43.255] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[    43.255] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    43.255] (**) Option "Device" "/dev/input/event2"
[    43.255] (**) Option "_source" "server/udev"
[    43.259] (II) event2  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[    43.262] (II) event2  - SynPS/2 Synaptics TouchPad: device is a touchpad
[    43.262] (II) event2  - SynPS/2 Synaptics TouchPad: device removed
[    43.292] (**) Option "Tapping" "true"
[    43.292] (**) Option "ScrollMethod" "edge"
[    43.292] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input9/event2"
[    43.292] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 11)
[    43.294] (**) Option "AccelerationScheme" "none"
[    43.294] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[    43.294] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    43.294] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    43.297] (II) event2  - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[    43.300] (II) event2  - SynPS/2 Synaptics TouchPad: device is a touchpad
[    43.303] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    43.303] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "Touchpad"
[    43.303] (II) LoadModule: "synaptics"
[    43.304] (WW) Warning, couldn't open module synaptics
[    43.304] (EE) Failed to load module "synaptics" (module does not exist, 0)
[    43.304] (EE) No input driver matching `synaptics'
[    43.304] (II) Falling back to input driver `libinput'
[    43.304] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[    43.304] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    43.304] (**) Option "Device" "/dev/input/mouse0"
[    43.304] (**) Option "_source" "server/udev"
[    43.380] (II) mouse0  - not using input device '/dev/input/mouse0'.
[    43.380] (EE) libinput: SynPS/2 Synaptics TouchPad: Failed to create a device for /dev/input/mouse0
[    43.380] (EE) PreInit returned 2 for "SynPS/2 Synaptics TouchPad"
[    43.380] (II) UnloadModule: "libinput"
[    43.381] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[    43.381] (II) No input driver specified, ignoring this device.
[    43.382] (II) This device may have been added with another device file.
[    43.384] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event12)
[    43.384] (**) ACPI Virtual Keyboard Device: Applying InputClass "libinput keyboard catchall"
[    43.384] (II) Using input driver 'libinput' for 'ACPI Virtual Keyboard Device'
[    43.384] (**) ACPI Virtual Keyboard Device: always reports core events
[    43.384] (**) Option "Device" "/dev/input/event12"
[    43.384] (**) Option "_source" "server/udev"
[    43.387] (II) event12 - ACPI Virtual Keyboard Device: is tagged by udev as: Keyboard
[    43.387] (II) event12 - ACPI Virtual Keyboard Device: device is a keyboard
[    43.388] (II) event12 - ACPI Virtual Keyboard Device: device removed
[    43.416] (**) Option "config_info" "udev:/sys/devices/virtual/input/input19/event12"
[    43.416] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 12)
[    43.416] (**) Option "xkb_model" "pc105"
[    43.416] (**) Option "xkb_layout" "es,us"
[    43.416] (**) Option "xkb_options" "grp:alt_space_toggle"
[    43.419] (II) event12 - ACPI Virtual Keyboard Device: is tagged by udev as: Keyboard
[    43.419] (II) event12 - ACPI Virtual Keyboard Device: device is a keyboard
[   108.191] (II) Axis 0x1 value 1239 is outside expected range [1256, 4600]
See https://wayland.freedesktop.org/libinput/doc/1.16.4/absolute_coordinate_ranges.html for details
[   318.328] (EE) event2  - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.16.4/touchpad-jumping-cursors.html for details
...and the file xorg.conf I don't have, as you can see on the snapshot.
Looks bad, no? Well, I wil be back tomorrow. Have a good night!
#8 2022-04-23 02:32
Humming Owl
Re: [solved]Screen distorted, SIS771/671, Bangho Mov / Clevo M540SS
@JSM
I actually forgot that you can't execute "sudo Xorg -configure" while being in graphical mode.
In this way you can execute that command:
Execute:
sudo systemctl set-default multi-user.target
sudo reboot
After rebooting you will notice that there is no graphical interface.
Fill the username and password and then execute:
sudo systemctl set-default graphical.target
sudo reboot
The "xorg.conf.new" file should now be located at "/root/".
Sorry for the inconvinience.
