#1 2021-09-15 08:54
skrebl
Install viber on Q4OS Trininty (32 bit)
Anybody here that managed to successfully install and run viber on Q4OS?
I don't see viber as a package in any of the package managers (e.g synaptic, gdebi, playonlinux)
So I followed the instructions for wine, installed it, got vibersetup.exe with wget and the trying to install viber with sudo wine command.
Got viber ui shown, it seems it got installed but the window got closed towards the end.
If I try to install it again, I get Remove option only.
#2 2021-09-15 13:20
Re: Install viber on Q4OS Trininty (32 bit)
Viber has a native Linux installer as well as an appimage version, and both can be found here https://www.viber.com/en/download/ no need for Wine.
Choose the one for Ubuntu, it should install in Q4OS with no problems, or download the appimage.
#3 2021-09-15 20:21
skrebl
I tried with
sudo dpkg --force-architecture -i viber.deb
and got the following:
Selecting previously unselected package viber:amd64.
(Reading database ... 200101 files and directories currently installed.)
Preparing to unpack viber.deb ...
Unpacking viber:amd64 (13.3.1.22) ...
dpkg: dependency problems prevent configuration of viber:amd64:
viber:amd64 depends on libpulse0.
viber:amd64 depends on libasound2.
viber:amd64 depends on libnss3.
viber:amd64 depends on libgstreamer-plugins-base1.0-0.
viber:amd64 depends on libgstreamer1.0-0.
viber:amd64 depends on gstreamer1.0-plugins-base.
viber:amd64 depends on gstreamer1.0-plugins-good.
viber:amd64 depends on gstreamer1.0-plugins-ugly.
viber:amd64 depends on gstreamer1.0-pulseaudio.
viber:amd64 depends on gstreamer1.0-libav.
dpkg: error processing package viber:amd64 (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils (0.23-4) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Errors were encountered while processing:
viber:amd64
If I check under Synaptic Package Manager, all these dependencies are installed, but it reports Viber as broken.
Viber is seen under Applications. If I click on it, nothing happens.
And is available at /opt/viber.
Any hints how to move on?
#4 2021-09-15 20:34
skrebl
khm, I will try to instal amd64 versions of the above.
#5 2021-09-15 20:41
skrebl
OK, added the misssing dependencies, removed viber and installed it again:
root@q4os-desktop:/home/berti/Downloads# sudo dpkg --force-architecture -i viber.deb
(Reading database ... 201253 files and directories currently installed.)
Setting up viber:amd64 (13.3.1.22) ...
This time no errors.
Viber is showing under apps, but it's not opening after clicking it.
#6 2021-09-16 02:05
Next time, when installing .deb files downloaded from internet use apt
sudo apt install ./viber.deb
this way all dependencies will be installed. Try running the app from terminal
/opt/viber
and check for any errors that may appear. Then you can copy/paste those here, so we can take a look at them.
#7 2021-09-16 17:29
skrebl
I reinstalled viber
root@q4os-desktop:/home/berti/Downloads# sudo apt install ./viber.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'viber:amd64' instead of './viber.deb'
The following packages were automatically installed and are no longer required:
  gnome-keyring gnome-keyring-pkcs11 kdbusnotification-trinity
  libayatana-appindicator3-1 libayatana-ido3-0.4-0 libayatana-indicator3-7
  libdbusmenu-glib4 libdbusmenu-gtk3-4 libnma0 libpam-gnome-keyring
  mobile-broadband-provider-info p11-kit
Use 'sudo apt autoremove' to remove them.
  viber:amd64
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/99.7 MB of archives.
After this operation, 358 GB of additional disk space will be used.
Get:1 /home/berti/Downloads/viber.deb viber amd64 13.3.1.22 [99.7 MB]
Preparing to unpack .../home/berti/Downloads/viber.deb ...
but cannot execute Viber:
root@q4os-desktop:/home/berti/Downloads# /opt/viber/Viber
-bash: /opt/viber/Viber: cannot execute binary file: Exec format error
root@q4os-desktop:/home/berti/Downloads# ls -al /opt/viber/Viber
-rwxr-xr-x 1 root root 44562952 Jul  7  2020 /opt/viber/Viber
Then google said I might have architecture problems, but all seems to be ok and supported:
root@q4os-desktop:/home/berti/Downloads# dpkg --print-architecture
i386
root@q4os-desktop:/home/berti/Downloads# dpkg --print-foreign-architectures
amd64
#8 2021-09-17 03:20
I downloaded viber, both the .deb installer and the appimage, but haven't had the chance to try neither in my VM. Is your Q4OS 32bit or 64? I only have  64, so if I try, the results will be for that. You could try the appimage and see if that works. You probably should install that pkg with your user, not root, to avoid permissions issues, just saying smile
#9 2021-09-17 10:44
skrebl
It's 32 bit. I'll try again without sudo. And with appimage. smile
#10 2021-09-17 13:07
I think you will find that the deb is 64 bit - even though there's a link in their site it goes to the same location as the 64 bit.
Wisdom has it that you need 32 bit WINE and the 32 bit windows app to make this work on a 32 bit system - cannot verify as I don't use it.
#11 2021-09-17 16:40
skrebl
Without sudo I immediately get lock error.
appimage was not executable.
tried with wine again, need sudo but, got it installed, but then cannot open it.
OK; if anybody succeeds, please let me know. smile
#12 2021-09-17 17:42
What I meant is this root@q4os-desktop:/home/berti/Downloads# why are you doing this as root, instead of using your regular user(berti?)?
You have to make it executable
chmod +x viber.Appimage
or open the file manager, locate the file, select it, hit Alt + Enter, the properties window will pop up, go to permissions' tab, and check the box that reads make this file executable or some similar wording. I got the appimage working here with no problems, check it out:
However, I'm running a 64-bit OS, whereas yours is 32-bit, and checking viber.Appimage gives
file viber.AppImage
viber.AppImage: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.18, stripped
Not sure whether that means it runs or not in a 32-bit OS.
#13 2021-09-19 18:19
skrebl
sorry, I was not precise:
berti@q4os-desktop:~/Downloads$ apt install ./viber.deb
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
And
berti@q4os-desktop:~/Downloads$ ./viber.AppImage
bash: ./viber.AppImage: cannot execute binary file: Exec format error
berti@q4os-desktop:~/Downloads$ ls -al viber.AppImage
-rwxrwxrwx 1 berti berti 140435432 Sep 17 17:22 viber.AppImage
#14 2021-09-19 18:26
And
Yes, that's what I was referring to, but with your user you need sudo, that's just fine
berti@q4os-desktop:~/Downloads$ sudo apt install ./viber.deb
You need to make the appimage executable, like I said in my previous post.
