#1 2021-05-19 21:57
xendistar
Chromium will not start
Chromium will not start on a new install with Trinity Desktop
If I try from the CLI I get the following error:
Received signal 4 ILL_ILLOPN 0000056b9790
Illegal Instruction.
I have tried a complete re installation of  Chromium but that made no difference
For whatever reason Konqueror will not load any pages, although I can ping any IP address or Domian name and get a reply
Can anybody please advise
#2 2021-05-19 22:13
Re: Chromium will not start
Are you using 32bit or 64bit system ? Please specify, see https://www.q4os.org/forum/viewtopic.php?id=3502
This is known Konqueror bug, that shows on some systems. It's resolved in the next Trinity version, deployed in the Q4OS 4 Gemini.
#3 2021-05-29 04:25
doq
Hi my name is Daniel, I use a learning netbook with Q4OS 32 bit system and Trinity Desktop, 2 Gb ram and a CPU @1,60 Ghz and I use as web browsers Firefox and Chromium. Zoom web in FIrefox give crash and chromium works good but I can't receive video for others, I can listen to the rest but I can't see the screen from others, just my screen and camera, etc. Best regards.
#4 2021-05-29 20:33
aluma
Hi, Daniel.
Unfortunately, there is not enough information about your computer to give any advice.
Intel Atom processors came with the GMA3150 video card for which there was only one ancient version of the Linux driver.
The video from the webcam goes in a very low resolution, and perhaps the driver by default copes with it, but it is not capable of a higher resolution.
But these are only assumptions ...
#5 2021-05-31 01:50
doq
Hello, thank you very much for your reply. I should have mentioned the features of my laptop, sorry. It is from 2013, it has 2 gs of ram, an Intel Atom N 3600 Series processor with a cpu @1.6 Ghz and a gma video card. It has a 10.1 inch screen, a resolution of 1024x600 pixels and a 2.0 megapixel integrated camera. Best regards.
#6 2021-05-31 07:21
aluma
Hi!
Intel gma 3600 is one of the worst options for Linux.
There is no manufacturer's driver, no source codes, and as a result, hardware acceleration does not work.
https://wiki.archlinux.org/title/Intel_GMA_3600
