Hello
I have problem with my video card in Q4OS_64bit_Trinity gemmini
I cannot set proper resolution for my monitor which is 1280x1024
In application download center i only found Install NVidia drivers
so my question is where i can found proper driver for my card
AMD Radeon HD 6450
thanks in advance
Yes search engines...
but my card refuse to work with propriaty amd radeon drivers
telling me that are not compatibile..
is there a FOSS version of this?
I have an ATI Radeon too, although of a different model, and I have the xserver-xorg-video-radeon package installed (at Q4OS install time). Everything is working fine. If it is not already installed on your system, try it.
I found one video on you tube and try this in terminal
lspci -nnk | grep -i -EA3 "3d|display|vga"
xrandr
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install xserver-xorg-video-ati
sudo apt-get install xserver-xorg-video-amdgpu
so do i need to type :
sudo apt-get install xserver-xorg-video-radeon
xrandr
show that i have dvi 1280x1024 but i constantly can only 1024x768 screen resolution?
i tried
and still same just 1024x768
i tried
sudo apt-get install xserver-xorg-video-radeonand still same just 1024x768
@aurel
Which computer model are you using? In case it is a desktop computer, can you share the name of the monitor?
Cheers.
It is desktop computer dual core pentium 64bit processor
monitor ..hmm that is some strange name YuSmart 17'' VGA 1280x1024 max resolution
i try to change resolution with xrandr
$ xrandr --output DVI-0 --mode 1280x1024
and work ...but screen is streched out of monitor size then on next boot
i get black screen ..ouff
so i gues i need to go into recovery mode ?
or reinstall ..oh such a nightmare
@aurel
For the black screen try doing the following:
When you hit the black screen try pressing "Ctrl+Alt+F1" (or another F key) to get a terminal to log in. Fill your username and password and execute the following to reset xrandr configurations:
xrandr -s 0
Then type:
sudo reboot
You should get rid of the black screen when booting.
Cheers.
yes i do that
and get same thing after reboot
The same black screen or the same incorrect screen resolution for your monitor?
the same black screen
Try setting up the bad resolution to see if you get rid of the black screen.
xrandr --output DVI-0 --mode 1024x768
sudo reboot
If nothing happens after reboot try pressing again "Ctrl+Alt+F1" (fill username and password) and type:
startx
To see if graphical interface starts up.
hello
just to let you know ..and maybe someone have similar problem
for setting resolution to 1280x1024 on older monitor you need :
xrandr --addmode VGA-0 1280x1024
xrandr --output VGA-0 --mode 1280x1024
even i am using DVI output from my card any debian/ubuntu distro recognize it
like a VGA...my guess because is VGA monitor
