#1 2019-07-27 21:25
JimW
Display resolution not holding during reboot *SOLVED*
My display has a default resolution 1600 X 1200 which is what Q4OS Centurian found on installation. However, due to eyesight and preferences I change it to 1024 X 768. I have found on reboot or restart after power down that the display resolution has changed back to 1600 X 1200 and I have to reset it.
Is there any way to get this to 'stick'?
(inxi.txt attached if needed)
#2 2019-07-27 22:10
Re: Display resolution not holding during reboot *SOLVED*
You could try to use the "tderandrtray" utility, however we would recommend you to keep the native display resolution and use the DPI setting:
Control panel > System administration > Screen scaling
#3 2019-07-28 00:27
JimW
"Control panel > System administration > Screen scaling"
After a bit of experimenting that seems to have worked. Default was 96 and I've changed it to 130. Seems a bit off from doing it via the desktop config, but shouldn't be too hard to get used to.
Thanks.
