#1 2020-09-27 21:18
danielson
WUBI style Centaurus not working [Solved]
Tried to install WUBI style Centaurus...
Assigned 64Gb + username + p.w.
At reboot, after going through a slew of codes, asks for username and password.
Have tried twice and it isn't working.
At least i know that trying to re-install allows to remove just like WUBI used to.
DELL Optiplex 7060 - 8G RAM.
#2 2020-09-27 23:19
Re: WUBI style Centaurus not working [Solved]
Did you try to log with the username and password in ? Did installation go well ? If so, it looks more like a hardware related issue. as we are not able to reproduce that. Centaurus installer is working fine here.
You could also try new Quark wubi testing installer:
Installer download: https://sourceforge.net/projects/quark- … nsetup.zip
Setup guide: https://www.q4os.org/dqa014.html
#3 2020-09-28 00:17
danielson
@q4OS Team - went for a third attempt.
This time, instead of selecting reboot option, went for the shutdown and then everything went as expected.
Quick question: if we decide to uninstall again, can we use the WUBI style installer to do that?
Btw, seeing that everything is working fine now, might wait a while before testing the new Quark installer.
-what is new in Quark installer?
#4 2020-09-28 10:13
Yes, Windows installer, Wubi style, completely erases the Q4OS installation as it had never been installed.
danielson wrote:
... what is new in Quark installer?
It's just the same, Wubi style, installer for Quark operating system https://sourceforge.net/projects/quark-os/
#5 2020-09-28 11:23
danielson
That is good Q4OS Team!
Wonder why they ever did do away completely from WUBI?
So handy for newbies.
#6 2020-09-28 13:24
I so strongly agree -- as well as for a number of border cases OS setup, like virtual disks and/or loop devices... smile
#7 2020-09-28 13:48
@Midas
By the way, the Quark windows installer, as well as loop image, has been updated yesterday, you are welcome to test it out smile
#8 2020-09-28 14:43
danielson
Noticed Quark pending for approval at Distrowatch today Sept. 28, 2020.
A part from having both Q4OS+Trinity (which already exists right?), what makes Quark different?
A more recent Debian base?
Btw, of all the KDE distros i've tested so far, Q4OS uses less resources.
#9 2020-09-28 16:37
Quark is an Ubuntu-based distribution featuring Q4OS utilities,see https://sourceforge.net/projects/quark-os/
#10 2020-09-29 13:56
The Quark windows installer, as well as loop image, has been updated yesterday...
Thank you ever so much for that, will do. cool
