Hello
On my laptop with q4os, I have VB and am trying to run some live cd.
I find that when VB is in full screen mode, then content is seen. But disabled. There is some sort of darkness (hidden window) which seems to block the clicks. Scaled mode works.
Please help.
Thx.
youtu.be/GH2Dl-rfskk
Please check the video I captured on mobile. It will give some idea of the issues i am facing.
www.virtualbox.org/ticket/6089 same issue as mine.
Not sure but I recall something to do with Virtualbox Guest Extensions for full screen functionality - you have to download and install.
One reason why I prefer QEMU/KVM ![]()
when i try to install VB addons, it says that VB env not detected. are you really running inside VB host? if not, this setup doesnt make any sense.
