#1 2016-02-02 03:04
MC
Q4OS 2.0.2: Conky not reading eth0 downspeed / upspeed [Solved]
The settings I have work on my 1.4.6, but on 2.0.2 I'm not getting any readings on either conky for down/up speed.
Thanks for any help.
Q4OS running Xfce
#2 2016-02-02 11:42
Re: Q4OS 2.0.2: Conky not reading eth0 downspeed / upspeed [Solved]
Check your connection names using
sudo ifconfig
If I remember right they could be different and you will have to change the name for them. ie etho could now be something like espcn0
HTH
Dai
#3 2016-02-02 12:12
MC
Thanks Dai. I got it now.
Funny, I've never seen anything other than eth0 for wired.
Q4OS running Xfce
#4 2016-02-02 12:33
I first noticed it in debian testing and as 2.0.2 is derived from that i figured it would be the same.
Dai
