#1 2021-12-16 05:20
jethrobodean
Newbie , Q40s will not connect to internet but I have internet and
I have internet on the Desktop and can get around but I can not upgrade or change my profiler in q40s? I have been reading for the last week trying to figure it out,  I cannot reinstall drop box because It says Internet can not be found. please help before I throw this beloved desk top away..
#2 2021-12-16 05:25
jethrobodean
Re: Newbie , Q40s will not connect to internet but I have internet and
I am hard wired to a modem...I am using the desktop now to make contact here...
#3 2021-12-16 08:53
I don't understand whether your problem is
- connecting to Internet
- upgrading / changing your "profiler" (what is this?)
- re-install Dropbox
And who is "it" who says Internet can not be found?
Can you
- hover the mouse over the Network conections icon in the tray and look at the popup: is a connection active?
- right-click on that icon, choose Configure connections and look at the parameters: do they seem correct?
#4 2022-01-02 22:58
Brad
I have a simulaur problem.  I can use the internet as i am using it to create this post.  When i use the desktop profiler to select a profile or install any apps i get an error 30.
I ran  wget q40s.org  and got an error: certificate fo q4os.org is not trusted.
#5 2022-01-03 09:57
@Brad
Please post more information about your system and debug info as described here https://www.q4os.org/forum/viewtopic.php?id=3502 . We will try to help you to resolve the issue.
