#1 2021-05-11 11:43
Djdols
[SOLVED] 90 seconds boot problem
So I deleted the swap partition and edited the /etc/fstab file already to remove the line with swap. But the problem is, q4os still waits for 90 seconds on boot. Is there any way to fix this?
#2 2021-05-11 12:05
Djdols
Re: [SOLVED] 90 seconds boot problem
nvm guys i fixed it, turns out /etc/default/grub has a line GRUB_CMDLINE_LINUX_DEFAULT with the parameter of resume="someUIID" in which that UIID i believe is the partition that i removed. So i just removed that line
#3 2021-05-11 19:54
aluma
Everything is clear here, except for one thing, why remove swap?
If Linux runs out of memory, it will simply stop.
#4 2021-05-12 12:43
You can always swap from a file, can't you?
https://linuxize.com/post/create-a-linux-swap-file/
#5 2021-05-12 12:55
aluma
A swap partition, mounted on the peripheral of the hard drive will run faster, than just a file, written in the middle of the drive.
In addition, fragmentation of the latter is possible.
#6 2021-05-13 05:42
......if it is a very old spinner. SSD doesn't make any difference.
#7 2021-05-13 14:24
Also, with 8+ GB of RAM, unless you do intensive computing, the swap is rarely ever used, if at all. My desktop has 4 GB and a 2 GB swap partition, but it almost never use it.
#8 2021-05-13 19:39
aluma
...if it is a very old spinner...
The principle of operation and the distribution curve of the read / write speed are the same for old and modern hard drives.
Another question is how critical this segment is, relative to the speed of other computer devices.
#9 2021-05-13 19:55
aluma
My 4RAM computers also run with an empty swap.
But I can give you a more specific example.
2 GB RAM,  Q4os 32bit, full default installation.
Disconnected the second hard drive, forgetting that I installed swap on it myself.
Everything worked, but on the 4th facebook tab, Firefox stopped.
This is what I wanted to draw the attention of Q4os users.
And to have a swap and in what form is the owner's task.
"I want" and "can my device" is different for everyone. smile
#10 2021-05-14 06:05
Can't say i blame it - I wouldn't get past one tab.
#11 2021-05-14 12:55
Yes, you're right, and that's exactly why I said with 8+ GB of RAM, depending on what you do in your PC, a swap partition may or may not be needed.  Maybe OP's machine has 64 GB of RAM, we don't know, he didn't tell, and that's why he removed the swap.