#9 2022-04-23 14:17
JSM
@Humming Owl
Thank you. I will do this this afternoon and then let you know.
#10 2022-04-23 22:34
JSM
@Humming Owl
I tried trisquel because I don't want to compromise my Q4OS installation. And it was a good idea! I couldn't start trisquel graphically anymore. But the installation was new, without details and it only takes 10 minutes to install it smile
Ok, luckily the distortion is quite low and I can still work well. In the meantime, I have understood and read a little more, here in the forum (the problem has been raised several times, but has never been solved so far), then I looked at these two articles. Apparently, there are also tools to solve the problem.
https://wiki.ubuntu.com/X/Config/Resolution
https://blog.desdelinux.net/xrandr-pode … u-monitor/
I will now try one of these tools before trying the solution with the terminal. Of course, again with trisquel, in case something should go wrong. However, I still have to find out what screen resolution my notebook has.
#11 2022-04-24 04:31
Humming Owl
@JSM
The terminal thing wasn't a solution but a way to see what could be happening (the configuration for your screen is on that xorg.conf file).
Another thing that I want to ask, what is your computer model?
Cheers.
#12 2022-04-24 07:20
From what I could read here and there on the web, your SiS 771/671 can display up to 1280x800 pixels. The ratio is 1.6. For for the three modes listed in post #5 the ratio is 1.333. Of course, this says nothing about the native resolution of the display. Don't you have the specs of your computer?
#13 2022-04-24 15:53
JSM
@hchiper
@Humming Owl
No, unfortunately I have no information about the computer. I received it as a gift from a church in Buenos Aires 3 days ago. It is an agent product "BANGHO" and there are apparently problems with Linux drivers, as I read last night. But I still didn't have enough time to look for more information.
xorg.conf seems to be out of date, but can still be used. However, it apparently has second priority, behind other conf files.
But maybe I just have to change the drivers. I'll find out smile
#14 2022-04-24 16:34
Your system appears to be using Sis integrated graphics and is agp based. Sis drivers were bad even on the Windows side but Linux support is really poor for Sis chipsets in general. Given the age of the system, gaining supported drivers is probably not going to happen. I recently worked on a Sis based laptop with Ubuntu 20.04 but we were never able to get the chipset nor the igp to work properly. If you can find Sis agp/graphics drivers that are updated for Linux, you may be able to solve the issue. To be honest given the age of the laptop and the fact it uses Sis chipsets, Id buy a used but newer laptop and move on.
#15 2022-04-24 20:14
JSM
@crosscourt
After a search and reading of forum posts in Spanish, it is probably a driver problem. Obviously, there are also problems with the Wifi for BANGHO. Basically everything works on my notebook, even the built-in camera. Unfortunately, I'm not quite sure what kind of model I have, probably BANGHO MOV. I found drivers, but only for Windows. In Linux I would probably have to use an old kernel?
Well, the positive thing is that the distortion is not extreme and I can still work well. Even after several hours (3-4) I do not have a headache smile.
Maybe on trisquel mini 10 I'll try to follow the instructions from above, i.e. insert an additional definition for a monitor with this randr thing. And if I'm lucky, it works and it wasn't the driver after all smile
But another problem I discovered:
If I want to copy something to a system folder as root, I get the message "TDE mediamanger is not running".  It is not listed in the "Service Manager" control panel.
#16 2022-04-26 04:45
Humming Owl
@JSM
If you happen to find the solution don't forget to post it!
I've found some links about some "xorg.conf" files for your graphics card in case you want to test them. Remember to put it on the "/etc/X11/" path.
https://ubuntuperonista.blogspot.com/20 … buntu.html
https://forums.linuxmint.com/viewtopic.php?t=273919
https://www.linuxliteos.com/forums/vide … pcie-vga)/
https://gist.github.com/voyeg3r/576445
https://forums.debian.net/viewtopic.php?f=6&t=120734
There seems to be a lot of issues with that graphic card not being able to function properly on Linux.
Cheers.
#17 2022-04-26 14:32
JSM
@Humming Owl
Thank you! I have been practicing with xrandr in the meantime, but so far unsuccessfully. I am getting various error messages. Perhaps this is also due to the problem with the chip set and the driver. As soon as I have time, I will look at the links.
