#26 2021-06-16 10:44
Re: Q4OS 4.5 Gemini
We can confirm that. We would assume, Firefox uses different engines for rendering different widgets, most likely the main scrollbar uses some sort of integrated GTK engine, while others use the system theme. Does FF main scrollbar follow the configured GTK3 theme at all in other desktop environments, for ex. XFCE ?
Thanks for the info - I will remove the settings_trinity.ini as suggested.
The themes mentioned - and others - are all recognised fully in
Buster + XFCE
Buster + Trinity 14.0.10
Bullseye + MATE
Bullseye + LXDE
I suspect it IS a GTK3 thing, though it would make no sense to use different scroll bars in different windows.
The various DEs are not readily comparable side by side as I know that both MATE and LXDE draw heavily on GTK2 despite being on Bullseye so it may be more of luck than anything else.
At least the config tools now work as expected in other applications so it hasn't been a pointless exercise smile
Thanks again!
#27 2021-06-16 17:31
Rosul
Re: Q4OS 4.5 Gemini
If I install this build, can I just continue to use it after Debian and Q4OS have released stable releases, will I need to reinstall or do other things?
#28 2021-06-16 19:36
Re: Q4OS 4.5 Gemini
Yes, it will be possible update and continue using it, however a new installation will be recommended to get a fresh and clean stable system.
#29 2021-06-16 20:10
Re: Q4OS 4.5 Gemini
Buster + XFCE
Bullseye + MATE
Bullseye + LXDE
Confirmed. In addition, Firefox ESR in Plasma seems to work partially, the same way as in Trinity. Those systems:
Bullseye + TDE
Bullseye + Plasma
#30 2021-06-17 06:20
Re: Q4OS 4.5 Gemini
I've just tried with Bullseye + XFCE - Firefox ESR honours the themes
#31 2021-06-17 09:13
Re: Q4OS 4.5 Gemini
Buster + XFCE
Bullseye + MATE
Bullseye + LXDE
Bullseye + TDE
Bullseye + Plasma
Just done a quick install with the latest Bullseye + Plasma KDE from the Debian weekly builds
Firefox behaves perfectly with the installed GTK themes mentioned.
Double checked with a different Bullseye + Plasma distro and that was also fine with both ESR 78 and FF 88.0
#32 2021-06-17 09:31
Re: Q4OS 4.5 Gemini
Confirmed. So, it's definitely Q4OS issue, we will continue to investigate it. Are there other elements in Firefox, except the main window scrollbar, not following the GTK3 theme ?
Edit:
We have created new bug report https://sourceforge.net/p/q4os/tickets/160/ . Reporting any related findings is appreciated.
#33 2021-06-17 11:45
Re: Q4OS 4.5 Gemini
I have updated the ticket as follows:-
Some of the tools under the hamburger do follow the GTK theme. The ones that do not are:-
Protections dashboard
New Window
New Private Window
Logins and Passwords
#34 2021-06-28 15:41
Re: Q4OS 4.5 Gemini
Hi,
In order to test if Q4os 4.5 Gemini could solve this issue (SEC_ERROR_PKCS11_GENERAL_ERROR) I tried to install it in several machines, but all attempts failed.
  • Desktop Intel i5 with VTx - Win10 x64 host - VirtualBox 5.2.38 x64 - q4os-4.5-x64-testing.r2.iso
        I get many error messages scrolling several screens, ending with Kernel panic - not syncing: Attempted to kill ini!.
        Another time it ends with "A start job is runnig for... and freezes"
  • Laptop Intel P6000 without VTx - Q4OS 3.14 host - VirtualBox 5.2 x64 - q4os-4.5-i386-instcd-testing.r2.iso
        I get two successive Segmentation fault errors, but I don't have enough time to read all.
        When I arrive at the language selection screen, the VM totally freezes; no action of the keyboard or the mouse is possible.
I never had any problem when I tried to install Q4OS 3.10 and the following editions. Did I miss something with Q4OS 4.5? Maybe a specific requirement?
Note that my main concern is to try to search further the reason of the SEC_ERROR_PKCS11_GENERAL_ERROR about which I posted a message last week; I was curious whether it could be solved with Gemini.
Thanks,
Laurent
#35 2021-06-28 16:38
Re: Q4OS 4.5 Gemini
I could enable the video capture of the VM machine. Here are the messages displayed in the second case of my previous mesage:
Segmentation fault
Starting system log daemon: syslogd, klogd.
Trying to enable the frame buffer...
Segmentation fault
haveged: command socket is listening at fd 3
Then the screen is filled with white blocks and thereafter with black blocks.
