#1 2022-03-14 00:00
madibi
When from live, I cannot change the place where where to put grub
4,7 Gemini - when I install from live. I cannot change the place where to put grub, that by default goes to sda.
Instead, I want to install it on sdb.
And over all I DONT WANT TO PUT GRUB IN SDA.
Unfortunateli the install program, don't let me to handle the situation
Hany help will be appreciated.
Thx in advance
m
#2 2022-03-20 19:06
Humming Owl
Re: When from live, I cannot change the place where where to put grub
If you can, try removing the hard disk of your computer and then initiate the Q4OS installer with your external drive connected. Grub should now be installed your external drive.
#3 2022-03-20 20:27
Q4OS 4.7 live installer offers grub installation location. Isn't it there ?
#4 2022-03-21 00:36
Humming Owl
I forgot to mention that I have only used non-Live installation images of Q4OS.
#5 2022-03-21 10:47
The topic head suggests OP used live installation images.
4,7 Gemini - when I install from live. I cannot change the place where to put grub ...
#6 2022-03-21 16:54
I tried and I confirm it works well. Thanks.
#7 2022-03-24 14:47
madibi
OK, thx.
I searched only in the manual partitioning and didnt find the box that you highlighted.
I'll give a try
#8 2022-03-28 20:18
madibi
I installed really a lot of distros. Q4OS from 2.4. So before writing to the forum I searched the option that the team showed above.
There is not!
Please see the photo attached
mfile:///home/madibi/Scaricati/IMG_20220328_113214.jpg
#9 2022-03-28 21:36
No photo attached, just a path on your hard disk is displayed.
Use the link "post reply" and use the button in the attachment section (under the text box) to browse to your file and select it.
