The settings I have work on my 1.4.6, but on 2.0.2 I'm not getting any readings on either conky for down/up speed.
Thanks for any help.
Q4OS running Xfce
Check your connection names using
sudo ifconfigIf I remember right they could be different and you will have to change the name for them. ie etho could now be something like espcn0
HTH
Dai
Thanks Dai. I got it now.
Funny, I've never seen anything other than eth0 for wired.
Q4OS running Xfce
I first noticed it in debian testing and as 2.0.2 is derived from that i figured it would be the same.
Dai