After that comes the Select a language dialog and freezes on it.
Edit: Not these problems when I tried to install q4os-3.14-i386-instcd.r5.iso
#36 2021-07-01 07:52
Re: Q4OS 4.5 Gemini
@hchiper
Thanks for reporting. We are not able to reproduce crashes in Virtualbox, the virtual machine boots fine. What parameters for the VM did you set upon creating it ?
#37 2021-07-02 15:25
Re: Q4OS 4.5 Gemini
Thanks for your response.
I think the best way to answer your question is to attach my .vbox configuration file.
I use VirtualBox 5.2.34 r133893
Q4OS Gemini.vbox
#38 2021-07-03 18:15
danielson
Re: Q4OS 4.5 Gemini
4.5 r2 flawless installation!
Was nice to see Vivaldi added to list of readily available software list ! smile
It is running just fine!
Don't know why, but it seems that the only way i can ever make the HP 1018 printer to work, is to manually install the driver via Konsole with:
hp-plugin -i
(just in case someone has same issue).
DELL Optiplex 7060 - 8G RAM.
#39 2021-07-05 10:37
Re: Q4OS 4.5 Gemini
@danielson
Would you specify the way and error on HP 1018 printer installation for us to be able to reproduce and investigate ?
#40 2021-07-05 10:40
Re: Q4OS 4.5 Gemini
@hchiper
You may need to use the more up to date Virtualbox version 6.
#41 2021-07-05 13:02
Re: Q4OS 4.5 Gemini
Thanks q4aosteam.
The problem with Virtualbox6 is that I even cannot save a machine config (OK button greyed) because VB detects an error and requires me to disable VT-x acceleration in the Acceleration tab. But this tab is inaccessible (greyed), I suppose because my processor has no VT-x.
Edit:
Looks like VB6 enables VT-x by default, even if the host has no VT-x... ?
Edit 2:
I just tried to install Debian debian-bullseye-DI-rc2-i386-netinst.iso in VB5.2 and the behavior was exactly the same (segmentation faults and blocked on the language dialog).
#42 2021-07-06 02:59
danielson
Re: Q4OS 4.5 Gemini
@danielson
Sorry for the delay.
There are no error messages.
Diligently install the HP app. (btw, printer was already recognized by OS) which says the driver would be installed (but never happens).
So, always install it manually as per command line mentioned.
I'm used to it, as all the other OS do it too.
Not a Q4OS issue for sure!
Just a stupid ol' HP printer.
#43 2021-07-06 05:15
Re: Q4OS 4.5 Gemini
I find the Gutenprint driver works much better with my HP 1010 than HP CUPS
Connected via a USB print server and uses Appsocket/HP Jet Direct protocol
#44 2021-07-06 20:49
aluma
Re: Q4OS 4.5 Gemini
Not everyone is so lucky! smile
My HP LaserJet 1005 (like the 1018 of colleagues) is not in the Gutenprint lists.
So, unfortunately, I can't. compare the performance of hardware manufacturer programs and free software programmers, but, from experience, the latter usually fail for known reasons.
However. under Linux, I can use the scanner of my HP f2400, without ink tanks, but under Win they do not want the driver.
As I understand it, the question is, that hplip is not installed by default, but here Q4os tried, added it to the Q4OS Software Center.
#45 2021-07-09 06:40
Re: Q4OS 4.5 Gemini
I also tried to install Gemini 64 bits into Virtualbox 6 on a Win10 x64 host (i5 processor with VT-x) and I have got a kernel panic error at the very beginning (before seeing any dialog).
I'm not far from giving up sad
#46 2021-07-11 09:03
Re: Q4OS 4.5 Gemini
@hchiper
We will check that out and post back.
#47 2021-07-11 12:57
Re: Q4OS 4.5 Gemini
@hchiper
We are not able to reproduce kernel panic. Windows 10 host, Virtualbox 6.1.22, virtual machine Debian 64bit, 2GB RAM, install media q4os-4.5-x64-testing.r2.iso.
Installation as well as post install steps goes just fine. What desktop profile did you choose on installation ?
Have anyone else encountered kernel panic as described above ?
#48 2021-07-11 20:25
Re: Q4OS 4.5 Gemini
I have to apologize, because I tried to install Gemini q4os-4.5-x64-testing.r2.iso into VirtualBox 5.2, not 6.
On the other hand I could install q4os-4.5-i386-instcd-testing.r2.iso into 5.2 and run it successfully.
I'm not skilled enough to understand why I'm able to install only the 32 bits version.
Unluckily, the authentication error I reported was not solved with this new version. Anyway I'll follow the updates.
