#26 2021-10-27 11:26
Re: Share monitor screen to tv
@SteveM
It would be helpful for researching this issue, if you would give a try the vanilla Debian Bullseye Plasma live media and Q4OS Gemini Plasma live media testing out and post the result here. You can download the latest media here:
Debian Bullseye Plasma:
https://cdimage.debian.org/debian-cd/cu … so-hybrid/ .. file: debian-live-11.1.0-amd64-kde.iso
Q4OS Gemini Plasma:
https://www.q4os.org/downloads1.html ... Q4OS Gemini, Plasma, live - 64bit / x64
#27 2021-10-28 03:00
SteveM
The one above wouldn't run. An error, while attempting to boot up, said it was missing firmware.
_________________________________________
Q4OS Gemini Plasma:
The HDMI was connected and the TV on when this one booted up. The popup came up, but nothing happened when I clicked unify screens. Then I went to the display manager, but it was only showing the laptop and not the TV.
#28 2021-10-28 10:56
Would you try Debian with non-free firmware live media please ?
https://cdimage.debian.org/cdimage/unof … so-hybrid/ ... file: debian-live-11.1.0-amd64-kde+nonfree.iso
#29 2021-10-28 21:02
SteveM
I gave it a try with a live USB. It didn't work, even though I had the cable plugged in and the TV on. Then I typed xrandr into the terminal. It only sees my monitor, and not the TV. A live USB with Linux mint is the only one that has worked so far. The TV was detected as soon as the OS loaded.
#30 2021-10-28 22:10
@SteveM
Thanks for the valuable information. We will continue to investigate the issue and post back, as we find anything ralated.