Another reason could be the BIOS settings.
#18 2022-04-26 14:33
JSM
@Humming Owl
#19 2022-04-26 19:58
JSM
At least now I could find out what kind of notebook it is!
BANGHO MOV is Clevo M540SS
https://guidessimo.com/document/1111518 … al-96.html
#20 2022-04-26 21:20
JSM
Well, I tried a solution from here:
by #8 Post by clasan "2015-12-16 10:07
But unfortunately, another problem appears with "make", a file is not found. This is usually the case with these solutions from forums, they do not work and just take you from one error to another. Hours of effort, no result smile
#21 2022-04-26 21:57
JSM
A very long time ago, when I was still a young man, I studied informatic. In the subject "Software engineering" we read a book by this man. I think it's time more people read his books, especially software developers. I have never become one, because there are many things to do in informatic. Thank God smile But programming in Ada was cool smile
https://en.wikipedia.org/wiki/Grady_Booch
#22 2022-04-27 14:51
JSM
Quite a lot of information to read and then to test. But should I ever find a clean solution for my notebook (and it will only be a solution for exactly this model), then I post it here, or in "Tips and tutorials" and post the link here smile
Linux needs more management! Quality management, project management, stuff management, training management, test management. It's like a man who wants to build a house. First, he sits down and carefully writes down how he wants his house. Then he goes to an architect and let him do the detailed planning. Then the two are looking for a good construction company and only then the excavator comes and excavates the trench for the foundation. With Linux it is unfortunately the case that everyone immediately buys a shovel and starts digging, although no one knows what kind of house should actually be built. The result is a patchwork!
#23 2022-04-30 00:00
JSM
In the meantime, I have taken a few small steps forward. With this guide I could install the old drivers for SIS:
https://easylinuxtipsproject.blogspot.com/p/sis.html
So far I have not done any tests with it.
I also succeeded with "vesa" and an xorg.conf to obtain a resolution of 1280x768. But then the screen is distorted in height, so a circle is an oval, higher than wide. With the automatically created resolution of 1024x768, it is the opposite, that is, wider than high. Thus, the optical resolution must be between 1024 and 1280.
Now I learned in the manual that my screen is a WXGA with an aspect ratio of 16:10. Today 16:9 is common. So here lies the real problem.
Either the SIS drivers are able to generate a corresponding resolution, or I have to try to change the resolution with xrandr, as in this example:
https://unix.stackexchange.com/question … plications
But there is a lot to read and test!
#24 2022-05-01 19:41
JSM
Well, after further unsuccessful attempts to solve the problem with the distorted screen, I have the impression that it cannot be solved with X. The main problem is that Xrandr does not work correctly and produces error messages. I suspect that this is a problem of X.
I also realized that X is being replaced by Wayland and therefore I need a solution with Wayland and not with X wink
At the moment I have a Debian 11 installed with the GNOME desktop, because it works completely with Wayland. After installation, I have a screen resolution of 1024x768 and the display is also distorted, so a circle is an oval, wider than high. But after all, the text is much clearer. Now I will try to find or install the right tools to get a better resolution (1280x800) and correct the distortion.
If it works at some point, I will try to work with Q4OS Trinity and Trisquel Mini (lightdm) also with Wayland, if this is already technically possible. And if not, I will switch the desktop on both to get Wayland.
Too bad I didn't find a solution with X. For the moment it would have served me.
#25 2022-05-02 05:59
Have you tried using custom resolution settings in xorg.conf
If you know exactly what your screen supports you could just try plugging in the correct values in the example below and drop that into a clean xorg.conf
Section "Screen"
    Identifier "screen1"
    Device "device1"
    Monitor "monitor1"
    DefaultColorDepth 24
    Subsection "Display"
        Depth 8
        Modes "1920x1080" "1600x900" "1366x768" "1360x765" "1280x720"
    EndSubsection
        Depth 15
    EndSubsection
        Depth 16
    EndSubsection
        Depth 24
    EndSubsection
EndSection
Section "ServerLayout"
    Identifier "layout1"
    Screen "screen1"
EndSection
