#1 2022-04-06 01:37
atsaloli
Wi-fi works on one network but not on another: SSID not found
Hello,
I installed 64-bit Q4OS (Trinity Desktop) on a Lenovo x230 laptop.
It works at home, I can connect to our house wireless network.
But when I take the laptop to school, I can't connect to their wireless network.  I get the message:
    TDENetworkManager: Connection attempt failed! SSID not found.
I tried removing the network connection and re-adding it.  The network widget shows me that the system picks up the network. (The SSID is correct.)  But whenever I try to connect, I get the above error message.
/var/log/user.log shows:
Apr  4 18:03:39 q4os-desktop NetworkManager[471]: <info>  [1649113419.3208] keyfile: new connection /etc/NetworkManager/system-connections/ORBI46.nmconnection (7b64625c-6b0b-491d-bc23-828e4e37a10c,"ORBI46")
Apr  4 18:04:12 q4os-desktop NetworkManager[471]: <info>  [1649113452.5894] device (wlp3s0): Activation: starting connection 'ORBI46' (7b64625c-6b0b-491d-bc23-828e4e37a10c)
Apr  4 18:04:12 q4os-desktop NetworkManager[471]: <info>  [1649113452.5901] audit: op="connection-activate" uuid="7b64625c-6b0b-491d-bc23-828e4e37a10c" name="ORBI46" pid=1056 uid=1002 result="success"
Apr  4 18:04:12 q4os-desktop NetworkManager[471]: <info>  [1649113452.5944] device (wlp3s0): Activation: (wifi) connection 'ORBI46' requires no security.  No secrets needed.
Apr  4 18:04:12 q4os-desktop NetworkManager[471]: <info>  [1649113452.5948] Config: added 'ssid' value 'ORBI46'
Apr  4 18:04:38 q4os-desktop NetworkManager[471]: <warn>  [1649113478.3040] device (wlp3s0): Activation: failed for connection 'ORBI46'
Apr  4 18:05:51 q4os-desktop NetworkManager[471]: <info>  [1649113551.8242] device (wlp3s0): Activation: starting connection 'ORBI46' (7b64625c-6b0b-491d-bc23-828e4e37a10c)
Apr  4 18:05:51 q4os-desktop NetworkManager[471]: <info>  [1649113551.8243] audit: op="connection-activate" uuid="7b64625c-6b0b-491d-bc23-828e4e37a10c" name="ORBI46" pid=1056 uid=1002 result="success"
Apr  4 18:05:51 q4os-desktop NetworkManager[471]: <info>  [1649113551.8271] device (wlp3s0): Activation: (wifi) connection 'ORBI46' requires no security.  No secrets needed.
Apr  4 18:05:51 q4os-desktop NetworkManager[471]: <info>  [1649113551.8271] Config: added 'ssid' value 'ORBI46'
Apr  4 18:06:17 q4os-desktop NetworkManager[471]: <warn>  [1649113577.3038] device (wlp3s0): Activation: failed for connection 'ORBI46'
"inxi -F":
System:    Host: q4os-desktop Kernel: 4.19.0-17-amd64 x86_64 bits: 64 Desktop: Trinity
           Distro: Q4OS 3.15.2-n1
Machine:   Type: Laptop System: LENOVO product: 2306CTO v: ThinkPad X230 serial: <root required>
           Mobo: LENOVO model: 2306CTO serial: <root required> UEFI [Legacy]: LENOVO v: G2ET92WW (2.52 )
           date: 02/22/2013
Battery:   ID-1: BAT0 charge: 27.0 Wh condition: 37.9/57.7 Wh (66%)
CPU:       Topology: Dual Core model: Intel Core i7-3520M bits: 64 type: MT MCP L2 cache: 4096 KiB
           Speed: 1197 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 1197 2: 1197 3: 1197 4: 1197
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
           Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
           resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 18.3.6
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio driver: snd_hda_intel
           Sound Server: ALSA v: k4.19.0-17-amd64
Network:   Device-1: Intel 82579LM Gigabit Network driver: e1000e
           IF: enp0s25 state: down mac: 3c:97:0e:9f:42:ec
           Device-2: Intel Centrino Wireless-N 2200 driver: iwlwifi
           IF: wlp3s0 state: up mac: 9c:4e:36:bd:11:bc
Drives:    Local Storage: total: 223.57 GiB used: 7.37 GiB (3.3%)
           ID-1: /dev/sda vendor: Corsair model: Force LE SSD size: 223.57 GiB
Partition: ID-1: / size: 218.12 GiB used: 7.37 GiB (3.4%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 975.0 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 46.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 195 Uptime: 14m Memory: 15.37 GiB used: 1.13 GiB (7.4%) Shell: bash inxi: 3.0.32
Both networks show in the network manager of type "802.11 WiFi".
Any suggestions?  I'd like to be able to use the school network.
Thanks,
AT
#2 2022-04-06 06:39
Re: Wi-fi works on one network but not on another: SSID not found
Well, the first suggestion would be to install the latest version of Q4OS. The one you have there is the old Debian Buster base. The newer versions are Bullseye. https://sourceforge.net/projects/q4os/f … o/download
If that produces the same result then it may be your school network uses a different key type so it would be worth checking the settings they provide.
#3 2022-04-09 16:26
atsaloli
Thanks, bin!
I was able to connect to the school's wi-fi by configuring the network connection security to "WPA Personal" and putting in the shared key.
Understood that I'm on an older version of Q4OS.
Thank you for your kind reply.
#4 2022-04-10 05:34
smile
