#1 2021-09-16 13:48
schnappi
VirtualBox full screen show screen in "disabled" mode
Hello
On my laptop with q4os, I have VB and am trying to run some live cd.
I find that when VB is in full screen mode, then content  is seen. But disabled. There is some sort of darkness (hidden window) which seems to block the clicks. Scaled mode works.
Please help.
Thx.
#2 2021-09-17 00:43
schnappi
Re: VirtualBox full screen show screen in "disabled" mode
youtu.be/GH2Dl-rfskk
Please check the video I captured on mobile. It will give some idea of the issues i am facing.
#3 2021-09-17 00:58
schnappi
www.virtualbox.org/ticket/6089 same issue as mine.
#4 2021-09-17 06:38
Not sure but I recall something to do with Virtualbox Guest Extensions for full screen functionality - you have to download and install.
One reason why I prefer QEMU/KVM smile
#5 2021-09-17 08:14
schnappi
when i try to install VB addons, it says that VB env not detected. are you really running inside VB host? if not, this setup doesnt make any sense.
