#1 2019-07-30 10:10
KMix problems in Centaurus i386
I have installed Q4OS Centaurus, Trinity, install-cd - 32bit / i386 on my notebook yesterday, and discovered some problems with KMix, and weird behavior, which lead to complete PC hang sad
1.After I have installed Basic desktop profile (without pulseaudio), KMix slider showed something strange, and audio was not working at all.
https://drive.google.com/open?id=1131QF … f4rWNG0Y3o - KMix without PulseAudio
https://drive.google.com/open?id=111Nkb … 0u9ctFRb3S - KMix without PulseAudio
2.After I installed pulseaudio and pavucontrol, audio started to work, but still I was unable to move the slider using mouse scroll. I followed this advice, but I still unable to selert PulseAudio Master channel as preferred channel.
3.The most annoying thing. When I try to change global key combination, the KMix simply hangs, and returns error. What's worse, after that error PC hangs completely, and I have to do hard restart using Reset button.
https://drive.google.com/open?id=10y0oI … vUmXCa3bk5 - Failure and full freeze
https://drive.google.com/open?id=10mJZg … Oin2dj40qf - Failure and full freeze
https://drive.google.com/open?id=10zywl … XsaiFXOx3m - KMix Error
4.Translation is absent.
https://drive.google.com/open?id=11-65T … 367emD9BwM - Translation issue
My Notebook info:
https://drive.google.com/open?id=113ojs … TBPKFvgTLk - system information
https://drive.google.com/open?id=10de0u … fvkxjAIOtC - system information
Anyway, KMix needs some work to be done.
#2 2019-07-31 09:24
Re: KMix problems in Centaurus i386
We are checking all mentioned at the moment, post a feedback as soon as finished.
#3 2019-07-31 10:31
I gave up on Kmix after reported issues a while back http://www.q4os.org/forum/viewtopic.php?id=2689
Install pasystray - it works.
#4 2019-07-31 10:59
Yes, pasystray should work, however it's not pure TDE application, and adds an extra load to a clean TDE system. We are sure, the "kmix" is fully functional on at least some TDE systems.
Anyway, we will try to split the OP to a single issues and investigate them one by one. Unfortunately, it's not easy to investigate such type of issues, as different hardware configurations influence them significantly. A feedback will be posted later.
#5 2019-07-31 11:23
Thank you!
Still it is a workaround, which does not solve the initial KMix problems.
I will try it.
#6 2019-08-02 21:29
We have performed quite a thorough investigation, here are some results in short.
1. Fixed, install-cd revision ".r5"
2. Fixed, install-cd revision ".r5". We can confirm controlling KMix slider using mouse wheel doesn't work sometimes, looks like another KMix bug. We are investigating it still.
3. TDE bug confirmed https://bugs.trinitydesktop.org/show_bug.cgi?id=2955 , not connected to kmix directly.
4. We can confirm a missing TDE translations at the moment.
We have also reported a new TDE bug https://bugs.trinitydesktop.org/show_bug.cgi?id=3031
Thanks for the detailed reporting.
