#1 2022-04-25 18:38
aurel
Radeon HD 6450 drivers
Hello
I have problem with my video card in Q4OS_64bit_Trinity gemmini
I cannot set proper resolution for my monitor which is 1280x1024
In application download center i only found Install NVidia drivers
so my question is where i can found proper driver for my card
AMD Radeon HD 6450
thanks in advance
#2 2022-04-25 21:41
Re: Radeon HD 6450 drivers
#3 2022-04-26 08:42
aurel
Yes search engines...
but my card refuse to work with propriaty amd radeon drivers
telling me that are not compatibile..
is there a FOSS version of this?
#4 2022-04-26 15:33
I have an ATI Radeon too, although of a different model, and I have the xserver-xorg-video-radeon package installed (at Q4OS install time). Everything is working fine. If it is not already installed on your system, try it.
#5 2022-04-26 17:26
aurel
I found one video on you tube and try this in terminal
lspci -nnk | grep -i -EA3 "3d|display|vga"
xrandr
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install xserver-xorg-video-ati
sudo apt-get install xserver-xorg-video-amdgpu
so do i need to type :
sudo apt-get install xserver-xorg-video-radeon
xrandr
show that i have dvi 1280x1024 but i constantly can only 1024x768 screen resolution?
#6 2022-04-26 18:16
aurel
i tried
and still same just 1024x768
#7 2022-04-27 02:26
Humming Owl
aurel wrote:
i tried
@aurel
Which computer model are you using? In case it is a desktop computer, can you share the name of the monitor?
Cheers.
#8 2022-04-27 07:33
aurel
It is desktop computer dual core pentium 64bit processor
monitor ..hmm that is some strange name YuSmart 17'' VGA 1280x1024 max resolution
i try to change resolution with xrandr
  $ xrandr --output DVI-0 --mode 1280x1024
and work ...but screen is streched out of monitor size then on next boot
i get black screen ..ouff
so i gues i need to go into recovery mode ?
or reinstall ..oh such a nightmare
#9 2022-04-28 00:23
Humming Owl
@aurel
For the black screen try doing the following:
When you hit the black screen try pressing "Ctrl+Alt+F1" (or another F key) to get a terminal to log in. Fill your username and password and execute the following to reset xrandr configurations:
xrandr -s 0
Then type:
sudo reboot
You should get rid of the black screen when booting.
Cheers.
#10 2022-04-28 08:33
aurel
yes i do that
and get same thing after reboot
#11 2022-04-28 18:33
Humming Owl
The same black screen or the same incorrect screen resolution for your monitor?
#12 2022-04-28 20:26
aurel
the same black screen
#13 2022-04-28 22:02
Humming Owl
Try setting up the bad resolution to see if you get rid of the black screen.
xrandr --output DVI-0 --mode 1024x768
sudo reboot
If nothing happens after reboot try pressing again "Ctrl+Alt+F1" (fill username and password) and type:
startx
To see if graphical interface starts up.
#14 2022-05-19 16:13
aurel
hello
just to let you know ..and maybe someone have similar problem
for setting resolution to 1280x1024 on older monitor you need :
xrandr --addmode VGA-0 1280x1024
xrandr --output VGA-0 --mode 1280x1024
even i am using DVI output from my card any debian/ubuntu distro recognize it
like a VGA...my guess because is VGA monitor
